Hello,
Sorry about the vague topic, I couldnt come up with a better one.
I am using Arduino Mega R3. I have made a Fingerprint Attendance System and already wired the Ethernet Module ENC28J60. My objective is to send data(id of the finger and time) to my PC when a finger is identified on my arduino.
As far as I researched, I found two options:
1.Web Server - I can make a program on the pc to read the txt on html page.
2.FTP - I can store the data in txt file and send the text file.
I found the FTP setup very complex and could not get the Web Server to print dynamic data onto the html.
Is there any other way to achieve my objective?
I would appreciated ideas you would like to share
Thanks a lot in advance
it depends, what is it you want the computer to do?
Thank you for your concern,
I want the pc to read the data(most probably through java application ), then sort the data according to departments and update their attendance in the database. I am keeping the database on the server so that users can view their attendance online. I plan to develop a php website to serve the purpose.
Hang on - maybe a moderator can change the post to interfacing w/ Software on Computer area...
This is not the proper approach. Each time a fingerprint is scanned, the client should make a GET request to the server, to execute some PHP script that will record the data in the database.
You will have some other application/PHP scripts that will access the database, which can do a far faster job of sorting, and categorizing, the data. The application will be responsible for displaying the data in some meaningful way.
Thank you for your response,
PaulS:
I just googled on how to do that, It makes my program more simple than I had planned it to be
Thank You once again.
