Need help coding using ultrasonic sensor, stepper motor, and passive buzzer
Hey guys i need help with my code.
Im trying to make the stepper motor constantly rotate clockwise and then counterclockwise until the ultrasonic sensor detects an object at 20cm or less; once it hits < 20 I want the motor to stop and the passive buzzer to beep, then after a short delay to continue moving again clockwise to counterclockwise.
For some reason as soon as i add the stepper motor code the monitor that detects the sensor is delayed. Right now the motor moves when it detects something it stops, plays the beeps but wont continue moving again as the serial monitor just stop detecting anything
#include "SR04.h"
#include "pitches.h"
#include <Stepper.h>
#define TRIG_PIN 12
#define ECHO_PIN 11
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
long a;
int melody[] = { //beep 8 times when <20
  NOTE_DS3, NOTE_DS3, NOTE_DS3, NOTE_DS3, NOTE_DS3, NOTE_DS3, NOTE_DS3, NOTE_DS3};
int duration = 50; //how long each beep sound is
const int stepsPerRevolution = 950;  // when the motor changes rotation
const int rolePerMinute = 15;         // Adjustable range of 28BYJ-48 stepper is 0~17 rpm
// initialize the stepper library on pins 2 through 5:
Stepper myStepper(stepsPerRevolution, 2, 4, 3, 5);
   myStepper.setSpeed(rolePerMinute);
   myStepper.step(stepsPerRevolution); //rotates clockwise
   myStepper.step(-stepsPerRevolution); //totates counter clockwise
   a=sr04.Distance(); //detects distance on serial monitor
   Serial.print(a); //prints the distance
   Serial.println("cm");
   delay(200);
   if (a < 20) {
    for (int thisNote = 0; thisNote < 8; thisNote++) {
    tone(8, melody[thisNote], duration); //plays the melody when <20
    delay(100);
   myStepper.setSpeed(0); //stops the motor when <20
   else {
    myStepper.setSpeed(rolePerMinute); //replays the rotating motor loop when >20
    delay(200);
Where did you get the SR04.h library? You should include links to any library in your code that is not included with the IDE.
The Stepper library step() function blocks. Execution of anything else stop until the movement is complete. If you want to simulate non blocking you must do one step at a time. Or us a non-blocking library like AccelStepper.
Sorry here's the library GitHub - Martinsos/arduino-lib-hc-sr04: Arduino library for HC-SR04 ultrasonic distance sensor. its used to measure distance using the ultrasonic sensor
Also, how would I go about doing "one step at a time"
The library you are using uses the function pulseIn which is blocking.
stepper is blocking too.
You can use the MobaTools for non-blocking stepper-motor-driving
The pulse-creation for the stepper-motor is done "in the backround" independent of the code-execution.
MobaTools can be installed using the library-manager
The MobaTools have a pretty good documentation on how to use it
For the ultrasonic sensor there is another library
NewPing uses Timer2
the MobaTools use Timer1
this conflicts with using tone() that uses timer1 too.
What is the exact type of microcontroller you are using?
best regards Stefan
