hi,
I am a beginner can you help me use this code as but modify it so that it uses 3 multiplexers the model i am using is model number cd744067
here: :https://fr.aliexpress.com/item/32858973834.html?gatewayAdapt=glo2fra&spm=a2g0o.9042311.0.0.154c6c37NGCiR8
If you can show me how to make this code work that would be great thanks.
here is code taken from
Based on Sketch built by Gustavo Silveira (aka Music Nerd)
Modified by Dolce Wang
This code is only for Arduinos that use ATmega32u4 (like Micro, Pro Micro, Leonardo...)
Remember to also assign the correct board in the IDE (like Tools / Boards / Sparkfun AVR / Pro Micro...)
// Change any fields with //**
// LIBRARY
#include "MIDIUSB.h"
// BUTTONS
const int NButtons = 4; //*** total number of buttons
const int buttonPin[NButtons] = {2, 3, 5, 7}; //*** define Digital Pins connected from Buttons to Arduino; (ie {10, 16, 14, 15, 6, 7, 8, 9, 2, 3, 4, 5}; 12 buttons)
int buttonCState[NButtons] = {}; // stores the button current value
int buttonPState[NButtons] = {}; // stores the button previous value
// debounce
unsigned long lastDebounceTime[NButtons] = {0}; // the last time the output pin was toggled
unsigned long debounceDelay = 50; //** the debounce time; increase if the output flickers
// POTENTIOMETERS
const int NPots = 8; //*** total number of pots (knobs and faders)
const int potPin[NPots] = {A9, A8, A7, A6, A3, A2, A1, A0}; //*** define Analog Pins connected from Pots to Arduino; Leave nothing in the array if 0 pots {}
int potCState[NPots] = {0}; // Current state of the pot; delete 0 if 0 pots
int potPState[NPots] = {0}; // Previous state of the pot; delete 0 if 0 pots
int potVar = 0; // Difference between the current and previous state of the pot
int midiCState[NPots] = {0}; // Current state of the midi value; delete 0 if 0 pots
int midiPState[NPots] = {0}; // Previous state of the midi value; delete 0 if 0 pots
const int TIMEOUT = 300; //* Amount of time the potentiometer will be read after it exceeds the varThreshold
const int varThreshold = 10; //* Threshold for the potentiometer signal variation
boolean potMoving = true; // If the potentiometer is moving
unsigned long PTime[NPots] = {0}; // Previously stored time; delete 0 if 0 pots
unsigned long timer[NPots] = {0}; // Stores the time that has elapsed since the timer was reset; delete 0 if 0 pots
// MIDI Assignments
byte midiCh = 1; //* MIDI channel to be used
byte note = 36; //* Lowest note to be used; 36 = C2; 60 = Middle C
byte cc = 1; //* Lowest MIDI CC to be used
// SETUP
// Baud Rate
// 31250 for MIDI class compliant | 115200 for Hairless MIDI
// Buttons
// Initialize buttons with pull up resistors
for (int i = 0; i < NButtons; i++) {
pinMode(buttonPin[i], INPUT_PULLUP);
// LOOP
buttons();
potentiometers();
// BUTTONS
void buttons() {
buttonCState[i] = digitalRead(buttonPin[i]); // read pins from arduino
if ((millis() - lastDebounceTime[i]) > debounceDelay) {
if (buttonPState[i] != buttonCState[i]) {
lastDebounceTime[i] = millis();
if (buttonCState[i] == LOW) {
// Sends the MIDI note ON
// use if using with ATmega32U4 (micro, pro micro, leonardo...)
noteOn(midiCh, note + i, 127); // channel, note, velocity
MidiUSB.flush();
else {
// Sends the MIDI note OFF accordingly to the chosen board
noteOn(midiCh, note + i, 0); // channel, note, velocity
MidiUSB.flush();
buttonPState[i] = buttonCState[i];
// POTENTIOMETERS
void potentiometers() {
for (int i = 0; i < NPots; i++) { // Loops through all the potentiometers
potCState[i] = analogRead(potPin[i]); // reads the pins from arduino
midiCState[i] = map(potCState[i], 0, 1023, 0, 127); // Maps the reading of the potCState to a value usable in midi
potVar = abs(potCState[i] - potPState[i]); // Calculates the absolute value between the difference between the current and previous state of the pot
if (potVar > varThreshold) { // Opens the gate if the potentiometer variation is greater than the threshold
PTime[i] = millis(); // Stores the previous time
timer[i] = millis() - PTime[i]; // Resets the timer 11000 - 11000 = 0ms
if (timer[i] < TIMEOUT) { // If the timer is less than the maximum allowed time it means that the potentiometer is still moving
potMoving = true;
else {
potMoving = false;
if (potMoving == true) { // If the potentiometer is still moving, send the change control
if (midiPState[i] != midiCState[i]) {
// Sends MIDI CC
// Use if using with ATmega32U4 (micro, pro micro, leonardo...)
controlChange(midiCh, cc + i, midiCState[i]); // (channel, CC number, CC value)
MidiUSB.flush();
potPState[i] = potCState[i]; // Stores the current reading of the potentiometer to compare with the next
midiPState[i] = midiCState[i];
// if using with ATmega32U4 (micro, pro micro, leonardo...)
// Arduino MIDI functions MIDIUSB Library
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
void controlChange(byte channel, byte control, byte value) {
midiEventPacket_t event = {0x0B, 0xB0 | channel, control, value};
MidiUSB.sendMIDI(event);
