Noob here, can anyone help me?
"‘timer_count’ was not declared in this scope"
Error is in void setup on the "MsTimer2::set" line
If i remove this, the code compiles
` // PWM specification setting
TCCR1A = 0b00100001;
TCCR1B = 0b00010001;//分周比1
// PWM setting
OCR1A = (unsigned int)(8000000 / frq );
//for development
// Serial.begin(9600);
FULL CODE
//Clock M_D module
#include <MsTimer2.h>
#include <avr/io.h>
//---------basic waveform make--------------------
unsigned int frq = 60000; //frequency
float duty = 0.5;//pin10
int wave = 1000;//output wave form , fand + harm
const static word fand[180] PROGMEM = {
0, 17, 34, 52, 69, 86, 103, 120, 137, 154, 171, 187, 203, 219, 234, 250, 264, 279, 293, 307, 321, 334, 347, 359, 371, 383, 394, 404, 414, 424, 433, 441, 449, 456, 463, 469, 475, 480, 485, 489, 492, 495, 497, 498, 499, 500, 499, 498, 497, 495, 492, 489, 485, 480, 475, 469, 463, 456, 449, 441, 433, 424, 414, 404, 394, 383, 371, 359, 347, 334, 321, 307, 293, 279, 264, 250, 234, 219, 203, 187, 171, 154, 137, 120, 103, 86, 69, 52, 34, 17, 0, -18, -35, -53, -70, -87, -104, -121, -138, -155, -172, -188, -204, -220, -235, -250, -265, -280, -294, -308, -322, -335, -348, -360, -372, -384, -395, -405, -415, -425, -434, -442, -450, -457, -464, -470, -476, -481, -486, -490, -493, -496, -498, -499, -500, -500, -500, -499, -498, -496, -493, -490, -486, -481, -476, -470, -464, -457, -450, -442, -434, -425, -415, -405, -395, -384, -372, -360, -348, -335, -322, -308, -294, -280, -265, -250, -235, -220, -204, -188, -172, -155, -138, -121, -104, -87, -70, -53, -35, -18
const static word harm[180] PROGMEM = {
0, 416, 365, 321, 334, 307, 279, 279, 254, 232, 227, 203, 185, 178, 155, 140, 131, 110, 97, 88, 68, 57, 48, 30, 21, 11, -4, -11, -21, -34, -40, -48, -60, -63, -71, -80, -82, -88, -95, -95, -101, -104, -103, -107, -109, -106, -109, -107, -103, -104, -101, -95, -95, -88, -82, -80, -71, -63, -60, -48, -40, -34, -21, -11, -4, 11, 21, 30, 48, 57, 68, 88, 97, 110, 131, 140, 155, 178, 185, 203, 227, 232, 254, 279, 279, 307, 334, 321, 365, 416, 0, -417, -366, -322, -335, -308, -280, -280, -255, -233, -228, -204, -186, -179, -156, -141, -132, -111, -98, -89, -69, -58, -49, -31, -22, -12, 3, 10, 20, 33, 39, 47, 59, 62, 70, 79, 81, 87, 94, 94, 100, 103, 102, 106, 108, 105, 108, 106, 102, 103, 100, 94, 94, 87, 81, 79, 70, 62, 59, 47, 39, 33, 20, 10, 3, -12, -22, -31, -49, -58, -69, -89, -98, -111, -132, -141, -156, -179, -186, -204, -228, -233, -255, -280, -280, -308, -335, -322, -366, -417
//-------------trig------------
bool trig = 0;//
bool old_trig = 0;//
//-----------control wave color------------
int h = 0; //table finish count
int i = 0; //waveform
byte j = 1; //decay frequency
float k = 1; //decay amp
int knob_tone = 512;
int knob_harm = 512;
int knob_attack = 512;
int knob_decay = 512;
int CV_harm = 512;
unsigned long ext_count = 400;//タイマーカウント用
unsigned long old_ext_pulse = 0;
unsigned long old_int_pulse = 0;
unsigned long ext_period = 0;//周期
unsigned long ext_count_result = 0;//タイマーのカウント結果
unsigned long old_ext_count_result = 0;//タイマーのカウント結果
byte ext_pulse = 0;//外部クロック あれば1、なければ0
byte int_pulse = 0;//内部クロック
byte ext_injudge = 1;//外部入力有無判定。あれば1,なければ0。タイマーカウントが規定値超えると判定切り替え
byte old_ext_injudge = 2;
int AD_rate = 512;//rateノブの入力
int rate = 1000;//内部クロック動作時に使用
int AD_MD = 512;//MDノブの入力値
int out_width_ch1 = 10;//アウトプットのパルス幅。
int out_width_ch2 = 10;//アウトプットのパルス幅。
int old_AD_MD = 512;//SW切り替え時のRATE値誤読対策
int MD_ch1 = 5;//マルチプル、ディバイダー判定ch1
int MD_ch2 = 5;//マルチプル、ディバイダー判定ch2
int M_period_ch1 = 0;//マルチプルの時、出力クロックの周期。マルチプルでなければ0とする。
int M_period_ch2 = 0;//マルチプルの時、出力クロックの周期。マルチプルでなければ0とする。
int M_count_ch1 = 1;//マルチプルの時、パルスごとにカウントし、設定値に達すると0に戻る
int M_count_ch2 = 1;//マルチプルの時、パルスごとにカウントし、設定値に達すると0に戻る
int D_count_ch1 = 1;//外部パルスが入るとカウントを位置上げる
int D_count_ch2 = 1;//外部パルスが入るとカウントを位置上げる
int D_full_ch1 = 1;//カウントの上限値
int D_full_ch2 = 1;//カウントの上限値
byte CH1out = 0;//0でLOW出力、1でHIGH出力
byte CH2out = 0;//0でLOW出力、1でHIGH出力
byte M_done_ch1 = 0; //マルチプルの出力確認用。ないと、1クロックで複数パルスでてしまう
byte M_done_ch2 = 0; //マルチプルの出力確認用。ないと、1クロックで複数パルスでてしまう
//---mode切り替え-------------
byte mode_sw = 1;
byte mode = 1;//1=CH1,2=CH2
byte old_mode = 0;//SW切り替え時のRATE値誤読対策
int old_MD_ch1 = 0;//スイッチ切り替え時にディバイダーのクロックが狂うバグ対策
int old_MD_ch2 = 0;//スイッチ切り替え時にディバイダーのクロックが狂うバグ対策
pinMode(7, OUTPUT); //CH1out
pinMode(8, OUTPUT); //CH2out
pinMode(13, OUTPUT); //internal_clock_out
pinMode(11, INPUT); //ext_clock_in
pinMode(10, OUTPUT);//sound output
pinMode(12, OUTPUT);//LED
MsTimer2::set(1, timer_count); // 1ms毎にタイマーカウント
MsTimer2::start();//外部入力Highになったら、次のHighまでカウント
// PWM setting
//for development
AD_MD = analogRead(3);
AD_rate = 1023 - analogRead(4);
rate = AD_rate * 2 + 100;
old_ext_pulse = ext_pulse;
old_int_pulse = int_pulse;
ext_pulse = digitalRead(3);
mode_sw = digitalRead(11);
old_mode = mode;
old_ext_injudge = ext_injudge;
//-----------ディバイダー出力のカウントリセット------------
if (D_count_ch1 >= D_full_ch1) {
D_count_ch1 = 0;
if (D_count_ch2 >= D_full_ch2) {
D_count_ch2 = 0;
old_trig = trig;
trig = digitalRead(11);
digitalWrite(12, trig); //LED ON during trigger is high
if (old_trig == 0 && trig == 1) {//trigger detect
h = 0;
i = 0;
j = 0;
k = 1;
//-----------SWの読み取り---------------
old_MD_ch1 = MD_ch1;//スイッチ切り替え時にディバイダーのクロックが狂うバグ対策
old_MD_ch2 = MD_ch2;//スイッチ切り替え時にディバイダーのクロックが狂うバグ対策
if ( mode_sw == 1 ) {
mode = 1;
else if (mode_sw == 0 ) {
mode = 2;
if ( old_mode != mode ) {//スイッチ切り替え時にディバイダーのクロックが狂うバグ対策
old_AD_MD = AD_MD;
i ++;
if (i > 179) {
knob_tone = analogRead(0) / 64;
knob_harm = (1023 - analogRead(1) ) / 32;
knob_decay = analogRead(3) / 16;
knob_attack = analogRead(5) / 16;
CV_harm = analogRead(2) / 32;
knob_harm = knob_harm - CV_harm;
if ( knob_harm >= 31) {
knob_harm = 31;
//make decay
h ++;
i = 0;
j = j + 5;//modulate wave frequency slower rate
if (knob_decay <= 32) { //no body decay
k = k * (98 - (32 - knob_decay)) / 100 - 10 / 100;
else if (knob_decay > 32) { //with body decay
if (h < (16 - knob_tone) / 2) {
k = 0.8 + h / 16 / 5;
else {
k = k * (94 - (knob_decay - 32)) / 100 - 10 / 100;
delayMicroseconds((knob_tone) * j);//modulate wave frequency slower
//---------kick wave making------------------
if (h == 0 && i < knob_attack && knob_attack >= 5) { // make punch sound by noise
wave = (pgm_read_word(&(fand[random(0, 179)]))) * 32 + (pgm_read_word(&(harm[i]))) * (32 - knob_harm);
else if (h <= 1 && i > 25 && i < 90) {
wave = (pgm_read_word(&(fand[i]))) * (32 + knob_attack / 3) + (pgm_read_word(&(harm[i]))) * (32 - knob_harm);
else {
wave = (pgm_read_word(&(fand[i]))) * 32 + (pgm_read_word(&(harm[i]))) * (32 - knob_harm);
wave = wave * k;
wave = wave / 32 + 500;
duty = (float)wave / 1000;
//---------MDノブ判定-----------------------
if ( mode == 1 && abs(old_AD_MD - AD_MD ) > 30) { //absはスイッチ切り替え時にディバイダーのクロックが狂うバグ対策
old_AD_MD = 1200;//abs(old_AD_MD - AD_MD ) > 30が絶対に成立するため
if ( AD_MD >= 0 && AD_MD < 20) {
MD_ch1 = 9;//*16
else if ( AD_MD >= 20 && AD_MD < 90) {
MD_ch1 = 8;//*8
else if ( AD_MD >= 90 && AD_MD < 240) {
MD_ch1 = 7;//*4
else if ( AD_MD >= 240 && AD_MD < 400) {
MD_ch1 = 6;//*2
else if ( AD_MD >= 400 && AD_MD < 550) {
MD_ch1 = 5;//*1
else if ( AD_MD >= 550 && AD_MD < 700) {
MD_ch1 = 4;//1/2
else if ( AD_MD >= 700 && AD_MD < 820) {
MD_ch1 = 3;//1/3
else if ( AD_MD >= 820 && AD_MD < 960) {
MD_ch1 = 2;//1/4
else if ( AD_MD >= 960 && AD_MD < 1024) {
MD_ch1 = 1;//1/8
else if ( mode == 2 && abs(old_AD_MD - AD_MD ) > 30) { //absはスイッチ切り替え時にディバイダーのクロックが狂うバグ対策
MD_ch2 = 9;//*16
MD_ch2 = 8;//*8
MD_ch2 = 7;//*4
MD_ch2 = 6;//*2
MD_ch2 = 5;//*1
MD_ch2 = 4;//1/2
MD_ch2 = 3;//1/3
MD_ch2 = 2;//1/4
MD_ch2 = 1;//1/8
switch (MD_ch1) {
case 1:
out_width_ch1 = ext_period / 2 / 8;
M_period_ch1 = ext_period / 8;
case 2:
out_width_ch1 = ext_period / 2 / 4;
M_period_ch1 = ext_period / 4;
case 3:
out_width_ch1 = ext_period / 2 / 3;
M_period_ch1 = ext_period / 3;
case 4:
out_width_ch1 = ext_period / 2 / 2;
M_period_ch1 = ext_period / 2;
case 5:
out_width_ch1 = ext_period / 2 ;
M_period_ch1 = 0;
D_full_ch1 = 1;
case 6:
out_width_ch1 = ext_period / 2;
M_period_ch1 = 0;
D_full_ch1 = 2;
case 7:
M_period_ch1 = 0;
D_full_ch1 = 4;
case 8:
M_period_ch1 = 0;
D_full_ch1 = 8;
case 9:
M_period_ch1 = 0;
D_full_ch1 = 16;
switch (MD_ch2) {
case 1:
out_width_ch2 = ext_period / 2 / 8;
M_period_ch2 = ext_period / 8;
case 2:
out_width_ch2 = ext_period / 2 / 4;
M_period_ch2 = ext_period / 4;
case 3:
out_width_ch2 = ext_period / 2 / 3;
M_period_ch2 = ext_period / 3;
case 4:
out_width_ch2 = ext_period / 2 / 2;
M_period_ch2 = ext_period / 2;
case 5:
out_width_ch2 = ext_period / 2 ;
M_period_ch2 = 0;
D_full_ch2 = 1;
case 6:
M_period_ch2 = 0;
D_full_ch2 = 2;
case 7:
M_period_ch2 = 0;
D_full_ch2 = 4;
case 8:
M_period_ch2 = 0;
D_full_ch2 = 8;
case 9:
M_period_ch2 = 0;
D_full_ch2 = 16;
if ( MD_ch1 != old_MD_ch1 || MD_ch2 != old_MD_ch2 ) { //スイッチ切り替え時にディバイダーのクロックが狂うバグ対策
D_count_ch1 = 0;
D_count_ch2 = 0;
//------------外部入力有無判定-------------------------------
if ( ext_count > 4000 ) { //4s以上カウントが無ければ、外部入力無し判定
ext_injudge = 0;
else if ( ext_count < 4000 && ext_pulse == 1 ) {
ext_injudge = 1;
if ( old_ext_injudge == 1 && ext_injudge == 0 ) { //外部入力が有→無のとき
ext_count = 0;
//---------クロック設定------------------------
if ( ext_injudge != 0 ) { //外部クロックを使用
if (ext_pulse == 1 && old_ext_pulse == 0) {
old_ext_count_result = ext_count_result;//2回の平均取る用
ext_count_result = ext_count;
// ext_count = 0;
ext_period = (old_ext_count_result + ext_count_result) / 2;//外部入力周期。ばらつき低減のため2回の平均値
// MsTimer2::start();//外部入力Highになったら、次のHighまでカウント
else if ( ext_injudge == 0) { //内部クロックを使用
ext_period = rate;
if ( ext_count < 5 || ext_count >= ext_period) {
int_pulse = 1;
else if (ext_count >= 5 ) {
int_pulse = 0;
//--------------INTERNAL CLOCK出力(外部入力無い場合のみ)-----------
if ( int_pulse == 1 ) {
digitalWrite(13, HIGH);
else if ( ext_count >= ext_period / 2 ) {
digitalWrite(13, LOW);
//-----------------OUT1出力------------------
if (ext_pulse == 1 && old_ext_pulse == 0) {//外部クロック用
D_count_ch1 ++;
ext_count = 0;
M_count_ch1 = 0;
M_done_ch1 = 0;
if ( MD_ch1 <= 4 ) {
digitalWrite(7, HIGH);
CH1out = 1;
if (int_pulse == 1 && old_int_pulse == 0) {//内部クロック用
D_count_ch1 ++;
ext_count = 0;
M_count_ch1 = 0;
M_done_ch1 = 0;
CH1out = 1;
if ( MD_ch1 < 5 ) {
if ( ext_count >= M_period_ch1 * M_count_ch1 && CH1out == 0) {
CH1out = 1;
if ( ext_count >= M_period_ch1 * M_count_ch1 + out_width_ch1 && CH1out == 1 ) {
digitalWrite(7, LOW);
M_count_ch1 ++;
CH1out = 0;
else if ( MD_ch1 == 5 ) {
if (D_count_ch1 == 1 && M_done_ch1 == 0) {
CH1out = 1;
M_done_ch1 = 1;
if ( ext_count >= out_width_ch1 ) {
CH1out = 0;
else if ( MD_ch1 > 5 ) {
CH1out = 1;
M_done_ch1 = 1;
CH1out = 0;
//-----------------OUT2出力------------------
D_count_ch2 ++;
M_count_ch2 = 0;
M_done_ch2 = 0;
if ( MD_ch2 <= 4 ) {
digitalWrite(8, HIGH);
CH2out = 1;
D_count_ch2 ++;
M_count_ch2 = 0;
M_done_ch2 = 0;
CH2out = 1;
if ( MD_ch2 < 5 ) {
if ( ext_count >= M_period_ch2 * M_count_ch2 && CH2out == 0) {
CH2out = 1;
if ( ext_count >= M_period_ch2 * M_count_ch2 + out_width_ch2 && CH2out == 1 ) {
digitalWrite(8, LOW);
M_count_ch2 ++;
CH2out = 0;
else if ( MD_ch2 == 5 ) {
if (D_count_ch2 == 1 && M_done_ch2 == 0) {
CH2out = 1;
M_done_ch2 = 1;
if ( ext_count >= out_width_ch2 ) {
CH2out = 0;
else if ( MD_ch2 > 5 ) {
CH2out = 1;
M_done_ch2 = 1;
CH2out = 0;
//開発用
Serial.print(ext_count);
Serial.print(",");
Serial.print(CH1out * 500);
Serial.print(",");
Serial.print(D_count_ch1 * 80);
Serial.println("");
//タイマーカウント。1ms毎にカウントを増やす
void timer_count() {
ext_count ++;
