Here is some stuff that may be useful for others out there:
For an I2C connection you can run the following code to find out the address of the device:
#include <Wire.h>
Wire.begin(); // join i2c bus (address optional for master)
byte val = 88;
Wire.beginTransmission(val); // transmit to device #44 (0x2c)
Wire.send(0); // sends instruction byte
Wire.send(val); // sends potentiometer value byte
Wire.send(0);
Wire.endTransmission(); // stop transmitting
Serial.println(val);
val++; increment value
For those using the same Devantech drive system the following code may be helpful:
#include <Wire.h>
Serial.begin(9600); // start serial communication at 9600bps
int reading = 0;
int count = 0;
int reset = HIGH;
Wire.onRequest(resetEncA); // reset encoder to zero
// step 1: instruct sensor to read echoes
// Wire.beginTransmission(88); // transmit to device #112 (0x58)
// the address specified in the datasheet is 176 (0xB0)
// but i2c adressing uses the high 7 bits so it’s 88
Wire.send(0x00); // sets register pointer to the command register (0x00)
Wire.send(0x01); // command sensor to measure in “inches” (0x50)
Wire.send(-0x50); // use 0x51 for centimeters
// use 0x52 for ping microseconds
// step 2: wait for readings to happen
delay(70); // datasheet suggests at least 65 milliseconds
// step 3: instruct sensor to return a particular echo reading
Wire.send(0x02); // sets register pointer to echo #1 register (0x02)
// step 4: request reading from sensor
Wire.requestFrom(88, 1); // request 2 bytes from slave device #112
// step 5: receive reading from sensor
if(1 <= Wire.available()) // if two bytes were received
reading = Wire.receive(); // receive high byte (overwrites previous reading)
//reading = reading << 8; // shift high byte to be high 8 bits
//reading |= Wire.receive(); // receive low byte as lower 8 bits
Serial.print(reading, DEC); // print the reading
if (reading <= 255)
count++;
Serial.print("\t");
Serial.print(“count = “);
Serial.print(count);
Serial.print(”\n”);
delay(250); // wait a bit since people have to read the output
void resetEncA(int reset)
if (reset == HIGH)
Wire.send(0x10); // sets register pointer to echo #1 register (0x02)
Wire.send(0x20); // command register sets encoder to zero (0x20)
As a building block, I used the code from Nicholas Zambetti’s http://www.zambetti.com and James Tichenor I2C SRF10 or SRF08 Devantech Ultrasonic Ranger Finder. This code will read from the encoder, however I need to somehow increment each reading, because as of now, it will only read up to one rotation.
