Need help for project, 4leds controlled by touch with Arduino or Bare conductiv
I need help in project that consists 4 capacitive ink touch sensors and 4 leds.
Each sensor should control led by touching it.
Do you have any ideas about code and connection?
Important things:
  1. I would like to avoid using mpr121
  2. I want to make it as simple as possible
  3. I can use MAX7219 and FDC2214
  4. Do you have any ideas how to use Bare Condutive to control this project?
I would be grateful for any help
Duplicate topics in different sections merged
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Merged yet another duplicate from another forum section
What is that?
PaulRB:
What is that?
Some sort of touch sensor with a guard rail I would say. Along with some random piece of debris. :grinning:
akrz:
Then you have absolutely shot yourself in the foot!
That is the immediately obvious solution to your problem if you propose to involve an Arduino. :sunglasses:
Or the TTP223 which would in fact, be the simplest possible solution as it can control the LED by itself with no need for an Arduino. :roll_eyes:
Do you perhaps need to explain your actual project more fully? :astonished:
