Need help, could you be up to the challenge
Hi there
Iv never programmed before, only brought and used small intergrated circuits for my projects in the past , I'm going to put this simply I have two "TTP 223" sensor modules and I want them to control a couple of servos for me, I want to be able to press them so that one module controls them to move to the left and the other moves them to the right, but I want them to act as momentarily as possible, so as soon they are stoped they stop movement of the servos, I have brought a Arduino nano, but I will also need help on where to place them for the pins on the board.
Can anyone help me with this project, and even possibly write the script? Much appreciated if you can,
joko9086
OK, a good starting point is to link to your sensor's online datasheets, or attach the PDF files in the thread...
Perhaps a sketch (drawing) of what your mechanical layout is going to be - so we can visualise it.
As a mechanical project - you need to consider range of motion, power supplies etc (and chopping off fingers etc)
Your goal sounds easy enough for an experienced developer - if you want to keep going by yourself -
contribute more info, or drop a hint on the budget, timeline etc, and maybe we can PM you to get involved.
