Per the below from the manual, you would send the ESC a high servo position value (using degree or microsecond positions) when the "top point of forward" is required, and a low servo position value when the "top point of backward" is required.
Setting Throttle Range (Throttle range should be setup when a new transmitter is being used)
QUIK series ( “ SET ” KEY is used )
Switch off the ESC
[ch8594]
Switch on the transmitter
[ch8594]
Press and hold the “ SET ” KEY
[ch8594]
Switch on the ESC
[ch8594]
Push the
throttle stick to the top point of forward within two seconds
[ch8594]
Wait for one second
[ch8594]
System detects the Max throttle signal, and
makes two “beep-” sounds, which denotes that Max throttle has been confirmed and saved
[ch8594]
Pull the throttle stick to the top point of
backward
[ch8594]
System detects the Min throttle signal, makes two “beep-” sounds, which denotes that Min throttle has been confirmed and
saved
[ch8594]
Release the “ SET ” KEY
[ch8594]
Setting is finished.
