hi guys
i want to run my code 1 mins per hour
how do i code it?
thank you
hi guys
how do i code it?
thank you
Do You know about the IDE function millis() returning the number of miliseconds since startup?
Railroader:
no i dont know, its my first time to use the ardunio code,
jremington:
https://www.baldengineer.com/blink-without-delay-explained.html
unsigned long previousMillis = 0;
unsigned long interval = 1000;
if (currentMillis - previousMillis > interval) {
sensor.read();
Serial.print....
is this right? how do i set the number for the miles?
thank you
You are on the right track. Think about using Serial.print as a debugging tool, having "Serial Monitor" activated. Set number of miles? What do You think of then?
You should probably work through some of the ready to run, simple examples that come with the Arduino IDE before tackling this project.
Files > Examples > Basics (etc.)
Railroader:
have no idea, first time to touch this code,
can i just do
previousmiles = 3540;
currentmiles= 3600;
currentmiles=0, currentmiles ++;
Nope. Did you forget your question? If so, here it is:
See reply #6. Learn to crawl before trying to run.
