Need help changing code to change display orientation
Hello
I am programming a 5x7 LED matrix. I found this code
http://mvartan.com/2013/03/08/arduino-5x7-matrix-display-controller-hdsp-4403/
the problem is the orientation of the display in the code. I’m trying to figure how to make the letters go this way
7
0 0 0 0 0 0 0
0 0 0 0 0 0 0
0 0 0 0 0 0 0 5
0 0 0 0 0 0 0
0 0 0 0 0 0 0
instead of this way
5
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0 7
0 0 0 0 0
0 0 0 0 0
0 0 0 0 0
what happens when I upload the code is the display starts the letters on the left side like this 'A" for example
7
1 1 0 0 0 1 1
0 1 0 0 0 1 0
1 1 0 0 0 1 1 5
0 1 0 0 0 1 0
0 1 0 0 0 1 0
you’ll notice how the display restarts at the fifth row. Also the letter is going below the display. from this I know that the orientation is the wrong way. the code makes it 7x5 instead of 5x7.
any help would be appreciated
thanks
Post your code. You can make a function that rotates the bytes 90* before showing them. I made a function that does just that but it is made to work with 8x8 displays. I don't think it will work on a 5x7.
I have linked the code above
you can also find it here
There is a way to do it, but that would require rewriting the code.
Here is my function, if your interested.
byte* rotate90deg(byte data[]){ //private func
  for(int c=0;c<8;c++)
    for(int r=0;r<8;r++)
      tmpAry[r] <<= 1;
      tmpAry[r] |= bitRead(data[c],r);
      //Serial.println(tmpAry[r],BIN);
    //Serial.println();
  return tmpAry;
I don’t have a 5*7 display to do any tests, so I can only go by the serial monitor. Sorry.
This is my method to rotate the array 0, 90, 180 and 270 degrees.
byte flip(byte ary)//private func
  static const byte table[16] = {
    0x0, 0x8, 0x4, 0xC,
    0x2, 0xA, 0x6, 0xE,
    0x1, 0x9, 0x5, 0xD,
    0x3, 0xB, 0x7, 0xF
  byte h = table[(ary & 0xf0) >> 4];
  //Serial.println(h,HEX);
  byte l = table[ary & 0x0f] << 4;
  //Serial.println(l,HEX);
  return (l | h );
byte RotateData(byte data[], int rot){
  int cnt=0;
  //Serial.println(data,HEX);
  switch(rot)
  case 0:
    display(data,0);
  case 90:
    display(rotate90deg(data),0); // 90
  case 180:
    display(data,1); // 180
  case 270:
    display(rotate90deg(data),1); // 270
void display(byte *Ary, boolean Inv){
  for(byte k = 0; k < 8; k++)
    if(Inv)
      shiftOut(data,clock,MSBFIRST,8-k);
      shiftOut(data,clock,MSBFIRST, flip(Ary[k]));
      shiftOut(data,clock,MSBFIRST,k+(byte)1);
      shiftOut(data,clock,MSBFIRST, Ary[k]);
    digitalWrite(load,LOW);
    digitalWrite(load,HIGH);
I found code online for my 5x7 display but the letters are going the wrong way for example in this video that was on the same page as the code the display is vertical and the letters are going horizontally.
My display is vertical like the on in the video but my text is also scrolling vertically. Also the first 2 rows are always on .
here is the original code
#include <TimerOne.h>
#define A { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define B { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define C { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define D { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define E { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define f { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define G { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,1,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define H { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define I { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define J { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define K { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define L { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,0,0,0}, \
  {1,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define M { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define N { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define O { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define P { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,1,0,1,0}, \
  {0,0,0,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Q { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define R { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,0,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define S { \
  {0,0,0,0,0,0,0}, \
  {1,0,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,1,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define T { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define U { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define V { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {1,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define W { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define X { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,1,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Y { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,1,1,1,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Z { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,0,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define DASH { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define SPACE { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define DOT { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define COLS 5
#define ROWS 7
#define PINS 13
#define MATRIX1 { \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1} \
#define MATRIX2 { \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
byte col = 0;
byte leds[COLS][ROWS];
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[PINS]= {-1, 2, 9, 3, 11, 12, 13, 5, 6, 10, 4, 8, 7};
// col[xx] of leds = pin yy on led matrix
int cols[COLS] = {pins[1], pins[3], pins[10], pins[7], pins[8]};
// row[xx] of leds = pin yy on led matrix
int rows[ROWS] = {pins[12], pins[11], pins[2], pins[9], pins[4], pins[5], pins[6]};
const int numPatterns = 7;
byte patterns[numPatterns][COLS][ROWS] = {MATRIX2, S, T, E, A, K, MATRIX1};
int pattern = 0;
  //Serial.begin(9600);
  // sets the pins as output
  for (int i = 0; i < PINS; i++) {
    pinMode(pins[i], OUTPUT);
  // set up cols
  for (int i = 1; i <= COLS; i++) {
    digitalWrite(cols[i - 1], 0);
  //  and rows
  for (int i = 1; i <= ROWS; i++) {
    digitalWrite(rows[i - 1], 1);
  clearLeds();
  Timer1.initialize(2000);         // initialize timer1, and set a 1/2 second period
  Timer1.attachInterrupt(display);  // attaches display() as a timer overflow interrupt
  setPattern(pattern);
 pattern = ++pattern % numPatterns;
 slidePattern(pattern, 180);
// Interrupt routine
void display() {
  digitalWrite(cols[col], 0);  // Turn whole previous column off
  col++;
  if (col == 5) {
    col = 0;
  for (int row = 0; row < 7; row++) {
    if (leds[col][(ROWS - 1) - row] == 1) {
      digitalWrite(rows[row], 0);  // Turn on this led
    else {
      digitalWrite(rows[row], 1); // Turn off this led
   // delay(10);
  digitalWrite(cols[col], 1); // Turn whole column on at once (for equal lighting times)
void slidePattern(int pattern, int del) {
  for (int l = 0; l < COLS; l++) {
    for (int i = 0; i < (COLS - 1); i++) {
      for (int j = 0; j < ROWS; j++) {
        leds[i][j] = leds[i + 1][j];
      leds[4][j] = patterns[pattern][0 + l][j];
    delay(del);
void clearLeds() {
  // Clear display array
  for (int i = 0; i < COLS; i++) {
      leds[i][j] = 0;
void setPattern(int pattern) {
      leds[i][j] = patterns[pattern][i][j];
thanks
#define A { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define B { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define C { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define D { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define E { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define f { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define G { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,1,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define H { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define I { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define J { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define K { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define L { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,0,0,0}, \
  {1,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define M { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define N { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define O { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define P { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,1,0,1,0}, \
  {0,0,0,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Q { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define R { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,0,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define S { \
  {0,0,0,0,0,0,0}, \
  {1,0,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,1,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define T { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define U { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define V { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {1,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define W { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define X { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,1,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Y { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,1,1,1,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Z { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,0,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define DASH { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define SPACE { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define DOT { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define COLS 5
#define ROWS 7
#define PINS 13
#define MATRIX1 { \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1} \
#define MATRIX2 { \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
byte col = 0;
int pattern = 0;
  // set up cols
  //  and rows
  clearLeds();
void display() {
  col++;
  if (col == 5) {
    col = 0;
    else {
   // delay(10);
    delay(del);
void clearLeds() {
      leds[i][j] = 0;
thanks
Try this function. I don’t have a 5x7 display, so I used the serial monitor. ALSO, you will need to fix your letter arrays. You must make all the letter be centered in the array.
Letters that are NOT centered and must be fixed.
A, E, F, H, I, K, L, O, R, S, T, V
[b]// Put this in setup() function.[/b]
for(byte p = 0; p < 5; p++)
  RotatePattern(2);
[b]//Put this at the bottom of sketch.[/b]
void RotatePattern(int pattern)  // This function will rotate everything in the center of the 5x7 letter arrays, within your pattern.
  for (int i = 0; i < 5; i++) //col
    for (int j = 1; j < 6; j++) //row You want to be in a 5x5 box,
      //Serial.print(patterns[pattern][i][j]);
      leds[5-j][i] = patterns[pattern][i][j]; // this will rotate the letter.
    //Serial.println();
//  Serial.println();
//   for (int i = 0; i < 5; i++) //col
//    for (int j = 1; j < 6; j++) //row
//      Serial.print(leds[i][j]);
Thanks for replying
I used your function as you stated in the comments next to the code, but it has made no difference. the letters are still going the wrong way and the 6th and 7th rows are still on all the time. heres the new code with your function added in.
Also the reason that those letters are not centered is because that is they only way they are legible. if I center them the top will be cut off.
Im using the TC07-11EWA display
http://www.mouser.com/ds/2/216/TC07-11EWA-83196.pdf
#define A { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define B { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define C { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define D { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define E { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define f { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define G { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,1,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define H { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define I { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define J { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define K { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define L { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,0,0,0}, \
  {1,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define M { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define N { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define O { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define P { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,1,0,1,0}, \
  {0,0,0,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Q { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define R { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,0,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define S { \
  {0,0,0,0,0,0,0}, \
  {1,0,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,1,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define T { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define U { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define V { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {1,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define W { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define X { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,1,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Y { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,1,1,1,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Z { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,0,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define DASH { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define SPACE { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define DOT { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define COLS 5
#define ROWS 7
#define PINS 13
#define MATRIX1 { \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1} \
#define MATRIX2 { \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
byte col = 0;
int pattern = 0;
  RotatePattern(2);
  // set up cols
  //  and rows
  clearLeds();
void display() {
  col++;
  if (col == 5) {
    col = 0;
    else {
   // delay(10);
    delay(del);
void clearLeds() {
      leds[i][j] = 0;
In my function, in your setup(), change the 2 to p, and add a delay time.
It might be doing what you want, but I didn’t add a delay, so change the function to this.
void RotatePattern(int pattern, int del)
    //Serial.println();
    delay(del);
You also need to comment out this line “setPattern(pattern);” and move what I gave you after it.
That doesn’t sound good to me. If your telling it to show something in a 5x7 grid, then you should see everything and not have anything cut off.
still not working after doing everything you said except
not sure what that means
so far there have been no changes except a small delay at the very start.
Im starting to think that my display might be 7x5, maybe there is some way to change the code to fit a 7x5 display?
thanks for all you help so far
Ok the only other thing I can think of, is this. Open a new sketch and copy & paste the whole thing.
#define A { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,1,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define B { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define C { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define D { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define E { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define f { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define G { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,1,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define H { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define I { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define J { \
  {0,0,0,0,0,0,0}, \
  {0,0,1,1,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define K { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,0,0,0}, \
  {1,1,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define L { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,0,0,0}, \
  {1,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define M { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define N { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,1,1,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define O { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {1,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define P { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,1,0,1,0}, \
  {0,0,0,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Q { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,1,0}, \
  {0,0,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define R { \
  {0,0,0,0,0,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,1,0,1,0,0}, \
  {1,1,0,1,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define S { \
  {0,0,0,0,0,0,0}, \
  {1,0,1,1,1,0,0}, \
  {1,0,1,0,1,0,0}, \
  {1,1,1,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define T { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,0,0}, \
  {1,1,1,1,1,0,0}, \
  {0,0,0,0,1,0,0}, \
  {0,0,0,0,0,0,0} \
#define U { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,1,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define V { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {1,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define W { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,1,0,0,0,0}, \
  {0,1,1,1,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define X { \
  {0,0,0,0,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,1,0,0,0}, \
  {0,1,1,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Y { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,1,1,1,0,0,0}, \
  {0,0,0,0,1,1,0}, \
  {0,0,0,0,0,0,0} \
#define Z { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,1,1,0}, \
  {0,1,0,1,0,1,0}, \
  {0,1,1,0,0,1,0}, \
  {0,0,0,0,0,0,0} \
#define DASH { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,1,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define SPACE { \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define DOT { \
  {0,0,0,0,0,0,0}, \
  {0,1,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0}, \
  {0,0,0,0,0,0,0} \
#define COLS 5
#define ROWS 7
#define PINS 13
#define MATRIX1 { \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1} \
#define MATRIX2 { \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
  {1,0,1,0,1,0,1}, \
  {0,1,0,1,0,1,0}, \
byte col = 0;
byte patterns[numPatterns][COLS][ROWS] = {MATRIX2, S, C, E, A, K, MATRIX1};
int pattern = 0;
  // set up cols
  //  and rows
  clearLeds();
  //setPattern(pattern);
 //slidePattern(pattern, 180);
 RotatePattern(pattern);
void display()
  col++;
  if (col == 5) {
    col = 0;
   // delay(10);
    delay(del);
void clearLeds()
      leds[i][j] = 0;
    //Serial.println();
You have to reconnect all the LED's because you did it wrong!
how do you know?
Well it still didn’t work
Thanks for everything
spongeman619:
how do you know?
because there are 2 rows not working, which tells me that you are drawing it in the wrong way.
Take a look 2 rows missing it's because you are drawing the 7x5 instead of drawing 5x7. 5+2 = 7.
Can you send me a before and after video of what your seeing?
@spongeman619, please do not cross-post. Threads merged.
Sorry I did not know at the time. :roll_eyes:
