Need guide in pushing data from micro-controller to server
Firstly, Im a newbie in IoT field. Hardware parts is quite new to me.
I want to make a small project. That is creating a box attached into a car that can keep track its location and temperature. And, inside the box, there are a micro-controller (i think about arduino as it easy for newbie,) , a temp sensor, a gps receiver. Now, when the car running, this box's function is pushing sensors data to server for processing, then I write a web to show them. Currently, I'm in researching stage :). I have a concern that how to push data from the box onto server. Can you advise me some technologies as well as required hard-ware parts for doing that stuff. (And it is better if that technology can scale for a bunch of cars, because I want to make for a bus system, not only one car.)
I'm very appreciate for the helping.
Im very appreciate for the helping.
How do you plan to connect your box to the server?
as far as i know, i will use another sim module, connect to arduino then push data through 2g or 3g. But is there any different way of doing this ? I want to know deeply about this problem before put hand in implementing.
2g/3g is probably the way to go, because there will be a network of receiving masts covering the bus routes. But this will mean paying for a sim for each vehicle.
The other option I can think of is LoRa. This is a relatively new technology with similar range to 2g/3g provided there is a suitable number of receiving "masts" to cover the area required, which is unlikely in most cities outside US/Europe.
what is you technical background? electronics? programming? web development?
Go with esp8266.compared to ethernet shield its bit easy for you
Juraj:
Im currently a student whose major is software development. I want to try something new in IoT field.
DON'T CROSS POST!!!!!!!!!!!!!!!!!!!!
http://forum.arduino.cc/index.php?topic=518213
I HAVE REPORTED THIS THREAD TO THE MODERATORS
Threads merged.
