Got a Nano clone that I've used in projects before, most recently in a stepper motor project. Now when I try to load a sketch, get programmer not responding:
Arduino: 1.8.9 (Windows XP), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 930 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
D:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_85052/Blink.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "D:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_85052/Blink.ino.hex"
avrdude: writing flash (930 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
######avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
This is one of 3 Nano boards I have, and I can load sketches to the other 2. Next thing I did was the Loop-back test and had no problems. After that, decided to try and burn the boot loader again using 1 of the other Nanos I had. No luck (error output in next post)
Any ideas of things to try?
EDIT: One thing I noticed is when I hit the RESET button, the onboard LED flashes dim. The other 2 boards flash bright. Also, I tried burning a boot loader from one good board to the other good board and that didn't work for me either, so I'm not sure how exactly to do that (using one Nano as the programmer to burn the boot loader into the other Nano).
Output when I try to burn the bootloader:
D:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
Using Port : COM6
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4744608
Firmware Version: 0.4611299
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
Error while burning bootloader.
Try to put 10uF capacitor between RESET pin and GND pin on Nano which is used as programmer.
From your log:
the parameter -carduino causes that the reset pulse is generated by avrdude at the start of uploading process. This resets programmer Nano and uploading process fails, because programmer Nano skip to its bootloader and expects instructions for self programming.
The RESET-GND capacitor removes this reset pulse so programmer board can continue perform Arduino as ISP sketch.
Hard to say. It is probably damaged, but if it still flashes it can be good though.
Budvar10:
Thank you! This seemed to work for me, but some issues. See next post for loading sketch issues. (Dang character limit of 9000 won't let me post both code snippets in 1 post.)
D:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b19200 -Uflash:w:D:\Program Files\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:i -Ulock:w:0x0F:m
Using Port : COM6
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "D:\Program Files\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex"
avrdude: writing flash (32670 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32670 bytes of flash written
avrdude: verifying flash memory against D:\Program Files\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: load data flash data from input file D:\Program Files\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: input file D:\Program Files\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex contains 32670 bytes
avrdude: reading on-chip flash data:
avrdude: verifying ...
avrdude: 32670 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.05s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock verified
When I load a sketch to the "Fixed" Nano, it has a little trouble and gets a verification error. It looks like it writes the sketch, but it doesn't. The following code shows I loaded blink.ino, and I thought it was a success, but when I tried a different sketch, the blink.ino runs (I assume this came with the bootloader that I was able to burn to it). So what is going on here? Can I only load sketches through ISP? That is what I'm trying next.
EDIT: Yes, I can load a sketch through ISP.
D:\Program Files\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_713297/Blink.ino.hex:i
Using Port : COM6
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: reading input file "D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_713297/Blink.ino.hex"
############################################ | 100% 23.73s
avrdude: 930 bytes of flash written
avrdude: verifying flash memory against D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_713297/Blink.ino.hex:
avrdude: load data flash data from input file D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_713297/Blink.ino.hex:
avrdude: input file D:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_713297/Blink.ino.hex contains 930 bytes
Reading | ################################################## | 100% 0.25s
avrdude: verification error, first mismatch at byte 0x0000
0xff != 0x0c
avrdude: verification error; content mismatch
the selected serial port
does not exist or your board is not connected
If you load a sketch through ISP, previously uploaded image is erased, also the bootloader.
