Need Help for GPS Time Output in P10 Display (Dot Matrix Display)
UKHeliBob:
That's a very short line
No. It's not a short line.
This is a P10 Display.
Now Length will be 4 Display, Width will be 4 Display.
I Think Now You Might Understand.
When I asked if you knew how to draw a line between 2 points on the display I meant a line of dots as might be used to represent the hands of an analogue clock, not a line of text
What library are you using to control the display ?
UKHeliBob:
Sorry. I didn't understand that time.
I'm using DMD2 Library.
My Code is Given Below.
// Inserting File Library
#include <SPI.h>
#include <DMD2.h>
#include <NMEAGPS.h>
#include <fonts/Arial_Black_16.h>
// PICK ONE OF THESE PORT ALTERNATIVES
// BEST: connect GPS to pins 0 & 1, since you're not using Serial.
//             Requires disconnecting pin 0 to upload new sketch over USB.
#define gpsPort Serial // just an alias for Serial
// 2nd BEST: connect GPS to pins 8 & 9 (on an UNO)
//#include <AltSoftSerial.h>
//AltSoftSerial gpsPort
// 3rd BEST:
//#include <NeoSWSerial.h>
//NeoSWSerial gpsPort(3, 4); // RX, TX
// WORST: SoftwareSerial NOT RECOMMENDED
// Defining Constants
#define Length 2
#define Width 1
// Declaration Variable
SoftDMD dmd(Length, Width);                  // Length x Width
NMEAGPS gps; // parser
  dmd.setBrightness(255);
  dmd.selectFont(Arial_Black_16);
  dmd.begin();
  dmd.clearScreen();
  gpsPort.begin(9600);
  if (gps.available( gpsPort )) {
    gps_fix fix = gps.read();
    if (fix.valid.time) {
      // UTC_ind_zone_time
      char dmdBuff[10];
      sprintf_P( dmdBuff, PSTR("%02d:%02d:%02d"),
                 fix.dateTime.hours, fix.dateTime.minutes, fix.dateTime.seconds );
      dmd.drawString(0,1,dmdBuff);
The library appears to have functions to draw shapes and lines
From DMD2.h
  void drawLine(int x1, int y1, int x2, int y2, DMDGraphicsMode mode=GRAPHICS_ON);
  void drawCircle(unsigned int xCenter, unsigned int yCenter, int radius, DMDGraphicsMode mode=GRAPHICS_ON);
  void drawBox(unsigned int x1, unsigned int y1, unsigned int x2, unsigned int y2, DMDGraphicsMode mode=GRAPHICS_ON);
  void drawFilledBox(unsigned int x1, unsigned int y1, unsigned int x2, unsigned int y2, DMDGraphicsMode mode=GRAPHICS_ON);
  void drawTestPattern(DMDTestPattern pattern);
but before you go any further you need to think about how practical it is to draw an analogue clock on a display with such a limited number of pixels. Sketch out on squared paper how you expect it to look
UKHeliBob:
From DMD2.h
This is my display for analog clock. I think its look great on this big display.
OK. That looks like a more reasonable display to use rather than the one in your previous picture.
The first thing to do is to draw a straight line on the display from say 0, 0 to 10, 10 using the drawLine() function
Over to you
UKHeliBob:
Over to you
I have a Analog Clock Code. It's in Led Matrix Display.
Can I use this program clock options code?
What should be the final code if i add this code Clock Option To My Program?
I was trying this last few days but i can't do it! :frowning:
// Comment out if using the non-SPI version of the library
#define SPIWrite
// Include the LedMatrix library
#ifdef SPIWrite
#include <LedMatrixSPI.h>
#else
#include <LedMatrix.h>
#endif
const byte NUM_ROWS = 6;               // Number of 8x8 display rows
const byte NUM_COLS = 8;               // Number of 8x8 display columns
const byte maxWidth = NUM_COLS * 8;    // Maximum display width
const byte maxHeight = NUM_ROWS * 8;   // Maximum display height
const double rads = 0.0174532925;      // Used for clock demo
 Create an LedMarix object
 The first parameter is the number of 8x8 dot matrix
 rows, the second is the number of columns.
#ifdef SPIWrite
LedMatrixSPI lm = LedMatrixSPI(NUM_ROWS, NUM_COLS);
#else
LedMatrix lm = LedMatrix(NUM_ROWS, NUM_COLS);
#endif
   int16_t sHand, mHand, hHand, center;
   uint8_t centerX = maxWidth / 2 - 1;
   uint8_t centerY = maxHeight / 2 - 1;
   // Set the start time
   int hour = 1;
   int minute = 4;
   int second = 40;
   // Set the length of each hand
   int shLen = 23;
   int mhLen = 16;
   int hhLen = 10;
   // Find the center
   if (maxWidth > maxHeight)
      center = (maxHeight / 2) - 1;
      center = (maxWidth / 2) - 1;
   // Run the clock for some amount of time
   while(1) {
      // Calculate the degree each had is pointed
      sHand = round((360 * second / 60) - 90);
      mHand = round((360 * minute / 60) - 90);
      hHand = round((360 * hour   / 12) - 90);
      lm.clear(); // Clear the LED array, but not the screen
      lm.circle(centerX, centerY, center);  // Draw the clock
      // Draw the 3 hands
      lm.line(centerX, centerY, centerX + round(shLen * cos(sHand * rads)), centerY + round(shLen * sin(sHand * rads)));
      lm.line(centerX, centerY, centerX + round(mhLen * cos(mHand * rads)), centerY + round(mhLen * sin(mHand * rads)));
      lm.line(centerX, centerY, centerX + round(hhLen * cos(hHand * rads)), centerY + round(hhLen * sin(hHand * rads)));
      lm.update();   // Update the display
      delay(975);    // Delay almost a second (leave time for program overhead)
      second++;      // Increment the seconds
      // Reset seconds and increment minutes
      if (second > 59) {
         second = 0;
         minute++;
      // Reset minutes and increment hours
      if (minute > 59) {
         minute = 0;
         hour++;
      // Reset hours
      if (hour > 11) {
         hour = 0;
Sisir_Raihan:
#define SPIWrite
#ifdef SPIWrite
#else
#endif
#ifdef SPIWrite
#else
#endif
  int hour = 1;
  int minute = 4;
  int second = 40;
  int shLen = 23;
  int mhLen = 16;
  int hhLen = 10;
// Find the center
  while(1) {
// Draw the 3 hands
      if (second > 59) {
        second = 0;
        minute++;
      if (minute > 59) {
        minute = 0;
        hour++;
      // Reset hours
      if (hour > 11) {
        hour = 0;
Can Anyone Help me doing this program? :frowning:
