Need help for communication
Hello everyone, I've a problem and I need you to resolve it,
Look my code and let's me explain my aim:
  if (Serial.available()){
 char lumi = Serial.read();
    if (lumi == 'l')
        int luminosity = analogRead(A0);
        Serial.println(luminosity);
        Serial.print("\n");
    char temp = Serial.read();
    if (temp == 't')
        int temperature_sensor = analogRead(A1);
        float mv = ( temperature_sensor/1024.0)*5000;
        float cel = mv/10;
        Serial.println(cel);
        Serial.print("\n");
So, my program consist of display the temperature or the luminosity, if I type the character t or l in the Serial Monitor. However when I write t or l, the value does not display instantly and I need to spam to display this value. It's from there that I need you to help me solve my problem.
I am waiting for your reply.
Thanks.
You see if there is serial data to read. If there is, you read a character. you see if it is a 'l'. If it is, great, you do something.
If it isn't, you read another character, and see if it is a 't'.
Does THAT make sense? If the character is NOT an 'l', well, it just might be a 't'. So, compare the character to both. Don't read again.
Hi PaulS,
Thanks for your reply, I've understand that I had to use the : if(!x).
 char info = Serial.read();
    if (info == 'l')
        Serial.print("\n");
    if (info != 'l'){
      (info == 't');
      if (info == 't');
        float cel = mv/10;
        Serial.print("\n");
It's work now
Thanks you !
if (info == 'i')
// do something
else if (info == 't')
// do something else
better still
switch (info)
  case 'i':
  // do something
  case 't':
If you haven' seen the switch .. case statement, look it up as it is useful in these situations.
