Need help detecting changes in voltage
Hey,
Im a beginner and trying to make a automatic plant waterer and i can't figure out the code to detect the voltage.
Im planning on using the 5V of the arduino uno.
The idea is to put 2 elektrodes in the dirt, when the dirt is wet there should be a voltage between these 2 elektrodes, when the dirt is drying the voltage will slowly drop and when it drops below a certain point i want a servo to move and let water drop onto the dirt.
You will have top explain a bit more. What voltage? Where does it come from? How often does the voltage change? ETc, Etc. Etc.
Surely you have googled Arduino watering systems. There are a multitude of watering systems using a capacitive soil moisture sensor.
