Need Help COB LED 10W 12V ..
so i just brought some COB LED to make it into Flashlight , but the thing is , it wont turn on easly , i tried using Arduino just by the 5V and GND and it shine little bit , but when i try using battery case 4x2 (i dont know what its name) using 8 x 1,5V Battery on it, in wont light up not even little bit .
Somebody..
am i missing something here?..
Oh yeah and i also tried to SMD LED , and it fried 3/4 of them , so that indicate High Voltage? (i dunno)
this is the LED
What does this mean?
When you say "to SMD LED" it sounds like SMD is something you do to an LED where as SMD is a description of an LED standing for Surface Mount Device. If by "to" you mean "two" then how can you fry 3/4 of two LEDs.
How was the Arduino powered? If through the USB then there is a thermal fuse that limits the current through the LED.
So what was the voltage out of the battery when you measure it without a load and with the LED connected.
And also what type of batteries did you use.
Connecting an LED like this to batteries is a bad idea because the current limit depends on the battery chemistry, you have no control over it.
SMD LED I mean this ,
the Arduino is powered using USB from my Laptop and the 5V and GND through BreadBoard then go through the COB LED
i use Alkaline Battery
and i mean i use 8x 1,5V Battery , i mean a direct eletricity , not through Arduino then> LED COB,
But when use Arduino , i only power it up using Laptop USB Port like this
Laptop > Arduino > Breadboard > LED COB
And when using battery , it's like this..
8x1,5V Alkaline Battery > LED COB
i kinda forgot what to use , because its been 2 years im not playing the Arduino and making stuff my self and experiment , so i kinda not sure (kinda forgot) what is the purpose of Transistor or Capacitor and how to use it , other than that i still had some knowledge of it
except for controlling output and input , i dont know what to use
You need a resistor as a current limiting device in every LED. Circuit for LEDs that draw undear 40mA or so.
For LEDs that draw more you need a constant current driver to ensure that the current is under control.
Look up constant current drivers on Google.
