xl97:
Well.. I guess I cant comment about the hosting/domain stuff.. (maybe it works without issue?)
That being said.. WOWZERS MAN!.. I wouldnt use that script if I were you!.
I would switch to PDO and prepared statements..etc..
At the very least sanitize your data!.. That script is totally open to injection attacks!!
Does the script work 'as-is'? Can you load that up in your browser and get it to insert data?
If not.. then you know the problem isnt on the Arduino side of things.. (or at least not yet)Also says your script can not be found.. so the path is not correct.
if this is it: Error (nor does that url look even remotely compliant/legit)
i don't really care about the attacks, ik that that domain sucks but i've to use it even if i don't want to i have to, it's for school, they told me to use that anyways there's a commmand i use : Error , that command works just fine, my database is working fine, the php code is fine too but the problem is with arduino program i'm sure there's something wrong around, i don't know like the ip things idk what to put in there,i tried everything, or could it be from my arduino card? maybe it's broken or something..as i said database is fine, i can add things through ajout.php..
