Need help for GSM code combine with receiver code
Hi Guys,
I'm here to ask how to combine both GSM code with receiver code together. There's something wrong with receiver code inside the void loop function.
Kindly help me thank you.
// Include the GSM library
#include <GSM.h>
#include <VirtualWire.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
char remoteNumber[20]= "+86xxxxxxxx"; // number that you want to send a SMS
// Pins definition
const int led_pin = 7;
const int receive_pin = 6;
int pinSpeaker = 5;
int bb;
char txtMsg[200]="Hi COOL press the switch";
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
     Serial.begin(9600); // Debugging only
   // Initialise the IO and ISR
   vw_set_rx_pin(receive_pin);
   vw_setup(4000); // Transmission rate
   // Start the receiver PLL
   vw_rx_start();
   // Set LED pin and Buzzer
   pinMode(led_pin, OUTPUT);
   pinMode(pinSpeaker, OUTPUT);
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while (notConnected)
    if (gsmAccess.begin(PINNUMBER) == GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
   //SendSMS(); //SendSMS
 //send the message
 bb=digitalRead(6);
 if(bb==LOW) {
    uint8_t buf[VW_MAX_MESSAGE_LEN];
   uint8_t buflen = VW_MAX_MESSAGE_LEN;
   // Check if a message was received
    if (vw_get_message(buf, &buflen))
      if(buf[0]=='1')
      Serial.println("Motion detected!");
      digitalWrite(led_pin,1);
      playTone(300, 160);
      delay(150);
      Serial.println("the message will be send"); //
      delay(2000); //
      sms.beginSMS(remoteNumber); //
      sms.print(txtMsg); //
      sms.endSMS(); //
      delay(10000); //
    Serial.println("no message");
delay(2000);
     if(buf[0]=='0')
     Serial.println("Motion ended!");
     digitalWrite(led_pin,0);
     playTone(0, 0);
     delay(300);
void SendSMS()
 Serial.print("Enter a mobile number: ");
  char remoteNum[20];  // telephone number to send sms
  readSerial(remoteNum);
  Serial.println(remoteNum);
  // sms text
  Serial.print("Now, enter SMS content: ");
  char txtMsg[200];
  readSerial(txtMsg);
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtMsg);
  // send the message
  sms.beginSMS(remoteNum);
  sms.print(txtMsg);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
  Read input serial
int readSerial(char result[])
  int i = 0;
  while (1)
    while (Serial.available() > 0)
      char inChar = Serial.read();
      if (inChar == '\n')
        result[i] = '\0';
        Serial.flush();
        return 0;
      if (inChar != '\r')
        result[i] = inChar;
        i++;
// duration in mSecs, frequency in hertz
void playTone(long duration, int freq)
    duration *= 1000;
    int period = (1.0 / freq) * 1000000;
    long elapsed_time = 0;
    while (elapsed_time < duration)
    digitalWrite(pinSpeaker,HIGH);
    delayMicroseconds(period / 2);
    digitalWrite(pinSpeaker, LOW);
    elapsed_time += (period);
  while (!Serial) {
   vw_rx_start();
WTF? Why are you doing all that stuff, over and over, while waiting for the Serial port to be ready? Do you even HAVE a Leonardo?
 bb=digitalRead(6);
 if(bb==LOW) {
LOW means pressed only if you have a pullup resistor. You are not using the internal pullup resistor, so you need an external one. Do you have one? Why? What was wrong with the internal one?
delay(2000);
     if(buf[0]=='0')
There was no message, so let's see if the first character in the non-existent message is '0'. Why? What were you smoking when you wrote this mess?
Since you know that there is a problem, you should be able to explain what the problem is. Otherwise, you're just blowing smoke.
