Can anyone teach me how to change to scale for the following Simple Arduino Scope coding ? It is found in the example.
import arduinoscope.*;
import processing.serial.*;
// this example requires controlP5
// http://www.sojamo.de/libraries/controlP5/
import controlP5.*;
// how many scopes, you decide.
Oscilloscope[] scopes = new Oscilloscope[1];
Serial port;
ControlP5 controlP5;
PFont fontLarge;
PFont fontSmall;
int LINE_FEED=10;
int[] vals;
size(800, 800, P2D);
background(0);
controlP5 = new ControlP5(this);
// set these up under tools/create font, if they are not setup.
fontLarge = loadFont("TrebuchetMS-20.vlw");
fontSmall = loadFont("Uni0554-8.vlw");
int[] dimv = new int[2];
dimv[0] = width-130; // 130 margin for text
dimv[1] = height/scopes.length;
// setup vals from serial
vals = new int[scopes.length];
for (int i=0;i<scopes.length;i++){
int[] posv = new int[2];
posv[0]=0;
posv[1]=dimv[1]*i;
// random color, that will look nice and be visible
scopes[i] = new Oscilloscope(this, posv, dimv);
scopes[i].setLine_color(color((int)random(255), (int)random(127)+127, 255));
controlP5.addButton("pause",1,dimv[0]+10,posv[1]+10,32,20).setId(i);
controlP5.addButton("logic",1,dimv[0]+52,posv[1]+10,29,20).setId(i+50);
controlP5.addButton("save",1,dimv[0]+92,posv[1]+10,29,20).setId(i+100);
port = new Serial(this, Serial.list()[0], 115200);
// clear and wait for linefeed
port.clear();
port.bufferUntil(LINE_FEED);
void draw()
background(0);
// int[] vals = getTestValuesSquare();
// int[] vals = getTestValuesSin();
// update and draw scopes
scopes[i].addData(vals[i]);
scopes[i].draw();
// conversion multiplier for voltage
float multiplier = scopes[i].getMultiplier()/scopes[i].getResolution();
// convert arduino vals to voltage
float minval = scopes[i].getMinval() * multiplier;
float maxval = scopes[i].getMaxval() * multiplier;
int[] values = scopes[i].getValues();
float pinval = values[values.length-1] * multiplier;
// add lines
scopes[i].drawBounds();
stroke(255);
int[] pos = scopes[i].getPos();
int[] dim = scopes[i].getDim();
line(0, pos[1], width, pos[1]);
// add labels
fill(255);
textFont(fontLarge);
text(pinval, width-60, pos[1] + dim[1] - 10);
textFont(fontSmall);
text("min: " + minval, dim[0] + 10, pos[1] + 40);
text("max: " + maxval, dim[0] + 10, pos[1] + 48);
fill(scopes[i].getLine_color());
text("pin: " + i, dim[0] + 10,pos[1] + dim[1] - 10);
// draw text seperator, based on first scope
int[] dim = scopes[0].getDim();
stroke(255);
line(dim[0], 0, dim[0], height);
// update buttons
controlP5.draw();
// handles button clicks
void controlEvent(ControlEvent theEvent) {
int id = theEvent.controller().id();
// button families are in chunks of 50 to avoid collisions
if (id < 50){
scopes[id].setPause(!scopes[id].isPause());
}else if (id < 100){
scopes[id-50].setLogicMode(!scopes[id-50].isLogicMode());
}else if(id < 150){
String fname = "data"+(id-100)+".csv";
scopes[id-100].saveData(fname);
println("Saved as "+fname);
// handle serial data
void serialEvent(Serial p) {
String data = p.readStringUntil(LINE_FEED);
if (data != null) {
// println(data);
vals = int(split(data, ' '));
// for test data, you can comment, if not using
int d=0;
ControlTimer ct = new ControlTimer();
int[] getTestValuesSin(){
int[] vals = new int[scopes.length];
// this is test data
if (d==45){
d=0;
int sval = (int) abs(sin(d*2)*1023.0f);
vals[i]=sval;
d++;
return vals;
int oldtime;
int time;
boolean up=false;
int[] getTestValuesSquare(){
ct.setSpeedOfTime(25);
oldtime=time;
time = ct.second();
if (oldtime==time){
up = !up;
if (up){
vals[i]=1023;
}else{
vals[i]=0;
return vals;
