Need help dividing analog voltage
I am using a pulse sensor (https://pulsesensor.com) connected to an Adafruit Feather Huzzah esp8266 board. It draws power from a 3V pin ("the output from the 3.3V regulator that can supply 500mA peak"), and sends the sensor values to the ADC pin. However, this pin has "a 1.0V maximum voltage." I am trying to create a voltage divider but don't know how to go about it. Any help/a diagram showing how to wire this voltage divider on a breadboard, would be greatly appreciated. :slight_smile:
Search Google for Voltage Divider. There are loads of examples and calculators available
24k + 10k perhaps? That divides 3.4V down to 1.0V Voltage divider - Wikipedia
3.3V----////----////---+----////----GND
1k 22k | 10k
1.0V
Enter R1 to have 30 kOhms and R2 to have 13kOhms to get 0.998 V
anjaleen:
Forget the voltage divider.
Use analogReference(INTERNAL) and you will get a range of 0..1.1V at the analog inputs. By the way that will be more independen from Vcc as well.
RIN67630:
None of that on an ESP8266.
It only has one analogue input with a range of ~0-1volt.
Leo..
Wawa:
Leo..
Then, where is the problem?
The sensor delivers 0..1V the ESP needs 0..1V.
The sensor delivers about 3.3V.
jremington:
OK, then 27KΩ and 10KΩ according to the common E12 values will provide 0..3,7V range.
