I'm onto version 3 of my motorbike grip heater controller + clock. V1 had an LCD display, but the display would go black when left in the sun. V2 uses a LED display with large digits, but even at maximum brightness they can't easily be seen when full sunlight is on the display. For V3 I thought I'd give E-Paper a try.
I purchased a Waveshare 2.66" display along with an ESP32 display driver. I've managed to integrate that into the Arduino IDE and got a test program working, but the largest font available under their library is 24 - and I really need something at least 4 times bigger than that.
Can anyone suggest anything that already exists before I go down the labourious path of creating an appropriate font / images myself? It only needs to have digits 0 -> 9 plus colon.
One option would be to try out the GxEPD2 library.
It's based on AdafruitGFX and has handy stuff like setTextSize(4) to get a 4x magnification. It also comes with a few different font choices, and I think there are more around the web.
I suspect that you might need to use the GxEPD2_266_BN class.
I did install that library and looked at one of the examples but, unfortunately, I don't yet know enough about how to configure it correctly to make it work with my hardware, and ended up with compile errors.
I might "sink my teeth" into it a bit more this weekend and try to figure it out. I'm an absolute novice when it comes to E-Paper displays; and I'm lead to believe that are a bit more "finicky" than the other technologies (ones that I also struggle a bit with but generally "get there in the end").
It is a standard way of changing font size. You can look at the AdafruitGFX library code to see how they do it, and at the Waveshare library code to see if such an option exists, or would be simple to implement.
These e-paper displays can be read in full sunlight, but you need good UV protection and heat protection, else they turn black in sunlight, especially during screen update.
I would recommend to use transflective TFT displays for your purpose.
To increase the font size on a Waveshare E-Paper Display with a 2.66-inch screen, you will typically need to modify the code or configuration settings of the device or software you are using to control the display. Here are some general steps to help you achieve a larger font size:
Check the Display Resolution: Determine the resolution of your 2.66-inch Waveshare E-Paper Display. Knowing the resolution (e.g., 296x128 pixels) will help you understand the available space for text.
Select a Font Library: Many E-Paper Displays allow you to use custom fonts or fonts from a library. You can search for a font library that offers larger font sizes and select an appropriate font file.
Modify the Code: If you are using code to display text on the E-Paper Display, locate the part of the code where the font size is set. It is often controlled by parameters like font size, height, and width. Increase these values to make the text larger. Be careful not to exceed the display's resolution or dimensions.
Here's an example using Python and the Waveshare library for a Raspberry Pi:
python
from waveshare_epd import epd2in66
epd = epd2in66.EPD()
epd.init()
font_size = 24 # Increase this value for a larger font
epd.set_font_size(font_size)
Adjust Text Position: After increasing the font size, you might need to adjust the position of the text to ensure it fits within the display without overlapping or going beyond the edges.
Test and Iterate: Run your code with the modified settings and check if the font size on the display meets your requirements. If not, continue tweaking the font size and text positioning until you achieve the desired result.
Consider Display Limitations: Keep in mind that larger fonts may reduce the amount of text you can display on the screen simultaneously. Make sure the chosen font size fits the intended purpose of the display.
Documentation and Libraries: Refer to the documentation provided with your E-Paper Display and any libraries you are using for specific instructions on font size customization. Different displays and libraries may have variations in how they handle font rendering.
Hardware Limitations: Lastly, be aware that the display's physical size and resolution can limit how large you can make the font while still maintaining readability.
By following these steps and customizing your code or settings, you should be able to increase the font size on your 2.66-inch Waveshare E-Paper Display to better suit your needs.
