I use Arduino IDE 1.18.3.
I can compile sample code / my code with Mac OSX10.14.
but compile error happened with Mac OSX10.15 and OSX11.
somebody knows how to solve this problem ?
thank you.
masahiro
you should post the code using "</>" icon and error msgs as text (not images)
/Users/masahirokahata/Documents/Arduino/libraries/Bluefruit52Lib/src/services/BLEHidAdafruit.cpp:53:48: error: expected primary-expression before ',' token
53 | HID_REPORT_ID ( REPORT_ID_KEYBOARD ),
/Users/masahirokahata/Documents/Arduino/libraries/Bluefruit52Lib/src/services/BLEHidAdafruit.cpp:99:48: error: expected primary-expression before ',' token
99 | HID_REPORT_ID( REPORT_ID_CONSUMER_CONTROL ),
/Users/masahirokahata/Documents/Arduino/libraries/Bluefruit52Lib/src/services/BLEHidAdafruit.cpp:113:44: error: expected primary-expression before ',' token
113 | HID_REPORT_ID( REPORT_ID_MOUSE ),
error can be many different things -- need to see code
thank you for check this.
as I told in beginning, works with OS X 10.14, but error happened with OSX10.15, OSX11.
My code is different, but Similer as followings.
File/Examples/Adafruit nRF52 Libraries/Peripheral/blemidi
other code same also same error.
all same version Arduino IDE use.
in case you know any let me know, it will be grate.
need to see the code, to see what is before "," on lines 53, 99 and 113
code is BLEHidAdafruit.cpp
53: HID_REPORT_ID ( REPORT_ID_KEYBOARD ),
99: HID_REPORT_ID( REPORT_ID_CONSUMER_CONTROL ),
113: HID_REPORT_ID( REPORT_ID_MOUSE ),
code must be secret
if these are function calls, there should be a semicolon, ";" after the closing parenthesis.
somebody check this, then show it.
so, it was delay to show up.
~/Documents/Arduino/libraries/Bluefruit52Lib/src/services/BLEHidAdafruit.cpp
you can see all code at this.
it is just one line of function call. continue other line.
so, no need semicolon for this.
anyway, this works with OSX10.14,
not work with OSX10.15 and OSX11
again i'm providing an educated guess without seeing the complete code.
thank you.
I just wonder some other people has Similer problem or not.
I can use OSX10.14 to compile code anyway.
