Need help for adding ints in a char
Hello, I need in my code a character combined from ints. More specifically:
I need this:
char PIN[5] = "1234";
I have these:
int a = 1;
int b = 2;
int c = 3;
int d = 4;
How can I merge the 4 ints into one char? I tried concat without any luck
byte a = 1;
PIN[0] = a;
Thank's for your reply.
There's being a problem though.
When I test this:
byte a = 1;
byte b = 2;
byte c = 3;
byte d = 4;
char PIN[5] = "";
PIN[0] = a;
PIN[1] = b;
PIN[2] = c;
PIN[3] = d;
Serial.print("pin:   ");
Serial.print(PIN);
I get this at Serial monitor:
pin:
It doesnt show char's content
yes. Serial print does not know what you mean and decide to show a character with ASCII numbers 1 2 ...
to force print showing value as decimal number:
Serial.print(PIN[0], DEC);
Serial.print(PIN[1], DEC);
if it not to store but to be printed out, then you should convert digits to refered character
  byte a = 1;
  byte b = 2;
  byte c = 3;
  byte d = 4;
  char PIN[4];
  PIN[0] = a + 48;
  PIN[1] = b + 48;
  PIN[2] = c + 48;
  PIN[3] = d + 48;
  Serial.print(PIN);
Well, your suggestion works fine but it doesn't respond well with a library that I use, so I found out this way that works. I'll post it for anyone looking something like this.
int a = 1;
int b = 9;
int c = 9;
int d = 7;
char PIN[5];
snprintf(PIN, 5, "%d%d%d%d",  a, b, c, d);
Serial.print(PIN);
