need help for sending text from website to lcd
i have code to send text from webpage to lcd. i used aurduino,ethernet shield,sdcard and lcd.
now i want to modify that code to send from website to lcd.
some one who is good in php can help me
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include "rgb_lcd.h"
#include <Wire.h>
rgb_lcd lcd;
#define REQ_BUF_SZ   90
#define LCD_BUF_SZ   17
byte mac[] = {
  0x98, 0x4F, 0xEE,0x01, 0x65, 0x4E };
IPAddress ip(192,168,19,170);
String readString;
EthernetServer server(80);      // create a server at port 80
File webFile;                    // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
char lcd_buf_1[LCD_BUF_SZ] = {0};// buffer to save LCD line 1 text to
char lcd_buf_2[LCD_BUF_SZ] = {0};// buffer to save LCD line 2 text to
//LiquidCrystal lcd(3, 2, 8, 7, 6, 5);
    // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(115200);       // for debugging
    lcd.begin(16, 2);
    // Message on LCD
    lcd.print(F("Initializing"));
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        lcd.print(F("SD init failed"));
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    // End of initialization message on LCD + print IP address
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print(F("Done."));
    lcd.setCursor(0, 1);
    lcd.print(ip);
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                // limit the size of the stored received HTTP request
                // buffer first part of HTTP request in HTTP_req array (string)
                // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (StrContains(HTTP_req, "ajax_inputs")) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        // print the received text to the LCD if found
                        if (GetLcdText(lcd_buf_1, lcd_buf_2, LCD_BUF_SZ)) {
                          // lcd_buf_1 and lcd_buf_2 now contain the text from
                          // the web page
                          // write the received text to the LCD
                          lcd.clear();
                          lcd.print(lcd_buf_1);
                          lcd.print(lcd_buf_2);
                    else {  // web page request
                        client.println("Content-Type: text/html");
                        client.println();
                        // send web page
                        webFile = SD.open("index.htm");        // open web page file
                        if (webFile) {
                            while(webFile.available()) {
                                client.write(webFile.read()); // send web page to client
                            webFile.close();
                    // reset buffer index and all buffer elements to 0
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
// get the two strings for the LCD from the incoming HTTP GET request
boolean GetLcdText(char *line1, char *line2, int len)
  boolean got_text = false;    // text received flag
  char *str_begin;             // pointer to start of text
  char *str_end;               // pointer to end of text
  int str_len = 0;
  int txt_index = 0;
  char *current_line;
  current_line = line1;
  // get pointer to the beginning of the text
  str_begin = strstr(HTTP_req, "&L1=");
  for (int j = 0; j < 2; j++) { // do for 2 lines of text
    if (str_begin != NULL) {
      str_begin = strstr(str_begin, "=");  // skip to the =
      str_begin += 1;                      // skip over the =
      str_end = strstr(str_begin, "&");
      if (str_end != NULL) {
        str_end[0] = 0;  // terminate the string
        str_len = strlen(str_begin);
        // copy the string to the buffer and replace %20 with space ' '
        for (int i = 0; i < str_len; i++) {
          if (str_begin[i] != '%') {
            if (str_begin[i] == 0) {
              // end of string
            else {
              current_line[txt_index++] = str_begin[i];
              if (txt_index >= (len - 1)) {
                // keep the output string within bounds
          else {
            // replace %20 with a space
            if ((str_begin[i + 1] == '2') && (str_begin[i + 2] == '0')) {
              current_line[txt_index++] = ' ';
              i += 2;
        } // end for i loop
        current_line[txt_index] = 0;
        if (j == 0) {
          // got first line of text, now get second line
          str_begin = strstr(&str_end[1], "L2=");
          current_line = line2;
          txt_index = 0;
        got_text = true;
  } // end for j loop
  return got_text;
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
index.htm.txt (1.18 KB)
A web page is what a browser has rendered from some HTML. You can NOT make the browser send data to an Arduino to display on an LCD.
You CAN make the Arduino wear an Ethernet shield, and server up a "web page" that contains a form with a text field and a submit button.
You can make the Arduino handle GET requests for the page differently from GET requests that contain name equal value pairs (where name is the name of the text field and value is the data from the text field).
There is absolutely no reason to use Ajax for that.
