Here is a working 1khz pwm pulse generator sketch with a duty cycle pot. I wanted to add a 2nd frequency and another pot to this sketch and wondered the best way to do that? Thanks Mac
// Sketch name: PWM_FREQUENCY_GENERATOR2_FORUM_QUESTION.ino
// This sketch outputs PWM on UNO pin D3
// For 100% duty cycle add voltage divider (2pcs 22k ohm) on pin A0
// -or adjusted with a 50k potentiometer
// https://forum.arduino.cc/t/pwm-frequency-library/114988
#include <PWM.h>
int sensorValue = 0;
int32_t frequency = 1000; // frequency in hertz
// Serial.begin(9600); // for debugging
InitTimersSafe();
bool success = SetPinFrequencySafe (3, frequency); // output pin D3
if (success) {
// Show Frequency Lock on control panel (off or flashes when unlocked)
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
int sensorValue = analogRead(A0);
//A0 must have resistor voltage divider or 50k pot.
pwmWrite(3, sensorValue / 4);
delay(5); //default is 30
Serial.println(sensorValue); // for debugging
Serial.println(frequency); // for debugging
//delay (500); // for debugging
Tnks CrossRoads, I heard that Arduino's 8 bit timers can only use pins 2,3,6,7,8,11&12, so it seems that only D6 or D11 are usable. I already tried duplicating the code but had problem with 2 bool's.
// For 100% duty cycle add voltage divider (2pcs 22k ohm) on pin A0 & A1
#include <PWM.h>
int sensorValue = 0; // Tone 1
int sensor2Value = 0; // Tone 2
int32_t frequency = 1000; // Tone 1 frequency in hertz
int32_t frequency2 = 500; // Tone 2
// Serial.begin(9600); // for debuging
InitTimersSafe();
bool success = SetPinFrequencySafe (3, frequency); // Tone 1 pin D3
bool success = SetPinFrequencySafe (6, frequency2); // Tone 2 pin D6
if (success) {
int sensorValue = analogRead(A0); // Tone 1 duty cycle adjust
int sensor2Value = analogRead(A1); // Tone 2 duty cycle adjust
// Note: A0 & A1 must have voltage divider resistors or 50k pot.
delay(5);
pwmWrite(6, sensor2Value / 4); // Tone 2
delay(5);
// Serial.println(sensorValue); // for debuging
// Serial.println(frequency); // for debuging
// Serial.println(sensor2Value); // for debuging
// Serial.println(frequency2); // for debuging
//delay (500); // for debuging
Ok, the sketch compiles ok, but both pots adjust D3's pwm 1000Hz duty cycle. Also, no pwm output on D6, but both pots switch output between high and low states at 2.5v midpoint.
Setting the pins as OUTPUTS did not help. Before when testing, I was switching a single pot back and forth between A0 & A1's inputs, but after adding another pot on A1, D3's frequency duty cycle worked fine with only A0 pot adjusted. However, D6 still does not output any pwm!! We know D6 on the UNO is a pwm pin, so there must be an issue with Arduino's 8 bit timer pin selection??
Pins 5 and 6 belong to Timer0 which the Arduino core uses for millis(). The library may be protecting you from using them. You are already using Timer2 (Pins 3 and 11) and you can't have two different frequencies on one timer so I think your only choice is to use Timer1 (Pins 9 and 10).
Thanks for your help John and Crossroads. I did get it working by not using bool and using pins D3 & D9. As John said, it may be better to use 9 & 10 which would free up Timer0 for millis(). Now, it would be nice to be able to vary the frequencies also with pots! Working ketch attached:
#include <PWM.h>
pinMode(3, OUTPUT); // set digital pins as outputs
pinMode(9, OUTPUT);
pinMode(A0, INPUT); // set analog pins as inputs
pinMode(A1, INPUT);
InitTimersSafe();
SetPinFrequencySafe (9, frequency2); // Tone 2 pin D9
void loop() // Note: A0 & A1 must have voltage divider resistors or 50k pot.
pwmWrite(3, sensorValue / 4); // Tone 1
delay(5);
pwmWrite(9, sensor2Value / 4); // Tone 2
delay(5);
That's NOT what I meant to say. You apparently can't use Timer0 (5 or 6) and you are using one of the Timer2 pins (3). You can't put a different frequency on the same timer so you can't use 11. That leaves Timer1 9 OR 10. You can't use 9 AND 10 if you want two different frequencies.
Thanks for clarifying that for me John. I do need 2 adjustable frequencies, so will have to stick with 3 & 9, but don't think I can live without millis() either. I'll have to look if there are other Arduinos with 3 timers, or use 2 UNO's. I'm hoping to use the 2nd pwm to drive a Vactrol to adjust the gain on an Op-Amp. What do you think?
I just noticed that the Tone Library also uses Timer2 (which I need), so my coding issues are getting complicated. 2 Pro-Mini's would work, but I'm also trying to keep parts count to a minimum. I'll need to think on this for a while.....
