Need help badly with civi air patrol project for my son! Please
Hi all my son and I are building a near space balloon with his cap unit one of the trackers will be a sim900 gsm unit I have already got to send a text through the arduino test but I need it to work with this GPS unit and also send a text every 10 min with the gps coordinates without the serial screen activating it I am not sure why I am getting so many compile errors. Pretty new to this and advice what be very much appreciate here is the code followed by the compile errors
#include <SoftwareSerial.h>
#include "SIM900.h"
#include <TinyGPS.h>
#include "sms.h"
SMSGSM sms;
TinyGPS gps;
SoftwareSerial ss(2, 3);
SoftwareSerial SIM900(8, 7);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_str(const char *str, int len);
String strL, strN, poss, tareq, textForSMS;
char charL[10], charN[10], text[400];
int o = 1;
boolean started = false;
  ss.begin(9600);
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  while (o < 4) {
    gps.f_get_position(&flat, &flon, &age);
    textForSMS = "tareq Home"; //testing gps from here
    Serial.println(textForSMS);
    Serial.print("longitude: ");
    print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
    Serial.println("");
    Serial.print("latitude : ");
    print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
    smartdelay(1000);
    Serial.println(""); //till here
    o++;
  Serial.println("nil"); //to check whether 'if' works
  dtostrf(flat, 8, 6, charL);
  for (int i = 0; i < 10; i++)
    strL += charL;
  dtostrf(flon, 8, 6, charN);
    strN += charN;
  tareq = "tareq Home Location";
  tareq = tareq + "\nlongitude: " + strN + "\nlatitude :  " + strL;
  poss = tareq;
  poss.toCharArray(text, 400);
  gsm.begin(9600);
  Serial.println(text);
  if (sms.SendSMS("+8801839443686", text))
    Serial.println("\nSMS sent OK.");
    Serial.println("\nError sending SMS.");
  do {} while (1);
  //o++;
  unsigned long start = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (millis() - start < ms);
  if (val == invalid)
    while (len-- > 1)
      Serial.print('*');
    Serial.print(' ');
    Serial.print(val, prec);
    int vi = abs( val);
    int flen = prec + (val < 0.0 ? 2 : 1); // . and -
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i = flen; i < len; ++i)
      Serial.print(' ');
  smartdelay(0);
  int slen = strlen(str);
  for (int i = 0; i < len; ++i)
    Serial.print(i < slen ? str : ' ');
  smartdelay(0);
These are the compile errors and a picture will be attached
Arduino: 1.8.1 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:17:0:
C:\Program Files\Arduino\libraries\GSM\src/GSM.h:56:13: error: prototype for 'int GSM3ShieldV1AccessProvider::begin(long int)' does not match any in class 'GSM3ShieldV1AccessProvider'
 #define GSM GSM3ShieldV1AccessProvider
C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:43:5: note: in expansion of macro 'GSM'
 int GSM::begin(long baud_rate)
In file included from C:\Program Files\Arduino\libraries\GSM\src/GSM.h:45:0,
C:\Program Files\Arduino\libraries\GSM\src/GSM3ShieldV1AccessProvider.h:80:24: error: candidate is: virtual GSM3_NetworkStatus_t GSM3ShieldV1AccessProvider::begin(char*, bool, bool)
   GSM3_NetworkStatus_t begin(char* pin=0,bool restart=true, bool synchronous=true);
C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:315:21: error: variable or field 'InitParam' declared void
 void GSM::InitParam(byte group)
C:\Program Files\Arduino\libraries\GSM_GPRS_GPS_Shield_GSMSHIELD\GSM.cpp:315:21: error: 'byte' was not declared in this scope
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Oh and its attached to a uno gps NEO-6m
When your code requires a library that's not included with the Arduino IDE please always post a link(using the chain link icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger(Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
When you are listening to the SIM900, you won't be listening to the GPS.
When you are listening to the GPS, you won't be listening to the SIM900.
If you are fine with that, carry on.
Your code appears to be trying to compile the files for the official GSM shield, which you are not using. Why?
