Need help combining two sketches ASAP!
Right, so I’m doing a final year project for university, and I’m making a MIDI controller using various sensors and components. One of the components is an Adafruit Trellis (Overview | Introducing Adafruit Trellis | Adafruit Learning System) which uses its own sketch to read the buttons.
I’ve recently been trying to create a sketch in Arduino that will allow me to still read the Trellis as normal, but also be able to use other sensors and components by incorporating the standardfirmata sketch. I would just write a sketch for the whole controller, but my skills on Arduino software are not great, so all the messages i get in and out will be going through MaxMSP.
Here is the Trellis sketch:
  This is a test example for the Adafruit Trellis w/HT16K33
  Designed specifically to work with the Adafruit Trellis
  ----> https://www.adafruit.com/products/1616
  ----> https://www.adafruit.com/products/1611
  These displays use I2C to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  MIT license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_Trellis.h"
  This example shows reading buttons and setting/clearing buttons in a loop
  "momentary" mode has the LED light up only when a button is pressed
  "latching" mode lets you turn the LED on/off when pressed
  Up to 8 matrices can be used but this example will show 4 or 1
#define MOMENTARY 0
#define LATCHING 1
// set the mode here
#define MODE LATCHING
Adafruit_Trellis matrix0 = Adafruit_Trellis();
// uncomment the below to add 3 more matrices
Adafruit_Trellis matrix1 = Adafruit_Trellis();
Adafruit_Trellis matrix2 = Adafruit_Trellis();
Adafruit_Trellis matrix3 = Adafruit_Trellis();
// you can add another 4, up to 8
// Just one
Adafruit_TrellisSet trellis =  Adafruit_TrellisSet(&matrix0);
// or use the below to select 4, up to 8 can be passed in
//Adafruit_TrellisSet trellis =  Adafruit_TrellisSet(&matrix0, &matrix1, &matrix2, &matrix3);
// set to however many you're working with here, up to 8
#define NUMTRELLIS 1
#define numKeys (NUMTRELLIS * 16)
// Connect Trellis Vin to 5V and Ground to ground.
// Connect the INT wire to pin #A2 (can change later!)
#define INTPIN A2
// Connect I2C SDA pin to your Arduino SDA line
// Connect I2C SCL pin to your Arduino SCL line
// All Trellises share the SDA, SCL and INT pin!
// Even 8 tiles use only 3 wires max
  Serial.println("Trellis Demo");
  // INT pin requires a pullup
  pinMode(INTPIN, INPUT);
  digitalWrite(INTPIN, HIGH);
  // begin() with the addresses of each panel in order
  // I find it easiest if the addresses are in order
  trellis.begin(0x70);  // only one
  // trellis.begin(0x70, 0x71, 0x72, 0x73);  // or four!
  // light up all the LEDs in order
  for (uint8_t i=0; i<numKeys; i++) {
    trellis.setLED(i);
    trellis.writeDisplay();
    delay(50);
  // then turn them off
    trellis.clrLED(i);
    delay(50);
  delay(30); // 30ms delay is required, dont remove me!
  if (MODE == MOMENTARY) {
    // If a button was just pressed or released...
    if (trellis.readSwitches()) {
      // go through every button
	// if it was pressed, turn it on
	if (trellis.justPressed(i)) {
	  Serial.print("v"); Serial.println(i);
	  trellis.setLED(i);
	// if it was released, turn it off
	if (trellis.justReleased(i)) {
	  Serial.print("^"); Serial.println(i);
	  trellis.clrLED(i);
      // tell the trellis to set the LEDs we requested
  if (MODE == LATCHING) {
        // if it was pressed...
	  Serial.println(i);
	  // Alternate the LED
	  if (trellis.isLED(i))
	    trellis.clrLED(i);
	    trellis.setLED(i);
If anyone could assist me that would be much appreciated!
This is a quick as I can respond - demo for merging sketches
...R
Thanks for the reply. But one of the main issues is that the Trellis requires me to have serial readings that indicate different buttons that have been pressed. And the standardfirmata needs to use serial.print for itself. Therefore it is causing a clash in the serial monitor.
What i want to do is to be able to generate readings still from the Trellis and use the standardfirmata as normal. This is essential as I am using MaxMSP, which will be receiving messages from the serial port selected.
Any advice?
