Need help for my audio project
Can anyone help me, please? In my project, two Arduinos will be used. The second Arduino should receive from the first Arduino the information which sound frequency it should now generate via a 4 bit R2R DAC. The correct transmission of the frequency works. The DAC also works perfectly. However, only individually tested. But it doesn't work both at the same time. What could be the problem?
Thank you in advance.
This is the sketch from the second Arduino:
Arrggghhhh ... A screenshot of your code!
Please could you take the time to read the forum guidelines. They are pinned at the top of this very section of the forum.
to be more specific about posting code
When you figure out how to post, don't forget to include both send and receive sketches.
