Need help: Battery power supply for CNC Shield with two Nema17
Hi, I'm an arduino beginner and I'm building a telescope mount with 2 axes driven by two NEMA 17 stepper motors with a max. power of 2 Amps each. I connected them with a CNC Shield and I am using the A4988 Drivers. - As a power supply I use the battery packs of my drilling machine, because I want to be mobile with my telescope. It has 18 Volt and 4Ah. I adjusted the Vref to 1.2Volts (formula is: Imax * 8 * 0.1 = 2 * 8 * 0.1 = 1.6V as optimum - 1.2V was the max. Vref of the drivers).
After my first trys the steppers made weird fwd+bwd moves and at the end I burned my drivers.
I re-ordered a CNC-Shield, now with DRV8825 Drivers.
I need some help from experienced developers, if my setup is ok, and what I have done wrong.
You need to know how much current those drivers handle. I've used A4988, with heatsinks and fan cooling to operate them at some 1.5 Amps I think it was.
Just naked they would burn.
The coil current limit must be properly set before the motor is used. That means no guessing. Get the coil current limit from the motor data sheet or data plate. Use the instructions to set vref carefully.
Setting coil current:
https://zerotohero.engineering/setting-vref-for-drv8825-and-a4988-motor-drivers/
You do not have to set Vref (coil current limit) at max. Set it high enough that the the motors perform adequately without missing steps.
Stepper basics:
Blockquote
The DRV8825 drivers are good for 1.5A with no heat sink and 2.2A with heatsinks and active (fan) cooling. What are the specs of your steppers? Please post a data sheet for the motor.
Thank you so much for your replies. This helps a lot.
One question is still open for me, where I can't find any information about:
Does my power supply (The battery of my drilling machine) fit to my setup?
It has 18Volts and 4Ah.
I'm using 2 Nema 17 with this specification 17HE19-2004S.
The 18 volts are good for the DRV8825 as they are good up to 45 volts. Don't connect 18 volts to your Arduino.
