Need help Arduino Guessing number
Hi, I made a code for guess a random number but there is a pb...
When I type a number like 2, there is a 0 who will be type automaticaly after my number and i don't know why. I also tryied to add 2 leds for if the random number is higher or lower.( But i can't turn off these leds.)
There is the code :
int randNumber;
int player1_number;
int LedR = 2;
int LedB = 3;
randomSeed(analogRead(0));
Serial.println("");
Serial.println("
Serial.println("
Numerical guessing game ");
Serial.println("
Serial.println("
Serial.print("Devinez le nombre aléatoire:");
randNumber = random(0, 10);
while(Serial.read()>= 0){}
while (Serial.available() > 0 )  {
  delay( 10 );
  player1_number = Serial.parseInt();
  Serial.println ( player1_number );
  if(player1_number==randNumber){
  Serial.println("Bravo !");
  digitalWrite(LedR,HIGH);
  digitalWrite(LedB,HIGH);
  else if( player1_number < randNumber){
   Serial.println("C'est plus grand");
  else if( player1_number > randNumber){
   Serial.println("C'est plus petit");
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
If you get errors when compiling please copy them from the IDE using the "Copy error messages" button and paste the clipboard here in code tags
If you have the Line ending set to anything other than "No line ending" in the Serial monitor then you will have this problem because of the extra line ending characters
What is stopping you ?
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Thx all is good now, i just forgot how to switch off lights but i remember it xD
What is the intention with this line of code in setup: while(Serial.read()>= 0){}
Also you do not set the LED pins to be outputs, this will invert the way you can get a a weak light from the LED as you turn the pull up resistor on or off.
