Need help/advice in 2x16 LCD menu
I have problem making an iterative lcd menu for my board contains of few sensor, 4 buttons, and a a lcd.
button 1 - for changing mode (this is easy)
button2-3 - for moving an arrow to change different values, such as setting time and alarm. (also this 2 buttons can be used to change values.)
button4 - is the okay/select button
the problem of my program is, I have no idea how to make it work. It’s easy to change from one screen to one screen, but I have no idea how to achieve the functions mentioned above.
any tips, advices?
Mode 1 - mode4
subMode - sub menu for mode 1, for setting time and alarm, and change temp reading from F/C
Full code
#include <LiquidCrystal.h>
LiquidCrystal lcd(2,3,4,5,6,7);
byte timeIcon[8] = {
	0b11111,
	0b10001,
	0b01010,
	0b00100,
	0b00100,
	0b01010,
	0b10001,
	0b11111};
byte tempIcon[8] = {
        0b00100,
	0b01011,
	0b01010,
	0b01011,
	0b01110,
	0b11111,
	0b11111,
	0b01110};
byte batteryIcon[8] = {
	0b01110,
	0b11011,
	0b10001,
	0b11111,
	0b10001,
	0b11111,
	0b11111,
	0b11111};
byte lightIcon[8] = {
        0b00100,
	0b10101,
	0b01110,
	0b11011,
	0b01110,
	0b10101,
	0b00100,
	0b00000};
byte arrowupIcon[8] = {
	0b00100,
	0b00100,
	0b01110,
	0b11111,
	0b00100,
	0b01110,
	0b01110,
	0b01010};
byte buttonIcon[8] = {
	0b00000,
	0b00000,
	0b00000,
	0b11111,
	0b10001,
	0b10101,
	0b10001,
	0b11111};
byte alarmIcon[8] = {
        0b00000,
	0b00100,
	0b01110,
	0b01110,
	0b01110,
	0b11111,
	0b00100,
	0b00000
int timeI=0;
int tempI=1;
int batteryI=2;
int lightI=3;
int arrowupI=4;
int buttonI=5;
int alarmI=6;
#define tempI char(0x01)
#define batteryI char(0x02)
#define lightI char(0x03)
#define arrowupI char(0x04)
#define buttonI char(0x05)
#define alarmI char(0x06)
#define timeI char(0x07)
// Pinouts =====>
int buttonPin[6]={0,A4,A3,A2,A1}; // Button 1-4
int ledPin[7]={0,8,9,10,11,12};   // Led 1-5
int shuntPin=A5;
int tempPin=A6;
int lightPin=A7;
int beeperPin=A0;
// TimeValues  ======>
int DAY=0; //Day
int HR=0; //hour
int MIN=0; //minute
int SEC=0; //Second
int lastSec=0;
unsigned long previousSec=0;
int bdHR=0; // hour --- timer for battery discharge mode
int bdMIN=0; //minute
int bdSEC=0; //Second
int cdDAY=0; // days --- countdown timer for battery discharge mode
int cdHR=0; // hour
int cdMIN=0; //minute
int cdSEC=0; //Second
//   ======> sensorValues
int shuntMa=0;
int shuntMah=0;
unsigned long shuntMatotal=0;
int tempF=0;
int tempC=0;
int lightLevel=0;
//   ======> menus
int mode=1;
int lastMode=1;
int subMode=0;
int subsubMode=0;
int arrowLoc[16]={1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
//   ======> button
int buttonState[5]={0,0,0,0,0};
int lastButtonState[5]={0,1,1,1,1};
int buttonPress[5]={0,0,0,0,0};
int lastButtonPress[5]={0,0,0,0,0};
the rest of the code
  //===5 RED LEDs ===
for(int x=1; x<7; x++){
  pinMode(ledPin[x],OUTPUT);
  //===4 Black buttons ===
for(int x=1; x<5; x++){
  pinMode(buttonPin[x], INPUT_PULLUP);
  //===Sensors ===
  pinMode(shuntPin, INPUT);// shunt voltage
  pinMode(tempPin, INPUT);// Temp. Sensor
  pinMode(lightPin, INPUT);// Light resistor
  pinMode(beeperPin, OUTPUT); // Beeper
  //===LCD SETUP ===
  lcd.begin(16,2);
  lcd.createChar(7, timeIcon);
  lcd.createChar(1, tempIcon);
  lcd.createChar(2, batteryIcon);
  lcd.createChar(3, lightIcon);
  lcd.createChar(4, arrowupIcon);
  lcd.createChar(5, buttonIcon);
  lcd.createChar(6, alarmIcon);
//------------------------------------------------------------------>>LCD
if(mode!=lastMode){
  lastMode=mode;
  if(subMode>=1){
  subMode=0;
  mode--;
if(mode==1){
   if(subMode==0){
  char x [16];
  sprintf(x, "%c%02d:%02d:%02d:%02d %02d%c", timeI,DAY,HR,MIN,SEC,tempC,tempI);
  lcdPrintText(0,0,x);
  char y [16];
  sprintf(y, "%cm %c- %c+ %cx     ", buttonI,  buttonI, buttonI, buttonI );
  lcdPrintText(0,1,y);
  if(subMode==1){
  char x [16];
  if(subsubMode==1){
    char y [16];
    sprintf(y, "%c Set Time      ", arrowupI );
  if(subsubMode==2){
    char y [16];
    sprintf(y, "  %c          Day", arrowupI );
  if(subsubMode==3){
    char y [16];
    sprintf(y, "     %c       Hour", arrowupI );
  if(subsubMode==4){
    char y [16];
    sprintf(y, "        %c   Minute", arrowupI );
  if(subsubMode==5){
    char y [16];
    sprintf(y, "     (C/F)        %c", arrowupI );
  if(subsubMode==5){
    char y [16];
  if(subsubMode==5) subsubMode==0;
  if(subMode==2){
  char x [16];
  if(arrowLoc[0]==1){
  char y [16];
  sprintf(y, "%c Set Alarm 1   ", arrowupI );
  if(subMode==3){
  char x [16];
  if(arrowLoc[0]==1){
  char y [16];
  sprintf(y, "%c Set Alarm 2   ", arrowupI );
  if(subMode==4)  subMode=0;
  if(subMode==-1)  subMode=4;
if(mode==2){
  char x [16];
  sprintf(x, "%c%02d:%02d:%02d%c% 02d %c%c", batteryI,bdHR,bdMIN,bdSEC,batteryI,tempC,alarmI,lightI);
  char y [16];
  sprintf(y, "%04d:mAh %04d:mA", shuntMah,shuntMa );
if(mode==3){
  char x [16];
  sprintf(x, "%c%02d:%02d:%02d:%02d%c %c%c% ", timeI, cdDAY,cdHR,cdMIN,cdSEC,timeI, alarmI,lightI);
  char y [16];
  lcdPrintText(0,1,"Day Hr Min TIMER");
if(mode==4){
  char x [16];;
  sprintf(x,"%c Pigs Arduino %c",arrowupI,arrowupI);
  char y [16];
  lcdPrintText(0,1," Mini Os V.1.00 ");
if(mode==5)mode=1;
  char tempRead[5];
  sprintf(tempRead, "%02d %02d", lightLevel,tempC);
  lcd.setCursor(10, 0);
  lcd.print(tempRead);
  char shuntRead[14];
  sprintf(shuntRead,"%04dmA %04dMah",shuntMa, shuntMah);
   lcd.setCursor(1, 1);
  lcd.print(shuntRead);
//------------------------------------------------------------------<<LCD
//------------------------------------------------------------------>>Time
unsigned long currentSec=millis();
if(currentSec-previousSec>1000) {
SEC++;
previousSec=currentSec;
if(shuntMa>1){shuntMatotal=shuntMatotal+shuntMa;}
if(SEC==60){SEC=0; MIN++;}
if(MIN==60){MIN=0; HR++;}
if(HR==24) {HR=0;DAY++;}
//------------------------------------------------------------------<<Time
//------------------------------------------------------------------>> Sensors
// 8% difference from meter to arduino reading
int shuntVal= analogRead(shuntPin);
shuntMa=shuntVal*(5.0/1023.0*1000.0*0.92);              //shuntMa
shuntMah=shuntMatotal/3600;                            //shuntMah
//(21%) tempVal*0.21=F degree/ (F-32)X5/9=C degree
int tempVal= analogRead(tempPin);
tempF=tempVal*0.21;
tempF= constrain (tempF, 0,99);                      // tempF
tempC=((tempVal*0.21)-32)*5/9;                       // tempC
//darkest 50-1010 lightest
int lightVal= analogRead(lightPin);
lightVal=map(lightVal, 50,1010,0,99);
lightLevel=constrain (lightVal, 0, 99);             // lightLevel
//------------------------------------------------------------------<< Sensors
//------------------------------------------------------------------>> Buttons
if(buttonPress[1]!=lastButtonPress[1]){
  if(buttonPress[1]==HIGH){
    mode++;
lastButtonPress[1]=buttonPress[1];
if(buttonPress[2]!=lastButtonPress[2]){
  if(buttonPress[2]==HIGH){
    subMode--;
lastButtonPress[2]=buttonPress[2];
if(buttonPress[3]!=lastButtonPress[3]){
  if(buttonPress[3]==HIGH){
    subMode++;
lastButtonPress[3]=buttonPress[3];
if(buttonPress[4]!=lastButtonPress[4]){
  if(buttonPress[4]==HIGH){
    subsubMode++;
lastButtonPress[4]=buttonPress[4];
buttonState[x]=digitalRead(buttonPin[x]);
if(buttonState[x]!=lastButtonState[x]){
  lastButtonState[x]=buttonState[x];
  if(buttonState[x]==LOW)buttonPress[x]=1;
  else buttonPress[x]=0;
//------------------------------------------------------------------<< Buttons
//========================================================================================================>>FUNCTIONS
int bPress(int bPin){                                                             //button function
void lcdPrintText (int x, int y, char* text){
  lcd.setCursor(x,y);
  lcd.print(text);
