Need help about this code.
hi im new here, before i use this code on my arduino nano with bread board and lcd. now im just move to lcd keypad shield and arduino uno. after upload the code nothing shows, after review just change pin LiquidCrystal then ok. now my problem, im cannot select the menu using keypad shield.
that code i use.
//------------------------------- librarys ----------------------------------
#include <LiquidCrystal.h>
#include <Servo.h>
//------------------------------- lcd ----------------------------------
LiquidCrystal lcd(12, 11, 2, 3, 4, 5);
//------------------------------- stepper ----------------------------------
#define stepPin 7
#define dirPin 8
//------------------------------- servo ----------------------------------
Servo snippers;
#define servo 10
#define openAngle 180
#define closedAngle 0
//------------------------------- input ----------------------------------
#define leftButton 14
#define rightButton 9
#define upButton 15
#define downButton 6
//------------------------------- user settings ----------------------------------
unsigned int wireLength = 0;
unsigned int wireQuantity = 0;
//------------------------------- system settings ----------------------------------
int state = 0;
int incrementSpeed = 1;
int previousWireLength = 0;
int previousWireQuantity = 0;
float mmPerStep = 0.18096;
  lcd.begin(16, 2); //LCD columns and rows
  pinMode(upButton, INPUT_PULLUP);
  pinMode(downButton, INPUT_PULLUP);
  pinMode(leftButton, INPUT_PULLUP);
  pinMode(rightButton, INPUT_PULLUP);
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  snippers.attach(servo);
  snippers.write(openAngle);
  if (!digitalRead(rightButton)){
    if(state == 5){
      state = 0;
    else{
      state += 1;
    delay(200);
    lcd.clear();
  if (!digitalRead(leftButton) && state > 0 && state < 4){
    state -=1;
    delay(200);
    lcd.clear();
  switch (state){
    case 0:
      homeScreen();
    case 1:
       chooseWireLength();
    case 2:
      chooseWireQuantity();
    case 3:
      confirm();
    case 4:
      currentlyCutting();
    case 5:
      finishedCutting();
void homeScreen(){
  lcd.setCursor(0, 0);
  lcd.print("WIRE CUTTER");
  lcd.setCursor(11, 1);
  lcd.print("NEXT>");
  delay(100);
void chooseWireLength(){
  wireLength = changeValue(wireLength);
  //clear LCD if required
  if(previousWireLength != wireLength){
    lcd.clear();
    previousWireLength = wireLength;
  //Display information on LCD
  lcd.print("LENGTH:" + (String)wireLength + "mm");
  displayNavigation();
void chooseWireQuantity(){
  wireQuantity = changeValue(wireQuantity);
  if(previousWireQuantity != wireQuantity){
    lcd.clear();
    previousWireQuantity = wireQuantity;
  lcd.print("QUANTITY:" + (String)wireQuantity);
void confirm(){
  lcd.print((String)wireLength + "mm x " + (String)wireQuantity + "pcs");
  lcd.setCursor(0, 1);
  lcd.print("<BACK");
  lcd.setCursor(10, 1);
  lcd.print("START>");
  delay(100);
void currentlyCutting(){
  lcd.print((String)0 + "/" + (String)wireQuantity);
  lcd.print("???s");
  int stepsToTake = (int)wireLength/mmPerStep;
  for(int i = 0; i < wireQuantity; i++){
    unsigned long timeForOneCycle = millis();
    digitalWrite(dirPin,HIGH);
    for(int x = 0; x < stepsToTake; x++) {
      digitalWrite(stepPin,HIGH);
      delayMicroseconds(500);
      digitalWrite(stepPin,LOW);
    lcd.print((String)(i+1) + "/" + (String)wireQuantity);
    snippers.write(closedAngle);
    delay(600);
    delay(600);
    unsigned long timeRemaining = ((millis() - timeForOneCycle)*(wireQuantity - (i+1)))/1000;
    lcd.print((String)timeRemaining + "s    ");
  wireLength = 0;
  wireQuantity = 0;
  state = 5;
void finishedCutting(){
  lcd.clear();
  lcd.print("CUTTING COMPLETE");
  lcd.print("NEXT>");
  delay(100);
int changeValue(int currentValue){
  if (!digitalRead(upButton)) {
    delay(100);
    currentValue += incrementSpeed;
  if (!digitalRead(downButton)) {
    if(currentValue - incrementSpeed >= 0){
      delay(100);
      currentValue -= incrementSpeed;
    else{
      currentValue = 0;
  if (!digitalRead(downButton) && !digitalRead(upButton)){
    incrementSpeed = 1;
  return currentValue;
void displayNavigation(){
  lcd.print("<BACK");
  lcd.print("NEXT>");
  delay(100);
What exactly do you mean by "keypad shield" ?
Can you tell us which LCD Keypad Shield you are using? The ones I have seen have the buttons mapped to analog A0 and returns a value based on the resistive splitting circuit.
ToddL1962:
LCD1602 LCD 1602 Liquid Crystal Display Keypad Shield Arduino
This should get you going.
