Hello,
I want to controll WS2812 Stripes via Artnet.
I bought a Arduino Mega and W5100 Ethernet shield for it and i had no problem to controll the stripes via the adafruit strandtest example or to make a Webserver. But when i load the code for artnettows2812 first of all the test is running and my stripe lights up in (R, G, B) but i can't controll it via dot2. I have the same ip exept the last number and also tried ethernet.init(10) ; wicht i needed to make the webserver. (I pluged the shield with a rj 45 cabel in my pc)
Code:
This example will receive multiple universes via Artnet and control a strip of ws2811 leds via
Adafruit's NeoPixel library: https://github.com/adafruit/Adafruit_NeoPixel
This example may be copied under the terms of the MIT license, see the LICENSE file for details
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
// Neopixel settings
const int numLeds = 150; // change for your setup
const int numberOfChannels = numLeds * 3; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = 13;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_GRB + NEO_KHZ800);
// Artnet settings
Artnet artnet;
const int startUniverse = 1; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// Change ip and mac address for your setup
byte ip[] = {2, 254, 170, 254};
byte mac[] = {0x08, 0xE9, 0xE5, 0x00, 0x69, 0xEC}; // make sure this is different than any other mac address in your network
//Serial.begin(115200);
artnet.begin(mac, ip);
leds.begin();
initTest();
// this will be called for each packet received
artnet.setArtDmxCallback(onDmxFrame);
// we call the read function inside the loop
artnet.read();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
sendFrame = 1;
// set brightness of the whole strip
if (universe == 15)
leds.setBrightness(data[0]);
leds.show();
// Store which universe has got in
if ((universe - startUniverse) < maxUniverses)
universesReceived[universe - startUniverse] = 1;
for (int i = 0 ; i < maxUniverses ; i++)
if (universesReceived[i] == 0)
//Serial.println("Broke");
sendFrame = 0;
// read universe and put into the right part of the display buffer
for (int i = 0; i < length / 3; i++)
int led = i + (universe - startUniverse) * (previousDataLength / 3);
if (led < numLeds)
leds.setPixelColor(led, data[i * 3], data[i * 3 + 1], data[i * 3 + 2]);
previousDataLength = length;
if (sendFrame)
leds.show();
// Reset universeReceived to 0
memset(universesReceived, 0, maxUniverses);
void initTest()
for (int i = 0 ; i < numLeds ; i++)
leds.setPixelColor(i, 127, 0, 0);
leds.show();
leds.setPixelColor(i, 0, 127, 0);
leds.show();
leds.setPixelColor(i, 0, 0, 127);
leds.show();
leds.setPixelColor(i, 0, 0, 0);
leds.show();
