So I decided for a school project that I was going to try and do a build with the Dagu Wild Thumper 6wd with a 6DOF Arm.
I've already purchased the majority of the required parts needed for the project.
Here's a list of the parts:
Dagu: 6 w.d. WT, 6 DOF arm, WT motor control, and high power switch
2 Turnigy 7.2V 6K mA batteries, HK 6ch RC Tx & Rx, and charger
Arduino Mega 2560 and I also have an Uno and a internet shield.
Only things I plan on still getting is a camera and a router or wifi shield(still debating on that).
If any one has any experiance with this project, please help this noob out! Am I missing anything else and mainly the coding needed to have the arm to work!?!
Bottom is some multiple servo test code. Below is some info on using sliders on a web page to control servos. It uses an SD card to hold the files that are uploaded to the control web page.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or combined like 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
