Just to let everyone know, my electronics background is nearly 0. I just like to learn to make my own stuff.
Following this topic, I want to battery power a strip of 144 SK9822 leds.
Need Help Powering a WS2812B 144 Led Strip0
I'm going to use this for video work so I choose the SK9822 because it doesn't have the flickering of WS2812B leds.
This is because the SK9822 use a programmable constant current circuit for brightness control and PWM of 4.7 kHz for colour control (vs 430 Hz of WS2812).
I did some tests of slow motion 60fps->24fps and 30fps->24fps and I can't see any kind of flickering from the SK9822, at any brightness level!
The only thing I don't like about the SK9822 is the white color. Does anybody knows of a led strip with 144 leds per meter and also has white leds, beside rgb (of course with programmable constant current circuit for brightness control and high PWM frecuency)?
I'm thinking of using:
- 2p2s 6000 mAh 7.4v formed by 4 Samsung Q30 3.7v 3000 mA 15A with individual protection PCM on each battery:
- 2 Turnigy 5v 5A (8-26v) SBEC
- SP108E wifi controller (or Adruino Nano with potentiometer for rgb?)
- common 7.4v DC charger
And this is the diagram (I'm no electronic expert, so this is all I can draw )
I want to make sure I'm wiring everything in the right order and batteries are charging safely without going on fire.
