Need help ASAP: MKR WAN 1300 not sending proper data to TTN
Hello,
I have been having a problem with trying to send data to the LoRa network using the MKR WAN 1300. The code is:
#include <MKRWAN.h>
#include "arduino_secrets.h"
LoRaModem modem;
bool pump_running = false;
int water_level = 0;
const int empty_level = 0;
const int full_level = 5;
  while (!Serial);
  if (!modem.begin(EU868)){
    Serial.println("Failed to start module");
    while (1){}
  Serial.print("Your device EUI is: ");
  Serial.println(modem.deviceEUI());
  int connected = modem.joinOTAA(appEui, appKey);
  if (!connected){
    Serial.println("Something went wrong! Retry");
    while (1){}
  modem.minPollInterval(60);
  Serial.println("Successfully joined the network!");
  pinMode(13,OUTPUT); //Set pin 13 as OUTPUT pin, to send signal to relay
  adjust_water_level();
  send_level();
  for (int i =0;i<10;i++){ /*10 * 1 second delay*/
    check_downlink_messages();
void adjust_water_level(){
  if (pump_running){
    if (water_level < full_level){ /*Can't be overfilled*/
       water_level += 1; /*Water level rises*/
  else {
    if (water_level > empty_level){ /*Can't be less than empty*/
      water_level -= 1; /*Water level drops*/
  return;
void send_level(){
  int err;
  //modem.setPort(4);
  Serial.print("Sending water level: ");
  Serial.println(water_level);
  modem.beginPacket();
  modem.write(water_level);
  err = modem.endPacket(true);
  if (err > 0) {
    Serial.println("Message sent correctly!");
  else {
    Serial.println("Error sending message :(");
  return;
void check_downlink_messages(){
  if (!modem.available()) { /*If there was no message, get out of function*/
    Serial.println("No downlink message received at this time.");
    return;
  else { /*If there is a message*/
    Serial.print("Message Received: ");
    if (modem.read()!= 0){ /*The first byte is non-zero*/
      Serial.println("Starting the pump");
      pump_running = true;
      digitalWrite(13,HIGH); //if pump is not running, send HIGH value to relay
    else{
      Serial.println("Stopping the pump");
      digitalWrite(13,LOW); //if pump is not running, send LOW value to relay
  return;
The message gets uploaded to the TTN, however I get Payload: {ledState: null} 02 00 00 00 when I send an integer with a value of 2 to the network using the modem.write() function. I did this just for testing purposes. Later I used a uplink simulation to see if perhaps I used the wrong payload formatting, however that is not the case. I should be getting a Payload similar to the simulation, that being Payload: {port: 4, water_level=2).
Note that I am completely new to both arduino and lora, and this is a simple school project with a deadline, so I would appreciate if someone could help me out ASAP. After TTN v3 came out I am not sure if any older online resources are helpful anymore and I desperately need help.
It is quite hard to read code like this. Could you use code tags and proper indentation?
Hello
I guess the sketch has a delay() function issue too.
Sorry for the inconvenience, I am also new to this forum. The post is updated and is using code tags.
Hi, thank you for the reply. Which delay() functions should I edit/delete?
Ask yourself which one are needed to reach the desired funktionality of the sketch.
Line 34:   for (int i =0;i<10;i++){ /*10 * 1 second delay*/
	Line 36:     delay(1000);
	Line 67:   delay(1000 * 60);
	Line 89:   delay(400);
Yes, I can see it too now, and it looks like this is the biggest offender:
It looks like the OP is trying to invoke send_level() once a minute, but this approach just freezes the uC minute after minute so, @clyro, try to implement a non-blocking timed event based on the millis counter.
I have just tested the newly updated code where I removed some of the delay() functions, however I was still not able to fix my main issue. The decoded_payload still only contains ledState, while I am sending an int with the modem.write() function.
Perhaps my Uplink payload formatter code is not correct.
Be aware that your questions are not about LoRa as such, which is a low level radio protocol, but about an application called TTN\LoRaWAN that just happens to use LoRa in the background.
There is a forum which specifically supports the TTN application you are using;
