i was wondering if anyone could give me an example sketch about how you would control 2 servos in sequence using millis so that other operations can continue to go on.
for example if it takes (servo.1)100ms to rotate 15degrees and (servo.2) 200ms to turn 30 degrees and i want to press a button for them to go off it would kind of be psuedo coded like
servo.2 rotate in 300ms on button = high
servo.1 rotate in 100ms on button = high
const int buttonPin = 4; // the number of the pushbutton pin
const int servo1 = 6; // the number of servo1 pin
const int servo2 = 7; // the number of servo2 pin
void setup(){
// initialize the servo pins as outputs:
pinMode(servo1Pin, OUTPUT);
pinMode(servo2Pin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
unsigned long Startservo1 = millis(//do i enter 100 here or leave blank?);
unsigned long Startservo2 = millis(//do i enter 200 here or leave blank?);
periodservo1 = 100;
periodservo2 = 300;
void loop(){
//do whatever starts servo1
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn servo.1 on:
digitalWrite(servo1Pin, HIGH);
else {
// turn servo1 off:
digitalWrite(servo1Pin, LOW);
if (millis(//is this where i enter 100?) - Startservo1 =>periodservo1){
//stop servo 1
//do whatever starts servo2
my error message when i tried to verify the sketch.
sketch_jan03a.ino: In function 'void setup()':
sketch_jan03a:7: error: 'servo1Pin' was not declared in this scope
sketch_jan03a:8: error: 'servo2Pin' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Arduino.h:105: error: too many arguments to function 'long unsigned int millis()'
sketch_jan03a:13: error: at this point in file
sketch_jan03a:14: error: at this point in file
sketch_jan03a:15: error: 'periodservo1' was not declared in this scope
sketch_jan03a:16: error: 'periodservo2' was not declared in this scope
sketch_jan03a.ino: In function 'void loop()':
sketch_jan03a:22: error: 'buttonState' was not declared in this scope
sketch_jan03a:28: error: 'servo1Pin' was not declared in this scope
sketch_jan03a:32: error: 'servo1Pin' was not declared in this scope
sketch_jan03a:34: error: at this point in file
sketch_jan03a:34: error: 'Startservo1' was not declared in this scope
sketch_jan03a:34: error: expected primary-expression before '>' token
sketch_jan03a:34: error: 'periodservo1' was not declared in this scope
sketch_jan03a:40: error: 'servo2Pin' was not declared in this scope
sketch_jan03a:42: error: 'else' without a previous 'if'
sketch_jan03a:44: error: 'servo2Pin' was not declared in this scope
sketch_jan03a:46: error: at this point in file
sketch_jan03a:46: error: 'Startservo2' was not declared in this scope
sketch_jan03a:46: error: expected primary-expression before '>' token
sketch_jan03a:46: error: 'periodservo2' was not declared in this scope
sketch_jan03a:48: error: expected `}' at end of input
the sketch i tried to verify
void setup(){
unsigned long Startservo1 = millis(100);
unsigned long Startservo2 = millis(300);
periodservo1 = 100;
periodservo2 = 300;
void loop(){
// turn servo1 on:
else {
// turn servo1 off:
if (millis(100) - Startservo1 =>periodservo1){
//stop servo 1
// turn servo2 on:
digitalWrite(servo2Pin, HIGH);
else {
// turn servo2 off:
digitalWrite(servo2Pin, LOW);
if (millis(300) - Startservo2 =>periodservo2){
//stop servo 2
the link you included uses potentiometers of which im not using so im not quite sure how to input a button instead, and change the millis to go off in sequence rather than all at once
stevethor7687:
i really am astonished i cant find an example sketch of sequenced servos controlled by a button....not a single search provider has found anything.
I'm really astonished you didn't read #7 below about code boxes. You probably will need to make your sketch of sequenced servos as it contains several different parts. You probably can start by making code with a button push response like below, then add additional code to slow the servo movement using incremental servo position commands (similar to the servo "sweep" example code).
stevethor7687:
#include <Servo.h>
int button = 5; //button pin, connect to ground to move servo
int press = 0;
Servo servo;
Servo servo1;
boolean toggle = true;
pinMode(button, INPUT); //arduino monitor pin state
servo.attach(7); //pin for servo control signal
servo1.attach(8); //pin for servo control signal
digitalWrite(5, HIGH); //enable pullups to make pin high
ive tried converting this sketch before into millis and i was unsuccessful, also i read the forum guidance over two weeks ago and didnt remember to use the code button as im new to using forums so im still getting use to all the setups
thats what i have now is this what you meant by the startservo error? im still unsure how to write a button in but ill post that example in a second too i guess also when ever i see work done with a servo i always see the statement "#include servo.h" at the top of the sketch is this needed for this sketch? what does that statement mean?
This is a required library you need to get your sketch to control your servo motor.
Let us do some basic review.
1.) Before you attempt to experiment with writing your own sketch, try this example: http://arduino.cc/en/Tutorial/Sweep
Can you get your servo to sweep back and forth with the above sketch?
Do you understand how the sketch works and do you have any questions how it works?
2.) Below is a sketch that does not use the delay() function to do 2 things every now and then.
Do you have any questions how it works?
const unsigned long TaskAtime = 100UL; //Runs TaskA every 1/10 second
const unsigned long TaskBtime = 1000UL; //Runs TaskB every 1 second
unsigned long TimeA; //Times up, Task A time
unsigned long TimeB; //Times up, Task B time
// etc.
TimeA = millis(); //Initailize
TimeB = TimeA; //Initialize
pinMode(13,OUTPUT); //
pinMode(12,OUTPUT); //
} // >>>>>>>>>>>>>> END OF setup() <<<<<<<<<<<<<<<<<
unsigned long millisNow = millis();
if (millisNow - TimeA >= TaskAtime) //Is it time to run Task A?
TimeA = millis(); //Re-initialize
TaskA();
if (millisNow - TimeB >= TaskBtime) //Is it time to run Task B?
TimeB = millis(); //Re-initialize
TaskB();
//Other stuff goes here
} // >>>>>>>>>>>>>> END OF loop() <<<<<<<<<<<<<<<<<
// FUNCTIONS
void TaskA()
digitalWrite(13,!digitalRead(13)); //Toggle pin 13
//Other stuff
void TaskB()
digitalWrite(12,!digitalRead(12)); //Toggle pin 12
//Other stuff
// END OF CODE
3.) Have you run the Button sketch that comes with the Arduino IDE:
