Need help for modifying project code (pro mini arduino IO22D08)
hellow every one, could you please hepl me to solve my issue, i have pro mini delay relay (IO22D08), i tryed to modify the code in order to make it work as power sequencer: if i cinnect GND to IN1 the 1st relay will be ON and display CH01 the it will be OFF for 3 seconds,then the 2nd relay ON for 1 second and display CH02 then OFF for 3s,unitl the 8TH relay ,then the system reboot forever. code and scematic in attach.
//for Arduino pro mini
/*---Segment Display Screen----
--A--
F---B
--G--
E---C
--D--
__  __   __  __
|__||__|.|__||__|
|__||__|'|__||__|
#include <FlexiTimer2.h>
#define uchar unsigned char
#define uint  unsigned int
int display_dat;
int key_value;
//Pin connected to latch of Digital Tube Module
int latchPin = A2;
//Pin connected to clock of Digital Tube Module
int clockPin = A3;
//Pin connected to data of Digital Tube Module
int dataPin = 13;
//Pin connected to 595_OE of Digital Tube Module
int OE_595 = A1;
const int K1 = 7;
const int K2 = 8;
const int K3 = 9;
const int K4 = 10;
const int INPUT1 = 2;
const int INPUT2 = 3;
const int INPUT3 = 4;
const int INPUT4 = 5;
const int INPUT5 = 6;
const int INPUT6 = A0;
const int INPUT7 = 12;
const int INPUT8 = 11;
int relay1_delay_time = 1;//1-9999 seconds,Modify the number change delay time
int relay2_delay_time = 2;
int relay3_delay_time = 3;
int relay4_delay_time = 4;
int relay5_delay_time = 5;
int relay6_delay_time = 6;
int relay7_delay_time = 7;
int relay8_delay_time = 8;
int relay1_time_left;
int relay2_time_left;
int relay3_time_left;
int relay4_time_left;
int relay5_time_left;
int relay6_time_left;
int relay7_time_left;
int relay8_time_left;
int relay1_display;
int relay2_display;
int relay3_display;
int relay4_display;
int relay5_display;
int relay6_display;
int relay7_display;
int relay8_display;
/* NO.:0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22 23 24 25 26 27 28
/*Character :0,1,2,3,4,5,6,7,8,9,A, b, C, c, d, E, F, H, h, L, n, N, o, P, r, t, U, -,  ,*/
uchar  TUBE_SEG[] =
{0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90, 0x88, 0x83, 0xc6, 0xa7, 0xa1, 0x86, 0x8e, 0x89, 0x8b, 0xc7, 0xab, 0xc8, 0xa3, 0x8c, 0xaf, 0x87, 0xc1, 0xbf, 0xff}; //Common anode Digital Tube Character Gallery
uchar TUBE_NUM[8] = {0xfe, 0xff, 0xfd, 0xff, 0xfb, 0xff, 0xf7, 0xff,}; //Tuble bit number
uchar dat_buf[8];
// dat : Data to be displayed
// com_num :  Digital Tube Common
//relay_port : Relay port
uchar dat;
uchar com_num;
uchar relay_port;
void TubeDisplayOneBit()
uchar tube_dat, bit_num;
uchar display_l, display_h, relay_dat;
tube_dat = TUBE_SEG[dat]; //Common Cathode Digital Tube,bit negated
bit_num = ~TUBE_NUM[com_num];
display_l  = ((tube_dat & 0x10) >> 3); //Q4   <-D1 -3
display_l |= ((bit_num & 0x01) << 2); //DIGI0<-D2 +2
display_l |= ((tube_dat & 0x08) >> 0); //Q3   <-D3 0
display_l |= ((tube_dat & 0x01) << 4); //Q0   <-D4 -4
display_l |= ((tube_dat & 0x80) >> 2); //Q7   <-D5 -2
display_l |= ((tube_dat & 0x20) << 1); //Q5   <-D6 1
display_l |= ((tube_dat & 0x04) << 5); //Q2   <-D7 5
display_h  = ((bit_num & 0x02) >> 0); //DIGI1<-D1 0
display_h |= ((bit_num & 0x04) >> 0); //DIGI2<-D2 0
display_h |= ((tube_dat  & 0x40) >> 3); //Q6   <-D3 -3
display_h |= ((tube_dat  & 0x02) << 3); //Q1   <-D4 3
display_h |= ((bit_num & 0x08) << 2); //DIGI3<-D5 2
relay_dat = ((relay_port & 0x7f) << 1);
relay_dat = relay_dat | ((relay_port & 0x80) >> 7);
//ground latchPin and hold low for as long as you are transmitting
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, MSBFIRST, display_h);
shiftOut(dataPin, clockPin, MSBFIRST, display_l);
shiftOut(dataPin, clockPin, MSBFIRST, relay_dat);
//return the latch pin high to signal chip that it
//no longer needs to listen for information
digitalWrite(latchPin, HIGH);
uint OneSecondCnt = 500;
void TubeDisplay4Bit(void)
if (com_num < 7) com_num ++; else com_num = 0;
dat = dat_buf[com_num];
TubeDisplayOneBit();
OneSecondCnt--;
if (OneSecondCnt == 0)
 OneSecondCnt = 500;
 if (relay1_time_left > 0) {
   relay1_time_left--;
   relay1_display = relay1_time_left;
   bitClear(relay_port, 0);
   relay1_display = relay1_delay_time;
 if (relay2_time_left > 0) {
   relay2_time_left--;
   relay2_display = relay2_time_left;
   bitClear(relay_port, 1);
   relay2_display = relay2_delay_time;
 if (relay3_time_left > 0) {
   relay3_time_left--;
   relay3_display = relay3_time_left;
   bitClear(relay_port, 2);
   relay3_display = relay3_delay_time;
 if (relay4_time_left > 0) {
   relay4_time_left--;
   relay4_display = relay4_time_left;
   bitClear(relay_port, 3);
   relay4_display = relay4_delay_time;
 if (relay5_time_left > 0) {
   relay5_time_left--;
   relay5_display = relay5_time_left;
   bitClear(relay_port, 4);
   relay5_display = relay5_delay_time;
 if (relay6_time_left > 0) {
   relay6_time_left--;
   relay6_display = relay6_time_left;
   bitClear(relay_port, 5);
   relay6_display = relay6_delay_time;
 if (relay7_time_left > 0) {
   relay7_time_left--;
   relay7_display = relay7_time_left;
   bitClear(relay_port, 6);
   relay7_display = relay7_delay_time;
 if (relay8_time_left > 0) {
   relay8_time_left--;
   relay8_display = relay8_time_left;
   bitClear(relay_port, 7);
   relay8_display = relay8_delay_time;
if (key_value == 0) display_dat = relay1_display;
else if (key_value == 1) display_dat = relay2_display;
else if (key_value == 2) display_dat = relay3_display;
else if (key_value == 3) display_dat = relay4_display;
 if(key_value==0) display_dat = relay5_display;
 else if(key_value==1) display_dat = relay6_display;
 else if(key_value==2) display_dat = relay7_display;
 else if(key_value==3) display_dat = relay8_display;
dat_buf[0] = display_dat / 1000;
display_dat = display_dat % 1000;
dat_buf[2] = display_dat / 100;
display_dat = display_dat % 100;
dat_buf[4] = display_dat / 10;
dat_buf[6] = display_dat % 10;
//set pins to output because they are addressed in the main loop
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(OE_595, OUTPUT);
pinMode(K1, INPUT);
pinMode(K2, INPUT);
pinMode(K3, INPUT);
pinMode(K4, INPUT);
pinMode(INPUT1, INPUT);
pinMode(INPUT2, INPUT);
pinMode(INPUT3, INPUT);
pinMode(INPUT4, INPUT);
pinMode(INPUT5, INPUT);
pinMode(INPUT6, INPUT);
pinMode(INPUT7, INPUT);
pinMode(INPUT8, INPUT);
FlexiTimer2::set(2, 1.0 / 1000, TubeDisplay4Bit); // call every 2ms "ticks"
FlexiTimer2::start();
digitalWrite(OE_595, LOW);// Enable 74HC595
digitalWrite(INPUT1, HIGH);
digitalWrite(INPUT2, HIGH);
digitalWrite(INPUT3, HIGH);
digitalWrite(INPUT4, HIGH);
digitalWrite(INPUT5, HIGH);
digitalWrite(INPUT6, HIGH);
digitalWrite(INPUT7, HIGH);
digitalWrite(INPUT8, HIGH);
digitalWrite(K1, HIGH);
digitalWrite(K2, HIGH);
digitalWrite(K3, HIGH);
digitalWrite(K4, HIGH);
key_value = 0;
while (1)
 if (digitalRead(INPUT1) == LOW) {
   relay1_time_left = relay1_delay_time;
   bitSet(relay_port, 0);
 if (digitalRead(INPUT2) == LOW) {
   relay2_time_left = relay2_delay_time;
   bitSet(relay_port, 1);
 if (digitalRead(INPUT3) == LOW) {
   relay3_time_left = relay3_delay_time;
   bitSet(relay_port, 2);
 if (digitalRead(INPUT4) == LOW) {
   relay4_time_left = relay4_delay_time;
   bitSet(relay_port, 3);
 if (digitalRead(INPUT5) == LOW) {
   relay5_time_left = relay5_delay_time;
   bitSet(relay_port, 4);
 if (digitalRead(INPUT6) == LOW) {
   relay6_time_left = relay6_delay_time;
   bitSet(relay_port, 5);
 if (digitalRead(INPUT7) == LOW) {
   relay7_time_left = relay7_delay_time;
   bitSet(relay_port, 6);
 if (digitalRead(INPUT8) == LOW) {
   relay8_time_left = relay8_delay_time;
   bitSet(relay_port, 7);
 if     (digitalRead(K1) == LOW) {
   key_value = 0;
 else if (digitalRead(K2) == LOW) {
   key_value = 1;
 else if (digitalRead(K3) == LOW) {
   key_value = 2;
 else if (digitalRead(K4) == LOW) {
   key_value = 3;
(NEXT Post use the code tags button, </> on the menu, and paste your code in the box that opens. Thanks! Moderator)
_8ch_delay_relay.ino (8.37 KB)
FlexiTimer2.h (518 Bytes)
keywords.txt (63 Bytes)
FlexiTimer2.cpp (6.36 KB)
8ch_Pro_Mini_delay_relay(Schematic).pdf (619 KB)
IO22D08 8ch Pro mini PLC Instructions.pdf (1.07 MB)
Well done using code tags in Your first topic. If You would use the Autoformat function in the IDE before copying the code it would be a lot easier to read.
You will need really costly relays to survive switching at second intervalls for long. Every relay has a lifetime of a certain number of "make".
What is actually happening now?
Link to the relays?
Nice wiring diagram but it's not readable due to all the air making pin names very small. Lots of zooming needed and then the overview is lost.
hello,thanks for reply;
Now when i connect :
  • GND to IN1 and release : relay1 switch ON for 1 second then swith OFF
  • GND to IN2 and release: relay 2 switch ON for 2 second then swith OFF
  • GND to IN3 and release: relay 3 switch ON for 3 second then swith OFF
  • GND to IN4 and release: relay 4 switch ON for 4 second then swith OFF
  • GND to IN5 and release: relay 5 switch ON for 5 second then swith OFF
  • GND to IN6 and release: relay 6 switch ON for 6 second then swith OFF
  • GND to IN7 and release: relay 7 switch ON for 7 second then swith OFF
  • GND to IN8 and release: relay 8 switch ON for 8 second then swith OFF
Okey. And what do You want to happen, expressed this way?
