#include <Servo.h>
#include <math.h>
#define Echo 7
#define Trigger 8
#define S0 A1
#define S1 A2
#define S2 A3
#define S3 A4
#define sensorOut A5
Servo servo1,servo2,servo3,servo4,gripper;
long Durasi;
int Jarak;
float min_PWM;
float max_PWM;
float Delay_MS = 50.000;
float Pi = 3.141592653589793;
float Yoffset;
float D;
float d;
float R;
float L1 = 64.50;
float L2 = 105.00;
float L3 = 98.50;
float L4 = 100.00;
float X_End_Effector,Y_End_Effector,Z_End_Effector;
int pin_servo1 = 5;
int pin_servo2 = 6;
int pin_servo3 = 9;
int pin_servo4 = 10;
int pin_gripper = 11;
float alpha1, alpha2, sudut_servo1, sudut_servo2, sudut_servo3, sudut_servo4;
float gerak_servo1 = 90.00;
float gerak_servo2 = 90.00;
float gerak_servo3 = 90.00;
float gerak_servo4 = 90.00;
pinMode(Trigger, OUTPUT);
pinMode(Echo, INPUT);
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut, INPUT);
digitalWrite(S0, HIGH);
digitalWrite(S1, LOW);
servo1.attach(pin_servo1, min_PWM = 500.0, max_PWM = 2500.00);
servo2.attach(pin_servo2, min_PWM = 544.0, max_PWM = 544.00+(180.00/(190.00/(2000.00-544.00))));
servo3.attach(pin_servo3, min_PWM = 544.0, max_PWM = 2030.00);
servo4.attach(pin_servo4, min_PWM = 500.0, max_PWM = 2500.00);
gripper.attach(pin_gripper);
void Rumus_IK()
if (X_End_Effector > 0 && Y_End_Effector >= L1)
D = sqrt(pow(X_End_Effector,2) + pow(Z_End_Effector,2));
sudut_servo3 = (atan(Z_End_Effector/X_End_Effector))*(180.00/Pi);
d = D - L4;
Yoffset = Y_End_Effector - L1;
R = sqrt(pow(d,2) + pow(Yoffset,2));
alpha1 = (acos(d/R))*(180.00/Pi);
alpha2 = (acos((pow(L2,2) + pow(R,2) - pow(L3,2))/(2*L2*R)))*(180.00/Pi);
sudut_servo1 = (alpha1 + alpha2);
sudut_servo4 = ((acos((pow(L2,2) + pow(L3,2) - pow(R,2))/(2*L2*L3)))*(180.00/Pi));
sudut_servo2 = 180.00 - ((180.00 - (alpha2 + sudut_servo4)) - alpha1);
else if (X_End_Effector > 0 && Y_End_Effector <= L1)
d = D - L4;
sudut_servo1 = (alpha2 - alpha1);
sudut_servo2 = 180.00 - ((180.00 - (alpha2 + sudut_servo4)) + alpha1);
else if (X_End_Effector == 0 && Y_End_Effector >= L1)
sudut_servo3 = 90.00;
d = D - L4;
else if (X_End_Effector == 0 && Y_End_Effector <= L1)
d = D - L4;
else if (X_End_Effector < 0 && Y_End_Effector >= L1)
sudut_servo3 = 90.00 + (90 - abs((atan(Z_End_Effector/X_End_Effector))*(180.00/Pi)));
d = D - L4;
else if (X_End_Effector < 0 && Y_End_Effector <= L1)
sudut_servo3 = 90.00 + (90.00 - abs((atan(Z_End_Effector/X_End_Effector))*(180.00/Pi)));
d = D - L4;
void gerak_increment_servo3()
Rumus_IK();
for(gerak_servo3 == sudut_servo3; gerak_servo3 <= sudut_servo3; gerak_servo3 += 0.01)
servo3.write(gerak_servo3);
delayMicroseconds(Delay_MS);
for(gerak_servo3 == sudut_servo3; gerak_servo3 >= sudut_servo3; gerak_servo3 -= 0.01)
void gerak_increment_servo1()
Rumus_IK();
for(gerak_servo1 == sudut_servo1; gerak_servo1 <= sudut_servo1; gerak_servo1 += 0.01)
servo1.write(gerak_servo1);
for(gerak_servo1 == sudut_servo1; gerak_servo1 >= sudut_servo1; gerak_servo1 -= 0.01)
void gerak_increment_servo4()
Rumus_IK();
for(gerak_servo4 == sudut_servo4; gerak_servo4 <= sudut_servo4; gerak_servo4 += 0.01)
servo4.write(gerak_servo4);
for(gerak_servo4 == sudut_servo4; gerak_servo4 >= sudut_servo4; gerak_servo4 -= 0.01)
void gerak_increment_servo2()
Rumus_IK();
for(gerak_servo2 == (sudut_servo2 - 90.00); gerak_servo2 <= (sudut_servo2 - 90.00); gerak_servo2 += 0.01)
servo2.write(gerak_servo2);
for(gerak_servo2 == (sudut_servo2 - 90.00); gerak_servo2 >= (sudut_servo2 - 90.00); gerak_servo2 -= 0.01)
void gerak_increment_servo_1_4_2()
Rumus_IK();
for(gerak_servo1 = sudut_servo1, gerak_servo4 = sudut_servo4; gerak_servo1 <= sudut_servo1 && gerak_servo4 <= sudut_servo4; gerak_servo1 += 0.01, gerak_servo4 += 0.01)
for(gerak_servo1 = sudut_servo1, gerak_servo4 = sudut_servo4; gerak_servo1 >= sudut_servo1 && gerak_servo4 >= sudut_servo4; gerak_servo1 -= 0.01, gerak_servo4 -= 0.01)
digitalWrite(Trigger, LOW);
delayMicroseconds(2);
digitalWrite(Trigger, HIGH);
delayMicroseconds(10);
Durasi = pulseIn(Echo, HIGH);
Jarak = Durasi*0.034/2;
if(Jarak >= 10)//posisi home, saat ga ada objek
gripper.write(150);
X_End_Effector = 100.00;
Y_End_Effector = 200.00;
Z_End_Effector = 5.00;
gerak_increment_servo1();
gerak_increment_servo4();
gerak_increment_servo2();
//gerak_increment_servo_1_4_2();
gerak_increment_servo3();
else if(Jarak < 10)
{//ambil(masih di atas)
X_End_Effector = 10.00;
Y_End_Effector = 100.00;
Z_End_Effector = 200.00;
