This is the original code:
#include "Adafruit_NeoPixel.h"
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(8*14, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
strip.begin();
strip.show(); // Initialize all pixels to 'off'
rainbowCycle(20);
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((((i) * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
this is what I have done so far but I have become stuck. The code is for a book shelf so each box lights up a different colour and moves across to the next as a constant loop.:
#include "FastLED.h"
// Number of RGB LEDs in the strand
#define NUM_LEDS 180
// Arduino pin used for Data
#define DATA_PIN 1
// Define the array of leds
CRGB leds[NUM_LEDS];
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
FastLED.setMaxPowerInVoltsAndMilliamps(5,500);
rainbowCycle(20);
uint16_t i, j;
for(i=0; i< NUM_LEDS; i++) {
FastLED.setPixelColor(i, Wheel((((i) * 256 / FastLED.NUM_LEDS()) + j) & 255));
FastLED.show();
delay(wait);
if(WheelPos < 85) {
return FastLED.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
WheelPos -= 85;
return FastLED.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return FastLED.Color(0, WheelPos * 3, 255 - WheelPos * 3);
