Need help about time countdown loop
Hello, I has some problem my Project. I used lcd 16x2 and arduino uno to do clock and time countdown.
I want to my time is start countdown again when it has finished for the first time and start with a value that I set it for the first time. But it has nothing when it finished countdown in the first time,
just 00 : 00 : 00. I try to set some variable for use it to do a loop but it’s not success. please help or guide me to do this, thank you sir.
็Here is my code
#include <LiquidCrystal.h>  //these are libraries that need to be downloaded from the Arduino Playground website (LiquidCrystal.h should come pre-downloaded with
#include <Time.h>               //the Arduino): http://playground.arduino.cc/Code/Time
#include <Wire.h>
int buttonPin1 = 10;
int buttonPin2 = 9;
int buttonPin3 = 8;
int buttonPin4 = 6 ;
int buttonPin5 = 13;
int j ;
int x, y, z,a ;
int tSeconds=10, tMinutes=0, hours=0;  //this line, along with another line in void timerFunction(), is where you can adjust the amount of time that is counted down in        //the timer function
int centiseconds=0, sSeconds=0, sMinutes=0;
int button1Counter = 0;  //this section initializes the button counters, which is how the buttons can have multiple operations within the same function - more info:
int button1State = 0;        // http://arduino.cc/en/Tutorial/ButtonStateChange
int lastButton1State = 0;
int button2Counter = 0;
int button2State = 0;
int lastButton2State = 0;
#include<Servo.h>
Servo myservo;
LiquidCrystal lcd(12,11,5,4,3,2);
  lcd.begin(16, 2);
  setTime(14,39,00,2,07,2015);  // this is how you can set the time for the clock function (hour,minute,second,day,month,year)
  pinMode(buttonPin1, INPUT_PULLUP);
  pinMode(buttonPin2, INPUT_PULLUP);
  pinMode(buttonPin3, INPUT_PULLUP);
   pinMode(buttonPin4, INPUT_PULLUP);
    pinMode(buttonPin5, INPUT_PULLUP);
  myservo.attach(7);
  myservo.write(0);
  button1State = digitalRead(buttonPin1);  //this section gives the "Mode" button the ability to have three seperate operations
  if(button1State != lastButton1State)
    if(button1State = HIGH)
      button1Counter++;
      button2Counter = 1;
      delay(200);
  lastButton1State = button1State;
  if(button1Counter > 3)
    button1Counter = 1;
  button2State = digitalRead(buttonPin2);  //similarly, this section allows the "Start/Stop" button the ability to have two seperate functions
  if(button2State != lastButton2State)
    if(button2State = HIGH)
      button2Counter++;
      delay (200);
  lastButton2State = button2State;
  if(button2Counter > 2)
    button2Counter = 1;
  switch(button1Counter)  //switch case is really nice for changing the clock between its three functions
    case 1:  //the clock defaults to clockFunction()
    lcd.clear();
    lcd.setCursor(2, 1);
    lcd.print(":");
    lcd.setCursor(5, 1);
    lcd.print(":");
    clockFunction();
    case 2:  //if the "Mode" button is pressed, clock switches to timerFunction()
    lcd.clear();
    lcd.print(":");
    lcd.print(":");
    timerFunction();
     case 3:
     //if "Mode" is pressed again, the clock switches once more to stopwatchFunction()
      lcd.clear();
 lcd.setCursor(0, 0);
 lcd.print("servo delay");
  lcd.setCursor(0, 1);
  lcd.print(j);
  delay(100);
    speedx();
void clockFunction()  //this is the time clock function; it works using the Time.h library
  printDigits(month());
  lcd.setCursor(2, 0);
  lcd.print("/");
  lcd.setCursor(3, 0);
  printDigits(day());
  lcd.setCursor(5, 0);
  lcd.print("/");
  lcd.setCursor(6, 0);
  lcd.print(year());
  lcd.print(hour());
  lcd.setCursor(3, 1);
  printDigits(minute());
  lcd.setCursor(6, 1);
  printDigits(second());
  delay(100);
void timerFunction()  //the timer function was made with the help of this post: http://pastebin.com/f57045830
  if(button2Counter == 2 )  //if "Start/Stop" is pressed, the timer counts down
    static unsigned long lastTick = 0;
    if (tSeconds > 0)
      if (millis() - lastTick >= 1000)
        lastTick = millis();
        tSeconds--;
        lcdOutput();
    if (tMinutes > 0)
     if (tSeconds <= 0)
        tMinutes--;
        tSeconds = 60;
    if (hours > 0)
      if (tMinutes <= 0)
        hours--;
        tMinutes = 60;
  else  //if "Start/Stop" is unpressed or pressed a second time, display the current time, but don't count down
    lcdOutput();
  if(hours == 00 && tMinutes == 00 && tSeconds == 00)  //when timer ends, the alarm goes off
      myservo.write(300);
     delay(j*100);
       myservo.write(0);
lcdOutput();
delay(600);
hours = x;
tMinutes = y ;
tSeconds = z ;
lcdOutput();
   button2Counter = 1;
    while(digitalRead(buttonPin3) == HIGH)  //the alarm will only go off until "Restart" is pressed
      lcd.print("00:00:00");
    if(digitalRead(buttonPin3) == LOW) //when "Restart" is pressed, the timer resets
    hours++;
    x = hours;
      lcdOutput();
 if(digitalRead(buttonPin5) == LOW) //
    tMinutes++;
   y = tMinutes;
      lcdOutput();
  if(digitalRead(buttonPin4) == LOW && button2Counter == 1)  //resets the timer when "Restart" button is pressed, as long as the timer is NOT running
    hours = 0 ;//this part also must be changed when the timer is altered, to match the initial time
    tMinutes = 0;
    tSeconds = 5;
    z = tSeconds;
  lcdOutput();
  if (hours > 12)
     delay(100);
    hours =  0 ;
void lcdOutput()  //this is just used to display the timer on the LCD
  printDigits(hours);
  printDigits(tMinutes);
  printDigits(tSeconds);
  delay(100);
void printDigits(int digits)  //this void function is really useful; it adds a "0" to the beginning of the number, so that 5 minutes is displayed as "00:05:00", rather than "00:5 :00"
  if(digits < 10)
    lcd.print("0");
    lcd.print(digits);
    lcd.print(digits);
void speedx()
  if(digitalRead(buttonPin3) == LOW )   //if the "Start/Stop" button is pressed, the time begins running
    delay(100);
    j++;
  if(digitalRead(buttonPin5) == LOW )  //if the "Restart" button is pressed, as long as the timer is paused, the stopwatch resets to 00:00.00
    j--;
    delay(100);
I’d start by fixing all the ='s that should be =='s
