Hi to all the people in the forum, please help me to how to use this Tinker Mosfet Module.
i am so lost about electronic.
I will attach the picture of what is my question.
Thank you.
Thank you.
You should post the schematics, or a link to the actual part / vendor page. The picture is not that helpful.
only this schematic about this Tinker Mosfet Module i can find.
Also this the link of the Arduino Online Store that were i bought this Tinker Mosfet Module.
http://store.arduino.cc/it/index.php?main_page=product_info&cPath=16&products_id=108
Thanks
That dwg is incomplete. There's an IC onboard not shown.
The Arduino.cc link is no help in that regard either. But they state that it has an IRF520 (not a "logic-level" MOSFET) and that its input (on the 3pin connector, I presume) gets connected to an output on something called a "TinketKit shield".
Maybe the "TinkerKit shield" gets you the proper VGS(on) or is it via that smd IC?
I just email Davide of Arduino today to ask if they have the complete schematics of this product. Or i need to buy this Tinkerkit Shield to run this thing. i will post here what ever info i getting from them.
By the way thanks for posting a help i highly appreciated.
I just solve my problem about this tinkerkit mosfet Module.....
Thanks to all that make a reply on my post... thanks a lot
dear rexcobey1 ,
I know it is long ago now but I just saw your post and I have the same problem. could you explain the solution or help me???
Have you by chance seen this http://www.tinkerkit.com/mosfet/
yes, thank you but there is no schematic or similar :~
in detail i need to connect the output of the tinker MOS modul to a digital input on my ARDUINO board. but I do not know how to handle this 3 output pins of the MOS modul. I do not use a tinker shield
No but it explained how it works. There is an onboard ic that handles the voltage step up for you. Hook up your power supply and motor or whatever then the 3pin part hooks to the arduino. Not exactly sure how by id start by looking at the board and the data sheet to the ic with a lil time and the old multi meter itl be easy to figure out. I bet that the 3pins are 5v gnd and signal but I have no idea what order.
