Need Help/Direction on how to make my sketch size smaller
Hello
I need some help with making my sketch smaller. I just spent a few hours writing it and then realized it is going to be way too big.
I included a working example of what I am trying to do. My actual sketch is beyond the byte capacity of an Uno.
I am using a TLC5940 and am manually fading the channels.
I have 10 RGBs that fade in and out 10 colors at different intervals using switch case.
I also have functions that turn off the channels for a blackout period for the RGBs.
I know my problem lies in writing out each and every fade functions.
Any help or insight on how to compress this sketch is much appreciated.
This working example is for 2 RGBs and 2 colors.
#include "Tlc5940.h"
//--------Fade Variables----------------------
long previousMillis1 = 0;
long interval1 = 10;
long previousMillis2 = 0;
long interval2 = 10;
//-------------------Fade Values for Colors-----------------------
//-----------------Red-----
int rfadeValue1 = 0;                                     //Initial fade values
int rfadeValue2 = 0;
//-----------------Green-----
int gfadeValue1 = 0;
int gfadeValue2 = 0;
//-----------------Blue-------
int bfadeValue1 = 0;
int bfadeValue2 = 0;
//-----------Switch Case Variables----------------------
int led1State = 0;
boolean next1 = false;
int led2State = 0;
boolean next2 = false;
//----------------------Count/Time for Blackout-----
long int time1 = 10UL;
unsigned long count1 = 0;
long int time2 = 10UL;
unsigned long count2 = 0;
boolean timeout(unsigned long *marker, unsigned long interval) {         //Timer for Blackout phase
  if (millis() - *marker >= interval) {
    *marker += interval;    // move on ready for next interval
    return true;
  else return false;
void setup(){
  Tlc.init();
  led1State = 0;
  led2State = 0;
  time1 = 1UL;
  time2 = 1UL;
rgbAction();
  void rgbAction(){
  //------------------------------1-------------------------
    switch (led1State) {
       case 0:
      interval1 = 10;
        blueOn1();
        if (next1){
            next1 = false;
            led1State = 1;
    case 1:
      interval1 = 5;
        blueOff1();
        if (next1){
            next1 = false;
            led1State = 2;
    case 2:
          black1();
          time1 = 20000UL;
        if (timeout(&count1, time1 )) {
            next1 = false;
            led1State = 3;
    case 3:
      interval1 = 5;
        magentaOn1();
        if (next1){
            next1 = false;
            led1State = 4;
      case 4:
      interval1 = 5;
        magentaOff1();
        if (next1){
            next1 = false;
            led1State = 0;
//=======================================2============
    switch (led2State) {
       case 0:
      interval2 = 3;
        magentaOn2();
        if (next2){
            next2 = false;
            led2State = 1;
    case 1:
      interval2 = 4;
        magentaOff2();
        if (next2){
            next2 = false;
            led2State = 2;
    case 2:
          black2();
          time2 = 5000UL;
        if (timeout(&count2, time2 )) {
            next2 = false;
            led2State = 3;
    case 3:
      interval2 = 4;
        blueOn2();
        if (next2){
            next2 = false;
            led2State = 4;
      case 4:
      interval2 = 3;
        blueOff2();
        if (next2){
            next2 = false;
            led2State = 0;
//-----------------------BlackOut Funtions, period when RGB is off----------------
void black1(){
        Tlc.set(0, 0);
        Tlc.set(1, 0);
        Tlc.set(2, 0);
        Tlc.update();
   void black2(){
        Tlc.set(3, 0);
        Tlc.set(4, 0);
        Tlc.set(5, 0);
        Tlc.update();
//-------------------------------Blue fades for both RGBs-------
void blueOn1(){
   unsigned long currentMillis1 = millis();
 if(currentMillis1 - previousMillis1 > interval1) {
    previousMillis1 = currentMillis1;
  if(bfadeValue1 <= 4000, bfadeValue1 +=5) {
    Tlc.set(2, bfadeValue1);
 Tlc.update();
if(bfadeValue1 >= 4000){
next1 = true;
void blueOff1(){
  if(bfadeValue1 >=0, bfadeValue1 -=5){
 Tlc.update();
 if(bfadeValue1 <= 0){
next1 = true;
//-----#2---------------------
void blueOn2(){
   unsigned long currentMillis2 = millis();
 if(currentMillis2 - previousMillis2 > interval2) {
    previousMillis2 = currentMillis2;
  if(bfadeValue2 <= 4000, bfadeValue2 +=5) {
    Tlc.set(5, bfadeValue2);
 Tlc.update();
if(bfadeValue2 >= 4000){
next2 = true;
void blueOff2(){
  if(bfadeValue2 >=0, bfadeValue2 -=5){
 Tlc.update();
 if(bfadeValue2 <= 0){
next2 = true;
//-------------------------------Magenta fades for both RGBs-------
void magentaOn1(){
   unsigned long curentMillis1 = millis();
 if(curentMillis1 - previousMillis1 > interval1) {
    previousMillis1 = curentMillis1;
  if(rfadeValue1 <= 4000, rfadeValue1 +=5, bfadeValue1 <= 4000, bfadeValue1 +=5) {
    Tlc.set(0, rfadeValue1);
 Tlc.update();
next1 = true;
void magentaOff1(){
  if(rfadeValue1 >=0, rfadeValue1 -=5, bfadeValue1 >=0, bfadeValue1 -=5){
 Tlc.update();
next1 = true;
//------#2-------
void magentaOn2(){
  if(rfadeValue2 <= 4000, rfadeValue2 +=5, bfadeValue2 <= 4000, bfadeValue2 +=5) {
    Tlc.set(3, rfadeValue2);
 Tlc.update();
next2 = true;
void magentaOff2(){
  if(rfadeValue2 >=0, rfadeValue2 -=5, bfadeValue2 >=0, bfadeValue2 -=5){
 Tlc.update();
next2 = true;
Won't help with size, but these should be unsigned long, all time related elements should be unsigned long as that is what millis(); returns. Keep the math consistent:
These look like they could all be byte instead of int:
int led1State = 0;
These look a little mixed up - they should be unsigned long:
How big is the code compiling to?
Next step might be to go to a 1284P based board. 128K flash, 16K SRAM.
I offer them in several form-factors, this one is like a Duemilanove:
http://www.crossroadsfencing.com/BobuinoRev17/
@1rulon1
TIP: in the IDE you can do TOOLS->AUTO FORMAT to reindent the code ==> makes the code more readable
Are you running out of space for code, or data, or both ?
That code doesn't really look too long for a Uno.
Whe knows how big the TLC5940 library is? That might be the space killer.
CrossRoads,
Thank you for pointing out my unsigned long issues.
The TLC5940 library is ~2000 bytes.
I eventually will have a few 'settings' that I can switch through with an IR remote.
Right now the initializes, setup and just one Setting is ~30,000 bytes.
I may need to go to something bigger as you suggested.
