Need help building GPS library
Hi!
I am trying to build a library for my gps module and am having a hard time implementing the SoftwareSerial library within the private class. How might I go about this?
Here is my header file:
  #include "uBlox.h"
#include "Arduino.h"
#include "SoftwareSerial.h"
uBlox::uBlox(int rx, int tx) {
  SoftwareSerial gps(rx, tx);//initialize the serial connection  (This needs to be as uBlox private so that future functions can access it.)
uBlox::~uBlox() {  } //Why do I need this??
void configure() {
And the C++ file.
#include "uBlox.h"
void configure() {
How could I assign the pins when the SoftwareSerial instance is outside of the class?
You have to define the instance of SoftwareSerial at the same time as your constructor is created:
uBlox::uBlox(int rx, int tx) : gps(rx, tx)
after declaring that gps is an instance of SoftwareSerial in the header file:
SoftwareSerial gps;
Got it! Thanks for you help!
I have a feeling that something else may come up later, so for now, I won't mark it as solved :slight_smile:
