Need help for mapping and edge detection for traversing of my robot.
My bot consists of 3 IR sensor,two fixed in two sides f the front and one on the servomotor at the middle top. I wrote this arduino program to detect a gap among some obstacles for my bot to pass through. Please tel me where i am going wrong or whether my logic s correct or not???
#include <Servo.h>
Servo myservo;
int pos=0;
int dist[17];
int STBY = 10;
int PWMA = 3;
int AIN1 = 9;
int AIN2 = 8;
int PWMB = 5;
int BIN1 = 11;
int BIN2 = 12;
int sensorpin1 = 0;
int sensorpin2 = 5;
int sensorpin3 = 5;
myservo.attach(9);
pinMode(STBY,OUTPUT);
pinMode(PWMA,OUTPUT);
pinMode(AIN1,OUTPUT);
pinMode(AIN2,OUTPUT);
pinMode(PWMB,OUTPUT);
pinMode(BIN1,OUTPUT);
pinMode(BIN2,OUTPUT);
int obstacle=20;
int direction();
int distance(int val);
int d;
scan();
/* d=direction();
switch(d)
case 1: left();
case 2: forward();
case 3: right();
case 4: ultimatebackward();
void scan()
int i;
for(pos=0, i=0; pos<=180; pos+=10,i++)
myservo.write(pos);
dist*=distance(analogRead(sensorpin3));*
  • delay(100);*
    _ if(dist*<20)_
    _
    {_
    _ dist=0;
    else*
    dist*=1;
    for(pos=180,i=17; pos>=0; pos-=10,i–)
    myservo.write(pos);*_
_ dist*=distance(analogRead(sensorpin3));
delay(100);
if(dist<20)
dist=0;
else*
dist*=1;
int direction()
{*_
* int count1,count2,newcount,pos1,pos2;*
* for(int i=1;i<=17;i++)*
_ if(dist*==0)
if(dist[i-1]==0)
count1++;
else*
pos=i;
count2=count1;
count1=0;
count1++;
if(count2>newcount)
newcount=count2;
count2=0;
}*_
* pos2=pos1+newcount-1;*
* if((0<=pos1<=5)&&(0<=pos2<=5))*
* return(1);*
* else*
* if((6<=pos1<=11)&&(6<=pos2<=11))*
* return(2);*
* else*
* if((12<=pos1<=17)&&(12<=pos2<=17))*
* return(3);*
* else*
* if((0<=pos1<=5)&&(6<=pos2<=11)&&((5-pos1)<(pos2-5)))*
* return(2);*
* else*
* if((0<=pos1<=5)&&(6<=pos2<=11)&&((5-pos1)>(pos2-5)))*
* return(1);*
* else*
* if((5<=pos1<=11)&&(12<=pos2<=17)&&((11-pos1)>(pos2-11)))*
* return(1);*
* else*
* if((5<=pos1<=11)&&(12<=pos2<=17)&&((11-pos1)<(pos2-11)))*
* return(3);*
* else*
* return(4);*
* int distance(int val)*
* int dis;*
* //dis=(2914 / (val + 5)) - 1;*
* dis=2076/(val-11);*
* //Serial.println(dis);*
* return dis;*
* void forward()*
* int dist2,dist3;*
* dist2=analogRead(sensorpin1);*
* while(obstacle>dist2)*
* stop();*
* backward();*
* right();*
* dist3=analogRead(sensorpin2);*
* while(obstacle>dist3)*
* stop();*
* backward();*
* left();*
* digitalWrite(STBY,HIGH);*
* digitalWrite(AIN1,LOW);*
* digitalWrite(AIN2,HIGH);*
* digitalWrite(BIN1,LOW);*
* digitalWrite(BIN2,HIGH);*
* analogWrite(PWMA,200);*
* analogWrite(PWMB,200);*
* delay(500);*
* void backward()*
* digitalWrite(AIN1,HIGH);*
* digitalWrite(AIN2,LOW);*
* digitalWrite(BIN1,HIGH);*
* digitalWrite(BIN2,LOW);*
* delay(250);*
* void right()*
* delay(500);*
* stop();*
* void left()*
* delay(500);*
* stop();*
* void ultimatebackward()*
* delay(250);*
* delay(2000);*
* void stop()*
* digitalWrite(STBY,LOW);*
* delay(10);*
Now, without italics, please.
i have attached the code …
mapping.ino (4.74 KB)
#include  <Servo.h>
Servo myservo;
int pos=0;
int dist[17];
int STBY = 10;
int PWMA = 3;
int AIN1 = 9;
int AIN2 = 8;
int PWMB = 5;
int BIN1 = 11;
int BIN2 = 12;
int sensorpin1 = 0;
int sensorpin2 = 5;
int sensorpin3 = 5;
  myservo.attach(9);
int obstacle=20;
int direction();
   int d;
   scan();
  /* d=direction();
   switch(d)
     case 1: left();
     case 2: forward();
     case 3: right();
  void scan()
    int i;
     myservo.write(pos);
    dist[i]=distance(analogRead(sensorpin3));
     delay(100);
     if(dist[i]<20)
       dist[i]=0;
     dist[i]=1;
    for(pos=180,i=17; pos>=0; pos-=10,i--)
     myservo.write(pos);
      delay(100);
     if(dist[i]<20)
       dist[i]=0;
     dist[i]=1;
  int direction()
          if(dist[i]==0)
            if(dist[i-1]==0)
              count1++;
              pos=i;
              count2=count1;
              count1=0;
              count1++;
               if(count2>newcount)
                    newcount=count2;
                    count2=0;
          return(1);
          return(2);
          return(3);
          return(2);
          return(1);
          return(1);
          return(3);
        return(4);
         int dis;
        dis=2076/(val-11);
       return dis;
   void forward()
       int dist2,dist3;
         stop();
         backward();
         right();
         stop();
         backward();
         left();
  void backward()
       delay(250);
  void right()
       stop();
  void left()
       stop();
       delay(250);
       delay(2000);
   void stop()
       delay(10);
Why don’t you tell us if the code works, or not?
This, of course, is rubbish. Comparing the value of true (if pos1 is positive) or false (if pos1 is negative) to 5 is pointless.
int dist[17];
     myservo.write(pos);
