i am doing arduinoscope .the program in the arduino works well.but when running processing program ,it shows error as
the func id() does not exist.
can anybody suggest any help for this please??
arduino program:
this goes on your arduino
for use with Processing example SimpleSerialArduinoscope
// holds temp vals
int val;
// set 2-12 digital pins to read mode
for (int i=2;i<14;i++){
pinMode(i, INPUT);
// read all analog ports, split by " "
for (int i=0;i<6;i++){
Serial.print(analogRead(i));
Serial.print(" ");
// read all digital ports, split by " "
Serial.print(digitalRead(i));
Serial.print(" ");
// frame is marked by LF
processing:
This is a basic serial arduinoscope.
Serial data comes in, in the format
1 23 34 4 5 76
1 23 34 4 5 76
1 23 34 4 5 76
1 23 34 4 5 76
(space seperates pin=data, LF-seperated frame data)
import arduinoscope.*;
import processing.serial.*;
// this example requires controlP5
// http://www.sojamo.de/libraries/controlP5/
import controlP5.*;
// how many scopes, you decide.
Oscilloscope[] scopes = new Oscilloscope[6];
Serial port;
ControlP5 controlP5;
PFont fontLarge;
PFont fontSmall;
int LINE_FEED=10;
int[] vals;
size(800, 800, P2D);
background(0);
controlP5 = new ControlP5(this);
// set these up under tools/create font, if they are not setup.
fontLarge = loadFont("TrebuchetMS-20.vlw");
fontSmall = loadFont("Uni0554-8.vlw");
int[] dimv = new int[2];
dimv[0] = width-130; // 130 margin for text
dimv[1] = height/scopes.length;
// setup vals from serial
vals = new int[scopes.length];
for (int i=0;i<scopes.length;i++){
int[] posv = new int[2];
posv[0]=0;
posv[1]=dimv[1]*i;
// random color, that will look nice and be visible
scopes[i] = new Oscilloscope(this, posv, dimv);
scopes[i].setLine_color(color((int)random(255), (int)random(127)+127, 255));
controlP5.addButton("pause",1,dimv[0]+10,posv[1]+10,32,20).setId(i);
controlP5.addButton("logic",1,dimv[0]+52,posv[1]+10,29,20).setId(i+50);
controlP5.addButton("save",1,dimv[0]+92,posv[1]+10,29,20).setId(i+100);
port = new Serial(this, Serial.list()[2], 115200);
// clear and wait for linefeed
port.clear();
port.bufferUntil(LINE_FEED);
void draw()
background(0);
// int[] vals = getTestValuesSquare();
// int[] vals = getTestValuesSin();
// update and draw scopes
scopes[i].addData(vals[i]);
scopes[i].draw();
// conversion multiplier for voltage
float multiplier = scopes[i].getMultiplier()/scopes[i].getResolution();
// convert arduino vals to voltage
float minval = scopes[i].getMinval() * multiplier;
float maxval = scopes[i].getMaxval() * multiplier;
int[] values = scopes[i].getValues();
float pinval = values[values.length-1] * multiplier;
// add lines
scopes[i].drawBounds();
stroke(255);
int[] pos = scopes[i].getPos();
int[] dim = scopes[i].getDim();
line(0, pos[1], width, pos[1]);
// add labels
fill(255);
textFont(fontLarge);
text(pinval, width-60, pos[1] + dim[1] - 10);
textFont(fontSmall);
text("min: " + minval, dim[0] + 10, pos[1] + 40);
text("max: " + maxval, dim[0] + 10, pos[1] + 48);
fill(scopes[i].getLine_color());
text("pin: " + i, dim[0] + 10,pos[1] + dim[1] - 10);
// draw text seperator, based on first scope
int[] dim = scopes[0].getDim();
stroke(255);
line(dim[0], 0, dim[0], height);
// update buttons
controlP5.draw();
// handles button clicks
void controlEvent(ControlEvent theEvent) {
int id = theEvent.controller().id();
// button families are in chunks of 50 to avoid collisions
if (id < 50){
scopes[id].setPause(!scopes[id].isPause());
}else if (id < 100){
scopes[id-50].setLogicMode(!scopes[id-50].isLogicMode());
}else if(id < 150){
String fname = "data"+(id-100)+".csv";
scopes[id-100].saveData(fname);
println("Saved as "+fname);
// handle serial data
void serialEvent(Serial p) {
String data = p.readStringUntil(LINE_FEED);
if (data != null) {
// println(data);
vals = int(split(data, ' '));
// for test data, you can comment, if not using
int d=0;
ControlTimer ct = new ControlTimer();
int[] getTestValuesSin(){
int[] vals = new int[scopes.length];
// this is test data
if (d==45){
d=0;
int sval = (int) abs(sin(d*2)*1023.0f);
vals[i]=sval;
d++;
return vals;
int oldtime;
int time;
boolean up=false;
int[] getTestValuesSquare(){
ct.setSpeedOfTime(25);
oldtime=time;
time = ct.second();
if (oldtime==time){
up = !up;
if (up){
vals[i]=1023;
}else{
vals[i]=0;
return vals;
SimpleSerialArduinoscope.pde (4.99 KB)
