need help for Arduino 256, TTL camera and SD card..
// This is a basic snapshot sketch using the VC0706 library.
// On start, the Arduino will find the camera and SD card and
// then snap a photo, saving it to the SD card.
// Public domain.
// If using an Arduino Mega (1280, 2560 or ADK) in conjunction
// with an SD card shield designed for conventional Arduinos
// (Uno, etc.), it’s necessary to edit the library file:
// libraries/SD/utility/Sd2Card.h
// Look for this line:
// #define MEGA_SOFT_SPI 0
// change to:
// #define MEGA_SOFT_SPI 1
// This is NOT required if using an SD card breakout interfaced
// directly to the SPI bus of the Mega (pins 50-53), or if using
// a non-Mega, Uno-style board.
#include <Adafruit_VC0706.h>
#include <SD.h>
// comment out this line if using Arduino V23 or earlier
#include <SoftwareSerial.h>
// uncomment this line if using Arduino V23 or earlier
// #include <NewSoftSerial.h>
// SD card chip select line varies among boards/shields:
// Adafruit SD shields and modules: pin 10
// Arduino Ethernet shield: pin 4
// Sparkfun SD shield: pin 8
// Arduino Mega w/hardware SPI: pin 53
// Teensy 2.0: pin 0
// Teensy++ 2.0: pin 20
#define chipSelect 53
// Pins for camera connection are configurable.
// With the Arduino Uno, etc., most pins can be used, except for
// those already in use for the SD card (10 through 13 plus
// chipSelect, if other than pin 10).
// With the Arduino Mega, the choices are a bit more involved:
// 1) You can still use SoftwareSerial and connect the camera to
// a variety of pins…BUT the selection is limited. The TX
// pin from the camera (RX on the Arduino, and the first
// argument to SoftwareSerial()) MUST be one of: 62, 63, 64,
// 65, 66, 67, 68, or 69. If MEGA_SOFT_SPI is set (and using
// a conventional Arduino SD shield), pins 50, 51, 52 and 53
// are also available. The RX pin from the camera (TX on
// Arduino, second argument to SoftwareSerial()) can be any
// pin, again excepting those used by the SD card.
// 2) You can use any of the additional three hardware UARTs on
// the Mega board (labeled as RX1/TX1, RX2/TX2, RX3,TX3),
// but must specifically use the two pins defined by that
// UART; they are not configurable. In this case, pass the
// desired Serial object (rather than a SoftwareSerial
// object) to the VC0706 constructor.
// Using SoftwareSerial (Arduino 1.0+) or NewSoftSerial (Arduino 0023 & prior):
#if ARDUINO >= 100
// On Uno: camera TX connected to pin 2, camera RX to pin 3:
//SoftwareSerial cameraconnection = SoftwareSerial(2, 3);
// On Mega: camera TX connected to pin 69 (A15), camera RX to pin 3:
SoftwareSerial cameraconnection = SoftwareSerial(51, 3);
#else
NewSoftSerial cameraconnection = NewSoftSerial(2, 3);
#endif
Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
// Using hardware serial on Mega: camera TX conn. to RX1,
// camera RX to TX1, no SoftwareSerial object is required:
//Adafruit_VC0706 cam = Adafruit_VC0706(&Serial1);
// When using hardware SPI, the SS pin MUST be set to an
// output (even if not connected or used). If left as a
// floating input w/SPI on, this can cause lockuppage.
#if !defined(SOFTWARE_SPI)
#if defined(AVR_ATmega1280) || defined(AVR_ATmega2560)
if(chipSelect != 53) pinMode(53, OUTPUT); // SS on Mega
#else
if(chipSelect != 10) pinMode(10, OUTPUT); // SS on Uno, etc.
#endif
#endif
Serial.println(“VC0706 Camera snapshot test”);
// see if the card is present and can be initialized:
//if (!SD.begin(chipSelect)) {
//Serial.println(“Card failed, or not present”);
/// don’t do anything more:
// return;
// Try to locate the camera
if (cam.begin()) {
Serial.println(“Camera Found:”);
Serial.println(“No camera found?”);
return;
// Print out the camera version information (optional)
char *reply = cam.getVersion();
if (reply == 0) {
Serial.print(“Failed to get version”);
Serial.println("-----------------");
Serial.print(reply);
// Set the picture size - you can choose one of 640x480, 320x240 or 160x120
// Remember that bigger pictures take longer to transmit!
cam.setImageSize(VC0706_640x480); // biggest
//cam.setImageSize(VC0706_320x240); // medium
//cam.setImageSize(VC0706_160x120); // small
// You can read the size back from the camera (optional, but maybe useful?)
uint8_t imgsize = cam.getImageSize();
Serial.print("Image size: ");
if (imgsize == VC0706_640x480) Serial.println(“640x480”);
if (imgsize == VC0706_320x240) Serial.println(“320x240”);
if (imgsize == VC0706_160x120) Serial.println(“160x120”);
Serial.println(“Snap in 3 secs…”);
delay(3000);
if (! cam.takePicture())
Serial.println(“Failed to snap!”);
Serial.println(“Picture taken!”);
// Create an image with the name IMAGExx.JPG
char filename[13];
strcpy(filename, “IMAGE00.JPG”);
for (int i = 0; i < 100; i++) {
filename[5] = ‘0’ + i/10;
filename[6] = ‘0’ + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
// Open the file for writing
File imgFile = SD.open(filename, FILE_WRITE);
// Get the size of the image (frame) taken
uint16_t jpglen = cam.frameLength();
Serial.print(“Storing “);
Serial.print(jpglen, DEC);
Serial.print(” byte image.”);
int32_t time = millis();
pinMode(8, OUTPUT);
// Read all the data up to # bytes!
byte wCount = 0; // For counting # of writes
while (jpglen > 0) {
// read 32 bytes at a time;
uint8_t *buffer;
uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
buffer = cam.readPicture(bytesToRead);
imgFile.write(buffer, bytesToRead);
if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn’t appear locked up
Serial.print(’.’);
wCount = 0;
//Serial.print(“Read “); Serial.print(bytesToRead, DEC); Serial.println(” bytes”);
jpglen -= bytesToRead;
imgFile.close();
time = millis() - time;
Serial.println(“done!”);
Serial.print(time); Serial.println(" ms elapsed");
Hello,
I am trying to take picture by TTL camera and store it on the SD card, but got a problem … I used the tutorial from “adafruit learning system”(TTL serial camera) but I have a bit of problem with code, if the highlight part is commented the camera seemed to take snapshot but doesn’t store it in sd card, however if I uncomment that part and try to run the whole code the serial monitor will show that the camera is not found. I can’t see where is the problem any help will be appreciate it.
Thanks…
Hello,
Thanks…
// Public domain.
// change to:
#include <SD.h>
#if ARDUINO >= 100
#else
#endif
#else
#endif
#endif
Serial.begin(38400);
// return;
if (cam.begin()) {
return;
if (reply == 0) {
delay(3000);
char filename[13];
pinMode(8, OUTPUT);
uint8_t *buffer;
Serial.print(’.’);
wCount = 0;
imgFile.close();
Please use tags when posting code, and DO NOT CROSS POST.
