Hello guys,i need help to drive this stepper motor using ims 200....any of u have used this driver before???
Im using arduino uno v3 to control, but still cant.
-motor model=PF464-02(a)
Another question, what is phase inductance means???
the motor has 1.5 Khz...is that stand for the motor frequency?
correct me if im wrong....
Here i attached the datasheet for the driver and motor....
Either study inductance on Wikipedia or ignore it.
If you want help with your problem do the following (all of them).
Post a link to the other Thread so I can re-read it.
Post your code, and please use the # button to insert code tags before and after it.
Post a diagram of how you have things connected - a photo of a clear pencil drawing is fine.
kay88:
Hai Mark, here part where the datasheet write about the phase inductance..
Still can't see anything about 1.5kHz. There's an entry for 1.5mH (millihenries) in
the inductance column. The henry is the unit of inductance being that value that
leads to an induced voltage of exactly 1V when the current changes at exactly 1A/s
The lower the winding inductance the faster the motor can turn for a given supply
voltage, since inductance limits the rate at which winding current can change.
