I have an Arduino mega that is connected to a CIROCOMM GPS Shield
Background: I made this work once using example code from the internet. However it recently stopped working and has never worked since. I don't believe this is equipment problems because I have both a spare Mega and a spare GPS Shield. The symptoms are the same regardless of what combination of equipment I use. I really do not know what is going on or how to debug this system. Can someone please help explain some techniques that will allow me to debug this?
Problem: The problem appears to be in the Serial3 connection. Serial3.available() never returns true. How can I figure out what is going on here?
////// BEGIN CODE ///////
// WIRING:
// 1. GPS is powered and Grounded. After about 20 seconds the GPS achieves lock.
// GPS lock is indicted by a solid red light.
// 2. GPS TX (blue wire) is connected to Mega 14 (Tx3)
// GPS RX (yellow wire) is connected to Mega 15 (Rx3)
#include <TinyGPS.h>
#define GPSBAUD 4800
TinyGPS gps;
void getgps(TinyGPS &gps);
Serial3.begin(GPSBAUD);
Serial.println("GPS TEST CODE ");
Serial.println("entering loop");
if(Serial3.available()) { // PROBLEM IS HERE!!! - Never is available
Serial.println("serial3 available"); // THIS LINE NEVER PRINTS
Serial.println("serial3 not-available"); // THIS LINE ALWAYS PRINTS
while(Serial3.available()) // While there is data on the RX pin...
int c = Serial3.read(); // load the data into a variable...
if(gps.encode(c)) // if there is a new valid sentence...
getgps(gps); // then grab the data.
////// END CODE ///////
