Hello, everyone, I hope you may help me in my robot car project of a security robot car with aligned SDGs. Its function is to detect and roam around surroundings, acting similar to a police car. Basically its specific components are: ultrasonic sensor, servo motor, buzzer, DC motors, lcd module, rgb led, thermistor (heat detection), photoresistor (light detection), level shifter, and ps4 controller. It's main components are: Arduino UNO, Adafruit Motorshield v1, and ESP32 w/ CAM module. To add, there's no cam in the esp32 since the robot's too complex as it is.
I just need help because the problem is the robot is not moving, especially the fact that there is serious trouble in connecting the esp32 with the arduino UNO. Even if I finally managed to connect them both with a long serious effort, the problem persists with the robot not fulfilling its commands as the Arduino's serial monitor does not act; this goes back with the original problem of the connection between arduino and esp32.
Also, I've managed to at least connect successfully the ps4 controller and the esp32, and I have already planned several command buttons for the robot function.
Please help me fix this code. I'm already quite dying before being able to manage fixing this robot.
Arduino UNO code
#include <Servo.h>
#include <Wire.h>
#include <AFMotor.h>
#include <SoftwareSerial.h>
// RX = 8, TX = 9
SoftwareSerial EspSerial(8, 9); // RX, TX
// Pin Definitions
const int BUZZER_PIN = 7;
const int LED_R_PIN = 3;
const int LED_G_PIN = 5;
const int LED_B_PIN = 6;
const int SERVO_PIN = 10;
// Sensor Pins
const int PHOTORESISTOR_PIN = 2;
const int THERMISTOR_PIN = 4;
const int ULTRASONIC_TRIGGER_PIN = A2;
const int ULTRASONIC_ECHO_PIN = A3;
Servo ultrasonicServo;
LiquidCrystal_I2C lcd(0x27, 16, 2);
bool sdgModeActive = false;
bool intruderModeActive = false;
bool obstacleDetected = false; // for off when robot is on
unsigned long lastMoveTime = 0;
int roamingState = 0;
// Motor Speed
int motorSpeed = 128;
bool ramModeActive = false;
// Thresholds
const int HIGH_TEMP_THRESHOLD = 40; // Temperature threshold in Celsius
const int dangerDistance = 15; // Distance in cm, adjust as needed
const int lightThreshold = 200; // Adjust based on your sensor range
long duration;
int distance;
// Define motors
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
Serial.begin(19200);
pinMode(BUZZER_PIN, OUTPUT);
pinMode(LED_R_PIN, OUTPUT);
pinMode(LED_G_PIN, OUTPUT);
pinMode(LED_B_PIN, OUTPUT);
pinMode(PHOTORESISTOR_PIN, INPUT);
pinMode(THERMISTOR_PIN, INPUT);
ultrasonicServo.attach(SERVO_PIN);
ultrasonicServo.write(90);
Wire.begin(); // Uses A4 (SDA) and A5 (SCL)
lcd.init();
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Waiting...");
pinMode(ULTRASONIC_TRIGGER_PIN, OUTPUT);
pinMode(ULTRASONIC_ECHO_PIN, INPUT);
if (EspSerial.available()) {
String command = EspSerial.readStringUntil('\n');
command.trim();
handleCommand(command);
if (sdgModeActive) {
roamAutomatically();
if (intruderModeActive) {
monitorIntruder();
checkSensors();
// --- Handle incoming ESP32 commands ---
void handleCommand(String cmd) {
if (cmd.startsWith("SERVO:")) {
int angle = cmd.substring(6).toInt();
ultrasonicServo.write(angle);
else if (cmd == "COMMAND: SDG_MODE_ON") {
sdgModeActive = true;
lcd.clear();
lcd.print("SDG Mode ON");
beep();
setLEDColor(0, 255, 0);
else if (cmd == "COMMAND: SDG_MODE_OFF") {
lcd.clear();
lcd.print("Manual Mode");
beep();
setLEDColor(255, 255, 255);
else if (cmd == "COMMAND: INTRUDER_MODE_ON") {
intruderModeActive = true;
lcd.clear();
lcd.print("Guard Mode");
beep();
setLEDColor(255, 0, 0);
else if (cmd == "COMMAND: INTRUDER_MODE_OFF") {
lcd.clear();
beep();
else if (cmd == "COMMAND: MANUAL_MODE") {
lcd.clear();
beep();
else if (cmd == "COMMAND: BUZZER_BEEP") {
beep();
else if (cmd == "COMMAND: LED_BLINK") {
blinkLED();
else {
if (!sdgModeActive && !intruderModeActive) {
handleManualDrive(cmd);
// --- Simulated roaming movement ---
void roamAutomatically() {
unsigned long now = millis();
if (now - lastMoveTime > 2000) {
lastMoveTime = now;
roamingState = (roamingState + 1) % 4;
switch (roamingState) {
case 0:
moveForward();
case 1:
rotateLeft();
case 2:
moveForward();
case 3:
rotateRight();
// --- Intruder Monitoring ---
void monitorIntruder() {
distance = readUltrasonic();
if (distance < 20) {
lcd.clear();
lcd.print("Intruder Detected!");
beep();
moveBackward();
rotateLeft();
stopMoving();
// No intruder and no other warnings – turn off LCD display
lcd.clear();
float getTemperature(int analogValue) {
float voltage = analogValue * 5.0 / 1023.0;
float resistance = (5.0 - voltage) * 10000.0 / voltage;
float tempK = 1.0 / (log(resistance / 10000.0) / 3950.0 + (1.0 / 298.15));
return tempK - 273.15;
int getDistance() {
digitalWrite(ULTRASONIC_TRIGGER_PIN, LOW);
delayMicroseconds(2);
digitalWrite(ULTRASONIC_TRIGGER_PIN, HIGH);
delayMicroseconds(10);
long duration = pulseIn(ULTRASONIC_ECHO_PIN, HIGH);
return duration * 0.034 / 2;
void setColor(int r, int g, int b) {
analogWrite(LED_R_PIN, r);
analogWrite(LED_G_PIN, g);
analogWrite(LED_B_PIN, b);
// --- Sensor Checks ---
void checkSensors() {
// Example for a multi-sensor system (temperature + light + distance)
// --- Temperature Monitoring ---
int digitalTemp = digitalRead(4); // Assume A0 for thermistor
float temperature = getTemperature(digitalTemp);
if (temperature >= HIGH_TEMP_THRESHOLD) {
lcd.print("TEMP ALERT: ");
lcd.print(temperature);
lcd.print("C ");
lcd.setCursor(0, 1);
lcd.print("High Heat Level");
// High temp: rapid purple flashing + buzzer
tone(BUZZER_PIN, 1000);
digitalWrite(LED_R_PIN, HIGH);
digitalWrite(LED_B_PIN, HIGH);
digitalWrite(LED_G_PIN, LOW);
delay(100);
noTone(BUZZER_PIN);
digitalWrite(LED_R_PIN, LOW);
digitalWrite(LED_B_PIN, LOW);
delay(100);
// --- Light Intrusion Detection ---
int lightValue = digitalRead(2);
if (lightValue > lightThreshold) {
lcd.print("INTRUDER ALERT ");
lcd.print("Bright Light ");
for (int i = 0; i < 5; i++) {
digitalWrite(BUZZER_PIN, HIGH);
delay(100);
digitalWrite(BUZZER_PIN, LOW);
delay(100);
// --- Ultrasonic Distance Alert ---
int distance = getDistance();
if (distance > 0 && distance <= dangerDistance) {
lcd.print("MOTION DETECTED ");
lcd.print("Dist: ");
lcd.print(distance);
lcd.print(" cm ");
for (int i = 0; i < 3; i++) {
setColor(255, 0, 0); // Red
delay(150);
setColor(0, 0, 0); // Off
delay(150);
// --- Normal State ---
if (temperature < HIGH_TEMP_THRESHOLD && lightValue <= lightThreshold && (distance > dangerDistance || distance <= 0)) {
lcd.print("Monitoring... ");
lcd.print("All Normal ");
noTone(BUZZER_PIN);
setColor(0, 255, 0); // Green
// --- Helper Functions ---
void beep() {
delay(100);
void setLEDColor(int r, int g, int b) {
void blinkLED() {
setLEDColor(255, 255, 0);
delay(100);
setLEDColor(0, 0, 0);
delay(100);
delay(100);
long readUltrasonic() {
long duration = pulseIn(ULTRASONIC_ECHO_PIN, HIGH, 20000);
void moveForward() {
if (obstacleDetected && !ramModeActive) {
stopMoving();
return;
setAllMotors(FORWARD);
Serial.println("MOVING: FORWARD");
void moveBackward() {
setAllMotors(BACKWARD);
Serial.println("MOVING: BACKWARD");
void rotateLeft() {
motor1.setSpeed(motorSpeed);
motor2.setSpeed(motorSpeed);
motor3.setSpeed(motorSpeed);
motor4.setSpeed(motorSpeed);
motor1.run(BACKWARD);
motor2.run(FORWARD);
motor3.run(BACKWARD);
motor4.run(FORWARD);
Serial.println("MOVING: ROTATE LEFT");
void rotateRight() {
motor1.run(FORWARD);
motor2.run(BACKWARD);
motor3.run(FORWARD);
motor4.run(BACKWARD);
Serial.println("MOVING: ROTATE RIGHT");
void stopMoving() {
motor1.setSpeed(0);
motor2.setSpeed(0);
motor3.setSpeed(0);
motor4.setSpeed(0);
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
Serial.println("MOVING: STOPPED");
void setAllMotors(uint8_t dir) {
motor1.run(dir);
motor2.run(dir);
motor3.run(dir);
motor4.run(dir);
void handleManualDrive(String cmd) {
if (cmd == "COMMAND: FORWARD") moveForward();
else if (cmd == "COMMAND: BACKWARD") moveBackward();
else if (cmd == "COMMAND: LEFT") rotateLeft();
else if (cmd == "COMMAND: RIGHT") rotateRight();
else if (cmd == "COMMAND: FORWARD_SMOOTH") moveForward();
else if (cmd == "COMMAND: BACKWARD_SMOOTH") moveBackward();
else if (cmd == "COMMAND: LEFT_SMOOTH") rotateLeft();
else if (cmd == "COMMAND: RIGHT_SMOOTH") rotateRight();
else if (cmd == "COMMAND: ROTATE_LEFT_SERVO") {
ultrasonicServo.write(45); // Rotate servo to the left
Serial.println("Ultrasonic Sensor Rotated Left.");
else if (cmd == "COMMAND: ROTATE_RIGHT_SERVO") {
ultrasonicServo.write(135); // Rotate servo to the right
Serial.println("Ultrasonic Sensor Rotated Right.");
else if (cmd == "COMMAND: ROTATE_180_SERVO") {
ultrasonicServo.write(180); // Rotate servo to 180 degrees
Serial.println("Ultrasonic Sensor Rotated to 180 degrees.");
else if (cmd == "COMMAND: KICK_LEFT") rotateLeft();
else if (cmd == "COMMAND: KICK_RIGHT") rotateRight();
else if (cmd == "COMMAND: STOP") stopMoving();
else if (cmd == "COMMAND: RAM") { // Cross button pressed
ramModeActive = true;
motorSpeed = 255;
moveForward();
motorSpeed = 128;
stopMoving();
else if (cmd == "COMMAND: AUTO_RAM") { // Triangle button pressed
motorSpeed = 255;
moveForward();
else if (cmd == "COMMAND: MAX_SPEED") motorSpeed = 255;
else if (cmd == "COMMAND: MIN_SPEED") motorSpeed = 128;
else if (cmd == "COMMAND: STOP_RAM") {
stopMoving();
else if (cmd == "COMMAND: NORMAL_SPEED") {
motorSpeed = 128;
ESP32 Code (AI Thinker ESP32 board)
#include <Bluepad32.h>
ControllerPtr myController;
// Servo Rotation control flag
int servoAngle = 90; // Default servo angle
// Mode activation flags
// Function to process PS4 controller inputs
void processGamepad(ControllerPtr ctl) {
if (!ctl) return;
int axisRX = ctl->axisRX(); // Right joystick X-axis
int axisRY = ctl->axisRY(); // Right joystick Y-axis
// Map the R-joystick X-axis to a servo angle between 0 and 180
servoAngle = map(axisRX, -512, 512, 0, 180);
// --- L-stick for smooth movement ---
int axisLX = ctl->axisX(); // Left joystick X-axis (left-right)
int axisLY = ctl->axisY(); // Left joystick Y-axis (up-down)
// If the left analog stick is pushed up (forward), move forward
if (axisLY < -200) { // Threshold for moving forward
Serial.println("L-Stick Up: Move Forward Smoothly");
Serial.println("COMMAND: FORWARD_SMOOTH");
Serial1.println("L-Stick Up: Move Forward Smoothly");
Serial1.println("COMMAND: FORWARD_SMOOTH");
// If the left analog stick is pushed down (backward), move backward
else if (axisLY > 200) { // Threshold for moving backward
Serial.println("L-Stick Down: Move Backward Smoothly");
Serial.println("COMMAND: BACKWARD_SMOOTH");
Serial1.println("L-Stick Down: Move Backward Smoothly");
Serial1.println("COMMAND: BACKWARD_SMOOTH");
// If the left analog stick is pushed left (left), move left
if (axisLX < -200) { // Threshold for moving left
Serial.println("L-Stick Left: Move Left Smoothly");
Serial.println("COMMAND: LEFT_SMOOTH");
Serial1.println("L-Stick Left: Move Left Smoothly");
Serial1.println("COMMAND: LEFT_SMOOTH");
// If the left analog stick is pushed right (right), move right
else if (axisLX > 200) { // Threshold for moving right
Serial.println("L-Stick Right: Move Right Smoothly");
Serial.println("COMMAND: RIGHT_SMOOTH");
Serial1.println("L-Stick Right: Move Right Smoothly");
Serial1.println("COMMAND: RIGHT_SMOOTH");
// Send the servo angle to Arduino
Serial1.print("SERVO: ");
Serial1.println(servoAngle);
Serial.print("SERVO: ");
Serial.println(servoAngle);
uint16_t buttons = ctl->buttons();
// --- D-Pad for movement ---
if (ctl->dpad() == DPAD_UP) {
Serial.println("D-Pad Up: Move Forward");
Serial.println("COMMAND: FORWARD");
Serial1.println("D-Pad Up: Move Forward");
Serial1.println("COMMAND: FORWARD");
else if (ctl->dpad() == DPAD_DOWN) {
Serial.println("D-Pad Down: Move Backward");
Serial.println("COMMAND: BACKWARD");
Serial1.println("D-Pad Down: Move Backward");
Serial1.println("COMMAND: BACKWARD");
else if (ctl->dpad() == DPAD_LEFT) {
Serial.println("D-Pad Left: Move Left");
Serial.println("COMMAND: LEFT");
Serial1.println("D-Pad Left: Move Left");
Serial1.println("COMMAND: LEFT");
else if (ctl->dpad() == DPAD_RIGHT) {
Serial.println("D-Pad Right: Move Right");
Serial.println("COMMAND: RIGHT");
Serial1.println("D-Pad Right: Move Right");
Serial1.println("COMMAND: RIGHT");
// --- SDG Mode Toggle (L3 + R3) ---
if (buttons == (0x0100 | 0x0200)) { // L3 + R3 pressed
delay(200); // Small delay for stable button reading
if (!sdgModeActive) {
Serial.println("L3 + R3: Activate SDG Mode");
Serial.println("COMMAND: SDG_MODE");
Serial1.println("L3 + R3: Activate SDG Mode");
Serial1.println("COMMAND: SDG_MODE");
intruderModeActive = false; // Ensure intruder mode is off
Serial.println("L3 + R3: Deactivate SDG Mode (Return to Manual)");
Serial.println("COMMAND: SDG_MODE_OFF");
Serial1.println("L3 + R3: Deactivate SDG Mode (Return to Manual)");
Serial1.println("COMMAND: SDG_MODE_OFF");
// --- Intruder Alert Mode Toggle (R3 only) ---
else if (buttons == 0x0200) { // R3 pressed
if (!intruderModeActive) {
Serial.println("R3: Activate Intruder Alert Mode");
Serial.println("COMMAND: INTRUDER_ALERT_MODE");
Serial1.println("R3: Activate Intruder Alert Mode");
Serial1.println("COMMAND: INTRUDER_ALERT_MODE");
sdgModeActive = false; // Ensure SDG mode is off
Serial.println("R3: Deactivate Intruder Mode (Return to Manual)");
Serial.println("COMMAND: INTRUDER_ALERT_MODE_OFF");
Serial1.println("R3: Deactivate Intruder Mode (Return to Manual)");
Serial1.println("COMMAND: INTRUDER_ALERT_MODE_OFF");
// --- L3 Only ---
else if (buttons == 0x0100) { // L3 pressed alone
delay(200);
Serial.println("L3: Manual Mode Activated (Forced)");
Serial.println("COMMAND: MANUAL_MODE");
Serial1.println("L3: Manual Mode Activated (Forced)");
Serial1.println("COMMAND: MANUAL_MODE");
// Reset modes
// Feedback: Buzzer beep and LED blink command
Serial.println("COMMAND: BUZZER_BEEP");
Serial.println("COMMAND: LED_BLINK");
Serial1.println("COMMAND: BUZZER_BEEP");
Serial1.println("COMMAND: LED_BLINK");
// --- Normal manual controls ---
else if (!sdgModeActive && !intruderModeActive) {
// Handle button commands ONLY if no mode is active
if (buttons == 0x0001) { // Cross button
Serial.println("CROSS: RAM FORWARD");
Serial1.println("CROSS: RAM FORWARD");
if (buttons == 0x0002) { // Circle button
Serial.println("CIRCLE: Kick Left");
Serial.println("COMMAND: KICK_LEFT");
Serial1.println("CIRCLE: Kick Left");
Serial1.println("COMMAND: KICK_LEFT");
if (buttons == 0x0004) { // Square button
Serial.println("SQUARE: Rotate Left");
Serial.println("COMMAND: ROTATE_LEFT");
Serial1.println("SQUARE: Rotate Left");
Serial1.println("COMMAND: ROTATE_LEFT");
if (buttons == 0x0008) { // Triangle button
Serial.println("TRIANGLE: Rotate Right");
Serial.println("COMMAND: ROTATE_RIGHT");
Serial1.println("TRIANGLE: Rotate Right");
Serial1.println("COMMAND: ROTATE_RIGHT");
if (buttons == 0x0040) { // L2 button
Serial.println("L2: Decelerate and Stop");
Serial.println("COMMAND: STOP");
Serial1.println("L2: Decelerate and Stop");
Serial1.println("COMMAND: STOP");
if (buttons == 0x0080) { // R2 button
Serial.println("R2: Accelerate at Max Speed");
Serial.println("COMMAND: MAX_SPEED");
Serial1.println("R2: Accelerate at Max Speed");
Serial1.println("COMMAND: MAX_SPEED");
// Handle L1 and R1 (Servo Rotation)
if (buttons == 0x0010) { // L1
Serial.println("L1: Rotate Servo Left");
Serial.println("COMMAND: ROTATE_LEFT_SERVO");
Serial1.println("L1: Rotate Servo Left");
Serial1.println("COMMAND: ROTATE_LEFT_SERVO");
if (buttons == 0x0020) { // R1
Serial.println("R1: Rotate Servo Right");
Serial.println("COMMAND: ROTATE_RIGHT_SERVO");
Serial1.println("R1: Rotate Servo Right");
Serial1.println("COMMAND: ROTATE_RIGHT_SERVO");
if (buttons == (0x0010 | 0x0020)) { // L1 + R1
Serial.println("L1 + R1: Rotate Servo to 180 degrees");
Serial.println("COMMAND: ROTATE_180_SERVO");
Serial1.println("L1 + R1: Rotate Servo to 180 degrees");
Serial1.println("COMMAND: ROTATE_180_SERVO");
void onConnect(ControllerPtr ctl) {
Serial1.println("Controller Connected");
myController = ctl;
void onDisconnect(ControllerPtr ctl) {
Serial1.println("Controller Disconnected");
myController = nullptr;
// Use GPIO2 as RX and GPIO4 as TX for Serial1
Serial1.begin(19200, SERIAL_8N1, 2, 4);
BP32.setup(&onConnect, &onDisconnect);
BP32.forgetBluetoothKeys();
bool dataUpdated = BP32.update();
if (dataUpdated) {
processGamepad(myController);
delay(10); // Small delay for smoother operation
